help grease around cv boot, is it leaking?
Old Oct 14, 2005 | 04:10 PM
super6's Avatar
i noticed about bean size amount of grease by the inner edge of the cv boot. it this just normal to have or does that mean its leaking, ive heard that thing is a biatch to replace............and just when i thought everything was done
Old Oct 14, 2005 | 04:57 PM
BewstAdd1ct's Avatar
no, sometimes a heavy plunge will squeeze grease beetween the boot and shaft. inspect the boots by using your hands, not just by looking at them, ck the pleats for tears.
hope this helps
Old Oct 14, 2005 | 08:50 PM
super6's Avatar
hope this helps
kool, well do
Old Oct 14, 2005 | 09:15 PM
Insane Maxima's Avatar
If your boot is cracked/broken, its much easier to just replace the entire left/right side axle. Make sure you get an alignment afterwards so you dont screw up your tires.
Old Oct 15, 2005 | 06:25 PM
FanaticMadMax's Avatar
it's likely that you have a cracked or torn boot. That is a telltale of sign of grease on it.
Old Oct 15, 2005 | 06:48 PM
Puppetmaster's Avatar
Here's some good info:
http://www.motorvate.ca/auto/maxima/cv/cv_inspect.htm
And if necessary:
http://www.motorvate.ca/auto/maxima/...andr-part1.htm
Old Oct 16, 2005 | 01:50 PM
super6's Avatar
the grease is really on the axel part not on boot itself. i really hope not, too much maintnence lately.
Old Oct 17, 2005 | 07:34 AM
chr0nos's Avatar
i cut mine when replacing the springs last month. over the period of a few weeks there are quite a few splatters of grease on the inside of my wheel, and on various suspension parts.
i wil be replacing them on both sides this week. here is a tip for anyone doing a suspension upgrade: cover your cv boot with a bath tower or somethign when pulling the strut assembly out. this prevents you from cutting the cv boots.
puppet, thanks for the great link for cv replacement, i am sure it will help greately this weekend.
Old Oct 18, 2005 | 03:56 PM
alignment isnt required after axle replacement, as long as its done properly.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
knight_yyz
Nov 1, 2015 01:34 PM
followthadollar
Sep 17, 2015 06:31 PM
