2k2 3.5L -- Did an oil change last night, this morning car made an awful rattling.
Old Oct 18, 2005 | 04:22 AM
Colossus's Avatar
Yesterday I did an oil change around 4:00pm (4 1/4 quarts of 5W-30 with new filter).
Right after the oil change, I started the car and the oil guage flash really quickly for about half a second, then the car started and sounded great.
This morning I started the car and I heard an awful rattle noise (timing chain?). I'm assuming the oil just hadn't splashed all the areas yet so there was a little metal on metal action going on. Is this normal?
Old Oct 18, 2005 | 05:50 AM
2003PearlMaxima's Avatar
never had that issue, i dis have a bit of a chanin rattle before but it was fixed by the dealer... a rattling noise after oil change does not sound normal.
Sorry to hijack your Thread
Mods..How long do i have to wait till i can open a new thread ?
Old Oct 18, 2005 | 05:56 AM
jimmycapp's Avatar
Nissan filters have a built in Check-valve(one-way). This keeps the system pressurized when the engine is off. This also keeps tension in the timing chain tensioners. When you change the oil, you lose the pressure, and you hear chain noise on first startup. If you did not use an oem filter, you may hear that every startup.
James
Old Oct 18, 2005 | 06:08 AM
Colossus's Avatar
The previous filter was an STP or something and I bought new OEM Nissan filters...so it is odd that it made the noise.
I'll post if it keeps making the noise.
Old Oct 18, 2005 | 06:26 AM
2002 Maxima SE's Avatar
I get that noise regardless of whether I use Nissan OEM filters or not. This problem is due to the timing chain, its just a coincidence you were changing your oil before you heard it. The noise happens more frequently in cold weather (at least for me). The fix, is a TSB where the service center will have to remove half your engine to put a new sprocket in. For some this has worked, for others it has not.
I think it best to ignore it.
Old Oct 18, 2005 | 06:47 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Is this a problem evident in only in the 5.5 gen?
Old Oct 18, 2005 | 07:08 AM
KCMC582's Avatar
i think 2002 Maxima is right, it was just a coincidence that this happened after an oil change. since it is getting colder, you will probably hear this more now. mine has been doing this for a while, it is a TSB. the oil light flashes for a sec, and the rattle seems to come from the top of the engine bay, and lasts for a second. one of these days i will have another dealer look at it, since mine said its my Cattman catback rattling
Old Oct 18, 2005 | 07:20 AM
Dohcser's Avatar
Anyone have the TSB number?
Old Oct 18, 2005 | 07:38 AM
boondoxmax's Avatar
both my 5.5 gen did that. Just ignore it. No harm to the engine and also it doesn't matter what oil filter you use it will still rattle sometime.......
Old Oct 18, 2005 | 07:39 AM
KCMC582's Avatar
http://maxima.theowensfamily.com/tsb/NTB03-060.pdf
Old Oct 18, 2005 | 07:40 AM
chr0nos's Avatar
i think my oil light flashes every time i start the car, just like the airbag and seabelt lights. is this normal for everyone, or am i loosing too much oil?
Old Oct 18, 2005 | 07:47 AM
BigFly_2K2SE's Avatar
This is interesting, I recently noticed the "cold start timing chain rattle" on my 2K2 and it, coincidentally, also occurred very shortly (within a few days) after an oil change.
It happened to me twice and I am 3,000km from the end of my powertrain warranty so I was planning to take it in to get it fixed, but the last few times I have tried to re-enact it, it hasn't happened. I just know that if I take it in to the dealer they will be "unable to duplicate problem" and I will get hit with an $80 diagnostic fee. Then sure as anything the problem will get much worse as soon as my warranty expires.
Old Oct 18, 2005 | 08:06 AM
All the lights flash at start up. Perfectly normal.
Old Oct 18, 2005 | 08:08 AM
AcerX's Avatar
It is normal, as long as it doesn't flash for more than 5 secs or stay on entirely there shouldn't be a problem.
Old Oct 18, 2005 | 08:40 AM
03maxima1's Avatar
Why ignore it? I am having this done and it is under the 5/60 warrenty.
Old Oct 18, 2005 | 09:07 AM
Why? Because the Nissan Mechanics are only good at replacing items...small items. A new water pump, a new alternator, an oil change...these are things they can do. By having them do this TSB, you're trusting them to remove half your engine, remove/replace parts and put it back together again. I don't believe they are competent enough to do this work.
I would prefer to go to an independent mechanic I trust, pay for it and then submit the bill to Nissan for reimbursement. That way, you know the mechanic is competent to do the fix. This is a big job (see exploded diagram in PDF above). Short of this I would live with it rather than endure the missing pieces, not torqued to spec bolts, and leaking gaskets that are sure to come from this type of fix.
Old Oct 18, 2005 | 09:46 AM
OOmaxSE's Avatar
yeah! same here, my oil light quickly flashes every start up... sometimes flashes for up to a full second or maybe two. goes along with my airbag light and SES light
Old Oct 18, 2005 | 10:17 AM
chr0nos's Avatar
cool. that's what i figured, it was just a diagnostic flash/check. spanx for the replies to all.
Old Oct 18, 2005 | 10:26 AM
Colossus's Avatar
As long as no harm is being done, I will be leaving it alone. It makes the noise for less than one second. And it didn't appear to happen this afternoon with some warmer temperatures. I checked my dipstick after it sat for about 3 hours (to make sure my oil change was precise) and the oil is sitting exactly at the H maximum line, so the amount of oil is in there is perfect. Ah well, just a noise to live with!
Old Oct 18, 2005 | 01:52 PM
MAX_AE's Avatar
Nope, it happens on the 5th gen too. If my car is cold and I crank it to say back it out or into the garage. Turn it off. Next morning crank it up...it rattles and idles rough for a couple of seconds. But it's soon back to normal.
Old Oct 18, 2005 | 05:29 PM
BewstAdd1ct's Avatar
im calling on your whole post
you wont be submitting anything to nissan for warranty reimbursement unless the repair was done by a dealer. as far as nissan is concerned, the only tech is trusts are the ones employed by the dealer. besides, its a rare occasion that an engine tech at a dealer leave something loose, or neglect to replace a gasket. if the job comes back, the tech works for free. you dont pay a dime.
nissan dealer techs can only do small jobs, huh? id bet i could point out a few that would prove you wrong.
Old Oct 18, 2005 | 05:42 PM
Not true. In 1993 I had a transmission rebuilt on a 1991 Ford Explorer by an independent mechanic with only 30k miles on it. I submitted the paperwork to the local Ford dealer service advisor and received a check in the mail.
Who are you trying to fool?
But I thought it never happens? Its a little late when that overfilled oil pan or drain plug that fell out comes back. Just two cases I've read on this board alone.
I should have stated that all the techs I have come in contact with in 3 states are incompetent. Two of the dealers being the only ones available in a 30 mile radius. I retract my blanket statement about ALL Nissan dealers, just the 5 I've dealt with since owning my car.
Stewpid's Avatar
You'd rather take your Nissan to a tech who has to repair all makes and models for a major engine repair, than someone who only services Nissans day in day out, who has probably done this repair a hundred times?
Technicians who sevice all brands deserve alot of respect, but I doubt they see as much of the same concern as the dealer tech does. Especially when a tsb is concerned.
Old Oct 18, 2005 | 05:48 PM
I go to an independent who only services Nissan, Honda, and Toyota. They do excellent work, better than any Nissan dealer I've ever been too.
Old Oct 18, 2005 | 05:58 PM
Stewpid's Avatar
Fair enough. Specialists are your best bet. Dealer or independant.but that was an insulting generalization of Nissan techs.(I am not one)
Old Oct 18, 2005 | 06:04 PM
OMG its just an AODE... read my sentence again. i said nissan. and you point out a ford example. comprehension, anyone?
im not fooling, or trying to fool anyone. if the heavy line guy fkk'd up every engine he worked on, he wouldnt be the heavy line guy. same goes for light line, same for driveability.
i didnt say never. everyone makes mistakes, apparently the dealers in your area are worse than others. dont twist my sentences around
provide links plz, and id also like to see where they didnt get an engine free of charge.
so move, or buy another make. stop judging others and making assumptions and accusations based on a small portion.
Old Oct 18, 2005 | 06:13 PM
I gave a warranty example you said was BS but it has to be with a Nissan dealer. What don't you understand about a car manufacturer warranty being honored for non-dealer work?
I bought a Nissan and expected good work by said dealer...5 of them. My experience with the manufacturer's service is littered with incompetence and begging for excellent ratings on the SS.
You can ignore the bad service experiences on this board, but it does not make them any less true.
Old Oct 18, 2005 | 06:47 PM
Perhaps if the ones I had dealt with could complete a simple procedure without fault my impression would be different.
Old Oct 18, 2005 | 07:04 PM
theMax's Avatar
Try filling the oil filter like half way before you screw it on. This will have a faster source of oil to the engine.
Old Oct 18, 2005 | 07:34 PM
PoLo's Avatar
2-Wheelin it...
filter sits at 90 degrees and you need to screw it in. would you like to rethink your statement.
Old Oct 18, 2005 | 07:36 PM
i dont understand why you havent shown me anything credible stating so. all i have is your word.
im not claiming theyre less true, and there isnt a dealer in the nation with a 100% CSI score, so whats your point?
Old Oct 18, 2005 | 07:39 PM
PoLo's Avatar
2-Wheelin it...
might you like to add, NO NISSAN DEALER WILL ACCEPT AN INVOICE from you. if they do, would you please let me know as i'm about to pay someoen $300 for a $3000 engine replacement invoice.....CHACHING!!!!!!!!!!!!
Old Oct 18, 2005 | 07:42 PM
indeed, it opens the door for fraud, and technical difficulty. what would the warranty dept. do with all the jumbled warranty claims, misinfo, and inccorect forms.
though something as simple as a 4L60E getting a new rear sun gear at a pre authorized tranny shop under warranty might be a different story...
Old Oct 18, 2005 | 08:13 PM
shoman94's Avatar
Please keep on topic......
Also to the OP....what part number filter did you use?
Old Oct 19, 2005 | 12:42 AM
chinaonnitrous1's Avatar
Man, I would not TRUST a nissan dealer to rip out half my motor..........
With the cost cutting, shady mangment of independently owned nissan dealers.
Nissan North America, always says, that they cannot control the actions of the dealerships since they are privately owned.
Yet they send out certificates and recgonition based on what? The least amount of complaints the dealership reccives?
NNA dosen't back up the customers, just the dealerships. Ive had to pull teeth and go head to head with NNA, and the tech they sent out to replace a faulty MAF in january 2002. And guess what, they have a new-and improved version later.
Unless you have a super strong relationship with your service manager, I wouldnt bring my car within sight of a dealership.
Old Oct 19, 2005 | 04:22 AM
Colossus's Avatar
I stopped in at the local Nissan dealership and bought four oil filters (buy 3, 4th filter is free) for a 2002 Maxima 3.5 liter. Not sure on part number, but it's on my receipt I'm sure.
Old Oct 19, 2005 | 05:13 AM
You claim people who had a bad dealer service experience/dealer made mistakes is a "small portion" (your words). It's not. Grow a thicker skin.
Old Oct 19, 2005 | 05:40 AM
rbrown81's Avatar
But why is teh Rum gone?
What a moron.
Old Oct 19, 2005 | 07:48 AM
That's why he said fill it halfway. If you fill it half and then turn it 90 as you screw it on all in one motion, you won't spill a drop.
Old Oct 19, 2005 | 08:48 AM
03maxima1's Avatar
I took my car to them last Wednesday because when I started it I heard clicking or pinging noises from under the hood. When pressed on the gas it got faster and a little louder. I took the car in and they told me that it was the VTC Sprockets. They fixed the problem on by this Monday and are still hearing some noises. They are still diagnosing the car and I have not heard anything else since Monday. Now you got me worried.
