drop only the front side?
Old Oct 20, 2005 | 09:20 PM
danger300z's Avatar
Today at work i saw a 350z lower only the front side . Im now wondering how does our maxe's look only lower on the front . Has anyone of you guys done it ? DO they only sell the front aftermarket struts or they only sell all 4 of them?
Old Oct 21, 2005 | 03:39 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
my car is only drop in the front. It is fine and no problems at all..... I have to do the rear soon but cannot remove one of the screws ib the rear. wik have to take it to a mech..so they can loose the screww(bolt that holds the strut........with the suspension... they will sell only two f that what you need..... check on ebay
Old Oct 21, 2005 | 08:10 AM
danger300z's Avatar
i saw your domain great write up
Old Oct 21, 2005 | 08:31 AM
icelandmaxima's Avatar
Maxima Fanatic
I have coilovers and I lowered the front more than the rear for a little more of an aggressive stance and I think it looks pretty good. Its noticeable that the front is lower but you cant get a really aggressive stance because you would need to go really really low to get the look and in-time the cv would wear so it wouldn’t be worth it. I think the rear definitely needs to be lowered to get rid of that huge wheel gap so it doesn’t give you too much to work with.
Old Oct 21, 2005 | 08:33 AM
UGAd13's Avatar
H&R front only drop. I dropped the rear later on and think it looks a lot better. I'm on stock struts for now and the ride is fine since it is a mild drop. There are some threads out there if you want to search back a ways.
if pic doesn't work it's cardomains fault.
Old Oct 21, 2005 | 08:56 AM
danger300z's Avatar
I like it , thats a pic i wanted to see
Old Oct 21, 2005 | 09:02 AM
eyecon7's Avatar
i think you should get a drop all around
Old Oct 21, 2005 | 10:42 AM
ColdSHO's Avatar
depends on the springs used, its better to match the spring rates, if u dont u could have a max with funky(or even worse unpredictable) handling which could cause unwanted under or oversteer. and may lead to an accident in extreme circumstances.
throw on a set of maxspeeds up front and id think it would be fine, s-techs on the other hand i think would make it handle awkward.
i did the same thing as icelandmaxima. no regrets, the max looks awesopem witht he front end a lil lower then the back, looks like its ready to attack or soemthing, i juts added my rear spacers, now she looks really mean.
boomerbrian
Nov 8, 2015 05:10 PM
homeyclaus
Sep 3, 2015 06:15 PM
Balkins
Aug 12, 2015 06:39 AM
BassAddictJ
Aug 4, 2015 11:38 AM
