My Hotshot header install experience (20 pictures, 4.38mb)
Old Oct 24, 2005 | 06:10 PM
  #41
fishpony's Avatar
great pics. headers are next on my list, hopefully within 6 months. also curious as to what everyone is going to tune with.
Old Oct 24, 2005 | 06:25 PM
  #42
Luquire's Avatar
I have always wanted headers but i think for a few extra hundred dollars i could throw in a 3.5 in my car.
Old Oct 24, 2005 | 06:47 PM
  #43
BlackBIRDVQ's Avatar
drag racing is for wussies
Originally Posted by sloppymax
now time for a dyno. not just for the power increase but to figure out your a/f. i felt pretty big gains after my headers but found my a/f was running in the 11s after 4k rpms after the headers. with the y pipe that was on before, it was 13.5 across the board. it seems most 3.5s could use an afc or whichever piggyback to cure the a/f with them stock and after headers it seems to worsen.
I guess every car is diff as far as A/F goes, mine with headers and every bolt on stays at bout 13.4:1 on my wideband with no corrections what so ever. ECU will adjust gradually over time to a good ALPHA reading- Nissan language for short/long trim fuel ratios. I am not sure how it is on a 3.5L, but my 3.0L makes pretty good power with no adjustments needed- I need to adjust the timing to make full power, but with my current engine build up on my Q45 spending thousands of dollars every week, TS ECU with custom maps will have to wait till I have a car to drive around while the ECU is out at TS.
Old Oct 24, 2005 | 08:33 PM
  #44
whazzzzuup's Avatar
So like someone stated before, the car will get faster over the week. Is that due to the gradual fuel adjustment?
Old Oct 24, 2005 | 08:55 PM
  #45
Yes its due to ECUs self-learn procedure, I am not sure if the AF will be re-adjusted by the ECU or not on the 3.5L. Its would be nice to see how the AF is affected NOW till when it re-adjusts 2-3 weeks from now. Best bet would be to have a wideband installed durring a dyno few weeks from now, that way you will know if its in need of a AF tune. Like sloppymax said, his AF was all wacked on his 3.0L, yet mine is rock solid and I never adjusted it since the headers, since it makes best power at my 13.4:1 AF. Like I said every car reacts differently, there are no 2 cars alike out there- just like humans.
Old Nov 7, 2005 | 10:50 AM
  #46
Nismo3112's Avatar
Custom User Title
In the 8th pic it looks like your radiator is busted?????
Man those look good.
Old Nov 7, 2005 | 11:12 AM
  #47
whazzzzuup's Avatar
Yes, it does look like that, but it's not. When I pulled the upper radiator hose to remove the radiator fans, some coolant came out.
Old Nov 7, 2005 | 01:24 PM
  #48
00MaxSE's Avatar
Pointy Elbows
Wow those things are hot! I need to do this. Maybe after I find a job.
Old Nov 8, 2005 | 03:12 PM
  #49
vsamoylov
nice headers. now where is the dyno and how do they hold up to the cattman gen 2 in terms of #s? and how is fitment? if hs produce the same power and fit perfect, i buy them instead of the cattman.
Old Nov 8, 2005 | 06:32 PM
  #50
Puppetmaster's Avatar
Take a look at the other thread on Hotshot headers by JasonB-something.... Tilley did the install and they did have a couple issues with the Hotshots. Starchild also had his installed and posted his comments.
Old Nov 8, 2005 | 06:43 PM
  #51
whazzzzuup's Avatar
I don't know about the horsepower gains versus the Cattman headers, but I know fitment is very good on my Hotshots. The only negative thing (not that bad) that I have to say about Hotshot is the gasket they supply for the y-pipe and cat connection is not good. It goes bad almost instantly. Other than that, I am very satisfied in terms of fitment.
Old Nov 8, 2005 | 06:48 PM
  #52
vsamoylov
but is the fitment like that on all their headers? or is there some that installation is not perfect? and yeah i am still itnerested in your ssrs.
Old Nov 8, 2005 | 07:12 PM
  #53
fishpony's Avatar
dont know if this was posted but where did you buy your headers from? I just looked on sportcompactonly.com and they aren't on there anymore. Anyone know whats going on?
Old Nov 8, 2005 | 07:16 PM
  #54
You can get em from SCO... just call Steve G. You can also get em directly from Hotshot.
Old Nov 8, 2005 | 08:11 PM
  #55
Nismo3112's Avatar
Custom User Title
Can't wait till mine come in
VQ'ed
69
Aug 27, 2020 12:29 PM
Cotozic
Jun 28, 2017 08:01 PM
ac max 92
Sep 2, 2015 04:23 PM
FanaticMadMax
Aug 10, 2015 08:55 PM
mikekay
Aug 10, 2015 12:52 PM
