Windshield washer nozzle failure?
Old Oct 29, 2005 | 12:07 PM
steven88's Avatar
Need A Light?
Hey guys, recently my windshield washer sprayer started to shoot out fluid very slowly/weakly...before when I pull back on the handle, it sprays evenly with a strong burst....now it barely comes out and this kinda worried me....so I examine the nozzles to see if they were clogged...since I know its a common problem...to my suprise, they were fine...I tried pulling out the nozzle itself to examine the whole unit...it's fine
I have a feeling its the actual pump thats about to give out.....has this happened to anybody? If so, how much was the pump?
Old Oct 29, 2005 | 12:10 PM
Wills98MaxSE's Avatar
1 of few unmodded 4G Maxs
dumb ?, but do you have washer fluid in the reservoir? If its full, sounds like you either have a clog somewhere in the washer fluid lines, or as your 1st hunch is, the pump is going bad.
Old Oct 29, 2005 | 12:12 PM
steven88's Avatar
Need A Light?
haha good thing you pointed it out....YES i do have fluid....as a matter of fact...when my car started to experience this symptom, one of my first solutions was to refill more fluid (on top of examining the unit itself)
Old Oct 29, 2005 | 12:29 PM
E55AMG2's Avatar
Wat
Make sure your FSTB isnt pinching the lines
Old Oct 29, 2005 | 12:35 PM
foodmanry's Avatar
Da Roller Coaster!
That is a common problem on the 5th and 5.5 gens with a FSTB. I had to re-route my windshield washer line to ultimately fix the problem.
Old Oct 29, 2005 | 12:43 PM
steven88's Avatar
Need A Light?
Thanks! I will check out the problem right now
Old Oct 31, 2005 | 12:32 AM
steven88's Avatar
Need A Light?
I just took apart my FSTB....and double checked the nozzles for anything abnormal...it still sprays out the same...oh well, I'm going to conclude it to be a weak pump...hopefully it doesn't fail anytime soon...
thanks for the tip e55
Old Oct 31, 2005 | 02:55 PM
irish44j's Avatar
retired moderator
if you replace the nozzles, get new ones from a Murano...they spray in a nice "fan" pattern and fit in our hoods with only a small adjustment
Old Oct 31, 2005 | 03:14 PM
TPenguin's Avatar
Got Penguin?
What sort of adjustment needs to be made, i would love to get a spray instead of a stream. Also what year murano? Thanks for the help...
Old Oct 31, 2005 | 03:24 PM
irish44j's Avatar
retired moderator
I think mine were from a first year Murano, whatever that was. The only thing you hvae to do is use a file or dremel to shave down a little tab on them, and they will fit right in
Old Oct 31, 2005 | 05:20 PM
steven88's Avatar
Need A Light?
thanks for the tip josh...
how much are they btw? well I shouldn't really be askin this cuz even if I got them, it would still spray weakly...i think my main concern is the PUMP failing on me....
Old Oct 31, 2005 | 05:48 PM
irish44j's Avatar
retired moderator
i think they were like 7 bucks each from the dealer....had to be special ordered.
find a Junked Murano and take them off it...
BkGreen97
Apr 2, 2016 05:47 AM
02PearlSE
Feb 1, 2016 12:37 AM
Excalibur23
Oct 13, 2015 04:33 PM
The Wizard
24
Oct 1, 2015 08:47 PM
ac max 92
Sep 17, 2015 07:35 AM
