Vacuum sounding when starting car
So I turned on the car and it's sounds like a vacuum turning on for like a second.. I'm not liking it at all but I got a feeling it has to do with the cold weather... it sounds like it's right at the engine bay or around the MAF area... I'm planning to get a new MAF here soon anways so hopefully some of my other problems can be solved but another one pops up like always... any help to what the problem could be would be helpful.. Thanks!!!
it only happens when i start the engine... sounds like something is twirling inside.... not sure... not even sure what i can do... it goes away after 3 or 4 starts and warming the car...
I sorta have the same sound when mines cold too. I start it, the RPMS go up to like 2-3k, then they dip back down a little bit, and when it does that it makes this little....well....farting sound is the only way i know of to describe it. It only last for maybe....1 second at the very most. I don't know what it is. Checked my codes and am gettin a 0021 which is IVT....no CEL light yet, but the code is there. Any suggestions? Thanks!
Also, do you have to interpret the code or anything that you get when you do the ghetto check code method? The turnin the key and hittin the pedal. Like where the CEL light will flash fast, 10 times, then slow 10 times, then twice, then once?
Yeah, I am getting the same problem with my car (00 max 5 spd), sometimes even after it has warmed up completely. I used to think it was the cold, but it used to do it once in a while in the summer as well, even after I took off the CAI. I think a whirring noise that lasts about a second or more is a pretty accurate description. The noise has me and my mechanic totally puzzled. Any ideas would be much appreciated.
no, its not a whirring noise, its more like a.......farting noise. When i start, it revs up to around 2,000 rpms. Then it makes the noise when it drops back down to little bit over 1,100 rpms.
Originally Posted by BewstAdd1ct
ghetto check code method? yes thats an 0021
zero, probably just the intake. is it a sucking noise or a whirring noise or what? does it have a whistle to it?
does your car have a cranking problem, I mean does it start on the initial key turn? I had a sucking sound just recently, but my problem was my battery's CCA (Cold Cranking Amps) was tested at 130CCA a new battery is like 650CCA. The problem (sound) would happen when I would try to start the car but it would take 3 or 4 cranks of the key to get it started, but on the first crank it would make this "whoomp" sound, like a vacuum sucking. Replaced the battery and no sound. Just a thought.
Lakersallday24
06-16-2019 01:35 AM
kjlouis
11-24-2018 06:09 AM
MaximaDrvr
08-19-2015 08:20 PM
