Paint Match Question
Old Nov 2, 2005 | 10:17 PM
Kruppa's Avatar
I've had some trouble in the past with rear bumper cover paint matching the rest of the car ... and I've noticed most Stillen body kits (except darker colors) along with mine are brigher than the rest of the paint, but i assume that has to do with the polyeurothane material...
I found a great article that explains the difficulty in matching, especially plastic bumper cover... http://www.autobodysupply.net/auto-p...olor-Match.htm
This part is most interesting...
"Most car manufacturers have three major paint suppliers. The manufacturer decides on a standard color for production and submits a painted sample to their suppliers. The paint manufacturer then produces a formula for the “standard sample” and is allowed a tolerance of plus or minus 5% when they deliver the paint.
This is the first problem because the plant in the east coast may be getting a 5% shade greener on a blue metallic standard and the plant in the west coast may be getting a 5% shade violet on the same blue metallic standard. When compared side by side, they look like a completely different color."
Does anybody know if there is a way with your VIN number or production date that you could figure out the percentage of green/violet etc in our paint (mine is sterling mist to be specific)? Just wondering if that was possible because it seems to be the only way to get a correct match because otherwise its a total guess without blending which is lots of money. Thanks guys.
Old Nov 3, 2005 | 03:52 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
You will have two options..
1. Blend the paint
2. Paint the entire car
that's it.... nothing more , nothing else......
Old Nov 3, 2005 | 05:42 AM
MIXXMAX's Avatar
1. Blend the paint
Like Lonar said, whenever painting ABS plastic parts, the best way to get a match is to blend the paint around the surrounding areas where it's installed. For example, getting the front bumper painted, blend the hood also. This will make the naked eye see as a matching color. Another factor is that it also depends on the color of the car, too. Some complex colors are hard to blend when re-painted, i.e. Pearl White or Icelandic!
Old Nov 3, 2005 | 05:46 AM
Mizike's Avatar
Blending is the way to go. It is definately more expensive compared to getting individual pieces painted, but the results are going to be what youre looking for. Good luck.
Old Nov 3, 2005 | 06:54 AM
MaximaPolak's Avatar
Paint the entire car a fluorescent pink. That will fix your paint matching problem.
Old Nov 3, 2005 | 07:54 AM
Kruppa's Avatar
i WILL beat you if you ever come back into the great state of MA again
Old Nov 3, 2005 | 02:05 PM
BRAN808's Avatar
Even if you were to repaint the whole front clip, the front bumper would still appear a little different shade. It's because of the material being painted. It should not be a complete different shade, but there will probably be at least a little difference.
Kingofmaximas24
Nov 12, 2015 04:40 PM
pears
Sep 18, 2015 05:25 AM
minsbang
Sep 11, 2015 08:48 PM
TheMafia
Sep 4, 2015 08:26 AM
