AE Accelerator on non AE models...
I was able to install just the pads on mine. Others have reported their car needed to have the accelerator replaced. It depends on if your car is an early or late 2000 production.
The way you can tell if you can just slap on the pad is to look behind the gas pedal. If there is a squarish metal bracket back there, then you have to cut the bracket or get the new accerelator. Mine did not have this, so I was able to apply the pad with a little tweaking.
No pictures available. But if you search back about 6 months ago, I did a post about it.
just any local parts shop will do. mine is auto and I got both plates for 42 dollars. A lot of sites dun carry razor but momo or watever. I am planning on getting the foot rest plate...but u have to drill it into the floor.
btw, u might wanna get a smaller brake pedal since the 2 pedals are close to each other(auto). I have small on both pedals.
Originally posted by DooBall
anyone know a good site (cheap place) to get the razo pedals... ebay doesnt have any, their all manual and/or doesnt fit maxima!
The only notes I have are from when I posted a thread here on maxima.org: I did not have a digital camera at install time so all knowledge was captured in my brain (a small one) or in the post on maxima.org. I guess this falls in line with the knowledge of the Egyptians.
One thing I do not know the answer to is how Razo pedals work, but the AE pedal on an early 2000 Maxima (without the square metal bracket on the back side of the accelerator pedal work) do not work.
They should be the same in regards to install procedure.
PM me if you want more info about whether or not your application is a, pretty much, plug-n-play situation or you need to swap out the accelerator pedal assembly.
They should be the same in regards to install procedure.PM me if you want more info about whether or not your application is a, pretty much, plug-n-play situation or you need to swap out the accelerator pedal assembly.
DooBall - since you have a 2001, it should be easy for you.
Need help
23
Oct 2, 2015 08:56 AM
