Manual trans.... shifter really hard to move in neutral position............
Old Nov 4, 2005 | 02:27 PM
NYCe MaXiMa's Avatar
I can no longer easily move it back and forth when it's in neutral. It's kind of just stuck there dead in the center and i can jerk it back and forth but it takes a lot of effort..
i can still go into gears fine.. its just harder to move it......
is there some kind of spring or linkage problem that this is related to ? any ideas?
thanks
Old Nov 4, 2005 | 02:43 PM
Puppetmaster's Avatar
Have ya checked all the bushings? Btw, what year Max is it? I'm assuming 00-01....
Old Nov 4, 2005 | 03:25 PM
2000
which bushings should i be checking?
Old Nov 4, 2005 | 04:02 PM
ChromeSE5's Avatar
Like do you really have to push hard to get it into gears? I had that happen to my 2000 and it turned out to be my slave clutch but problems may vary.
Old Nov 6, 2005 | 11:03 AM
its not any harder to get into gears... all i'm talking about is the lack of free play in the shifter in the neutral position... may seem minor but it's annoying... it's really tight...
i just took off all the shields on the underbody to get a better look.. thinking maybe the spring ripped but it's fine. it has something to do with the linkage...
any more ideas?
Old Nov 10, 2005 | 06:51 PM
anyone else?
Old Nov 12, 2005 | 11:27 AM
BewstAdd1ct's Avatar
make sure the shift control rod isnt rubbing on anything. you might try disconnecting it and using a screwdriver at the trans to move side to side and see if you get the same drag.
also remove the shifter boot and see if any pivots and whatnot need lubrication.
Old Nov 13, 2005 | 05:49 PM
moneybags's Avatar
LUBRICATE EVERYTHING. oh it feels so good...
Old Nov 13, 2005 | 06:22 PM
NO... dont lubricate that...
Old Nov 17, 2005 | 08:34 AM
Thanks, yeah.. i am going to disconnect the linkage from the front and see if it still moves the same way.
Old Nov 17, 2005 | 10:00 AM
Originally Posted by NYCe MaXiMa
2000
I was actually thinking about an experience from my 02, so it may or may not apply. Well, there are bushings at the end of the shift control rod, but I'm not sure if those will cause what you're describing.
Like Bewst said, check the shift control rod components and maybe even the shift lever/stalk because I believe that there is a bearing at the bottom of that that may influence motion.
shilov
Feb 19, 2024 09:40 PM
Mar 12, 2020 12:06 AM
James92SE
Oct 8, 2015 04:57 PM
Lilfatz301
Sep 18, 2015 08:06 AM
ik95
Sep 16, 2015 08:11 PM
