so called hp chip?
Old Nov 5, 2005 | 07:35 AM
imported_black_tl's Avatar
so called hp chip?
on ebay I keep seeing this so called chip you can put in you car and it will give you up to 20hp. my only question is if it can give a car that much more power then why only sell it for 6-7 dollars.
"uses a resistance value of 3,700 ohms to override the sensor and signal the computer that it is receiving air at an optimal temperature of 60 degrees."
does anyone know about this? it says it only takes about five minutes to install and will not harm the car at all. says it will work with intakes and such. a little feedback would help...
Old Nov 5, 2005 | 07:37 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
IByougetflamed.
Did you REALLY think it would work?
Use some common-sense, my friend.
Old Nov 5, 2005 | 07:44 AM
what i'm thinking is that it is just another try to get rich quick idea. i haven't seen any results nor did i buy this.
Old Nov 5, 2005 | 07:48 AM
Then you did the right thing.
[/THREAD]
Old Nov 5, 2005 | 08:12 AM
DonGfun's Avatar
VW = 30 MPG
Or Get it, try it for like $10 and let us know if it works. ($10 is like 2 cups of coffee)
Old Nov 5, 2005 | 08:28 AM
BkMaxima2004's Avatar
$10 2 cups of coffe maybe in like starbucks, on the street from the guys in their little wagons, thats like 10 cups of coffe.
Old Nov 5, 2005 | 09:00 AM
chr0nos's Avatar
damn, starbucks is about $2.00 for a large cup here. thats 5 cups of coffe. i would not waste a whole work-week worth of cofee for a fake chip.
Old Nov 5, 2005 | 05:44 PM
JD2k2's Avatar
Maybe I should go into the coffee business
Old Nov 5, 2005 | 05:51 PM
Army of Maxima's Avatar
Looking for a few good Maximas
It isn't a chip, it is actually a RESISTOR. And all it does is hook up to your air temperature piece to allow the engine to run like it is receiving cold air all of the time.
It is a POS that someone is making buck$$ off of.
Old Nov 5, 2005 | 06:43 PM
paralyse's Avatar
I Miss My Maxima
To save you the trouble, it doesn't work.
You can achieve the same results by modifying your IAT sensor or coolant-temp to read low all the time. This forces the computer to stay in cold-start mode, which runs the engine rather rich to light off the pre-cats and cats faster for emissions. That's why your car has more get up and go when the engine is cold, and why the exhaust "smells" more strongly.
Continued running of your car in this mode may make you feel like you've got more power, but it will also destroy your cats in a hurry, and you won't be able to pass any emissions tests.
Old Nov 5, 2005 | 08:35 PM
silvermax2k2's Avatar
O.........M.........G
Old Nov 5, 2005 | 08:56 PM
rbrown81's Avatar
But why is teh Rum gone?
Sounds like junk!
Apr 16, 2020 05:15 AM
doctorpullit
Apr 23, 2017 05:35 AM
D Mason
Jun 21, 2016 04:43 AM
bigfrank
Oct 1, 2015 12:51 PM
Dasmith
Sep 23, 2015 08:28 PM
