O2 Simulator problems
Old Nov 7, 2005 | 05:06 PM
harmbone2k2's Avatar
6yrs old=36,500 miles :)
I have had the dual output simulator installed for about 5 months now. I thought all was well until a couple days ago when the SES light decided to make its presence once again. I know it is hooked up correctly and I have yet to get to Autozone to see what code is present. So, if anyone else has this, I hope you have better luck than me.
Old Nov 7, 2005 | 05:09 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
might want to make sure it is not a heater error which the simulator has nothing to do with. i got a heater error after about 3 months after the simulator was installed. my inspection is up so i plan on using the resistor to mock the heater signal as described on their site.
Old Nov 7, 2005 | 07:19 PM
Larrio's Avatar
The Definitive AE Master
The first one I ever bought was defective, which took awhile to figure out. You can use a multimeter and test to see the voltage emitted from the white signal wire. It should oscillate between 0 to at least 0.6V which is the minimum voltage that the ECU will look for that registers a working secondary sensor.
Or it might just be what sloppymax described.
Old Nov 7, 2005 | 08:27 PM
Epacy's Avatar
Unsuccesful STL Coordinator
I checked mine tonight and it did oscillate between those values. Didn't fluctuate nearly as much as the "real" installed sensors.
Old Nov 7, 2005 | 09:55 PM
Maximized Jiggs's Avatar
Hey while we are on this topic, my mechanic installed an O2 simulator on the seconday O2 sensor but the CEL came back on for P0420. There is only one secondary O2 sensor on the fed spec max right?
Old Nov 7, 2005 | 10:22 PM
steven88's Avatar
Need A Light?
Why would u say its related to the o2 simulator if u haven't pulled the codes yet?
Go get them checked out at autozone and report back with the #s...then we will be able to help diagnose it further
Old Nov 8, 2005 | 03:50 PM
I will do.
user 11122324
42
Jul 18, 2022 03:35 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
zmcneely13
Sep 26, 2015 02:26 PM
Noela
Sep 26, 2015 08:22 AM
