aksed my dealer about timing advance
I have a P0420 code that I need TSB done for. I also asked about doing a timing advance. Service guy said they will not do that, that they leave everything as factory set, due to some liability issues.
I will try another dealer, but it's 30 minutes away.
dont talk to the service manager or do it "on the record"
when i got mine done i talked directly to a service tech when he went out to get another car. gave him $50 and he did it. both of us won.
josh (irish44j) and I got our's done at the same time)
like sooner said, just find a tech out taking a smoke and slip him some cash to do it real quick....
make sure to bring the programming instructions (posted here someplace) to show him when he tries to say "I don't know how to do that" etc etc...
Originally Posted by NYPD-Arnold
I've noticed that on 3.0L 5th gens, BTDC @ 17 gives an incredible surge of power. On the 3.5L 5th gens not so much.
though, "incredible" might be a bit strong of a word
Originally Posted by dennisuello
anyone has a link to instructions?
http://forums.maxima.org/showthread....timing+advance
Originally Posted by irish44j
that is the impression when me (3.0) and sooonerfan (3.5) had when we got ours done at the same time.
Shame that the 3.5s don't experience this as much as we do.
Instructions:
http://forums.maxima.org/showpost.ph...90&postcount=1
Sometimes I like to credit myself for helping to really bring the timing advance craze to the masses. I've gotten well over 200 PMs asking me about it and where to get it done.
Originally Posted by soonerfan
no..................
oh and two more questions:
Does the fuel economy decrease?
How much extra HP do you get from this on VQ30?
For the time I’ve been a member it was not discussed for sure. Besides, it’ll take at least 20 minutes for me to find this info and someone who knows it can type it in 20 seconds…
So if someone knows the answers to my previous post please let me know.
i just did a search and there have been 10 threads since jun 05 (when you joined) that answers your question
20 minutes to find the answer
or
30 seconds to donate then 30 seconds to search
or
Anyways it’s up to you…not you, then someone else
Or 20 seconds of your time (which you have just spent anyways) to save me $25…
in this case, could someone explain how it works?
Fuel economy actually increases as long as you only use 91/93 octane. But you probably won't see much of an increase since you'll likely develop a heavier foot from always wanting to feel the increased surge of power -- I know I did.
On 3.5Ls it doesn't make much of a difference because of how the 3.5L was designed. 3.5Ls are more prone to engine knock from low grade octanes than the 3.0Ls, which might mean that they're already running a certain timing that'll create knock easier. 3.0Ls will require a lot more abuse and poor octane to begin knocking.
Err...I guess if I'm not coming off clear, let's put it this way: the 3.5Ls 15-degrees is like a 3.0Ls 17-degrees. So when 3.5Ls are advanced it doesn't do much for them, because they're already built from the factory to spark quicker/early, where as 3.0Ls have to be advanced to do this. This is what I was told previously by a Nissan technician. It sort of makes sense* once you begin to consider the frequent engine knock issues people have with their 3.5s.
*Edit: I have NO idea how I wrote "noise" instead of "sense".
they seemed to be talking about it a lot back in 2002 already. http://forums.maxima.org/showthread....advance+timing
Basically, when advancing timing you're advancing the point at which spark is created. The earlier the spark, the quicker the power is made and put down to the wheels -- this is also called "Before Top Dead Center" or BTDC. As far as HP increases, it's around the neighborhood of ~5HP per degree -- though this is open for debate.
Err...I guess if I'm not coming off clear, let's put it this way: the 3.5Ls 15-degrees is like a 3.0Ls 17-degrees. So when 3.5Ls are advanced it doesn't do much for them, because they're already built from the factory to spark quicker/early, where as 3.0Ls have to be advanced to do this. This is what I was told previously by a Nissan technician. It sort of makes noise once you begin to consider the frequent engine knock issues people have with their 3.5s.
http://www.howstuffworks.com/ignition-system1.htm
http://forums.maxima.org/showpost.ph...9&postcount=20
People need to flippin search.... use the Google, donate, or just read through the old threads.
/thread
/thread
/thread
/thread
/thread
/thread
Starrider
Sep 17, 2015 07:26 AM
