Wierd
Old Nov 17, 2005 | 09:10 AM
boondoxmax's Avatar
Wierd
I've had a clunking noise from the left side of my car only over deep dips. Got the car aligned the other day and the clunking noise went away and everything was nice and tight. Over the last couple of days the noise is starting to come back. Any idea what it could be....HELP. I am thinking the sway bar ends but what does that have to do with an alignment.
Old Nov 17, 2005 | 11:27 AM
boondoxmax's Avatar
Can some explain to me what bolts are used to adjust the front wheels when doing an alignment. I am wondering if they can come loose and cause clunking over bumps
Old Nov 17, 2005 | 12:26 PM
igzy's Avatar
I Know Kwaliti
Yeah... I have this problem too and when I posted about it some months ago I was told not to worry about it, something to do with some plastic piece underneath making noise and that does not really matter... I have been driving with it for a loooong time now and only notice it when I climb my driveway... Though you could make sure it is not your strut mounts, suspension, ball joints, bearings, control arms, tie rod, etc... But if they have not reported anything during the aligment, you should be fine
Old Nov 17, 2005 | 12:32 PM
boondoxmax's Avatar
Yeah no problem reported during alignment. Just seems wierd how the noise went away after the alignment and now resurfaces as time goes on.
Old Nov 17, 2005 | 12:39 PM
AcerX's Avatar
Don't you guys know about the Noise Fairy? She is the same one who changes our radio stations every now and then.
Old Nov 17, 2005 | 12:50 PM
igzy's Avatar
I Know Kwaliti
My noise fairy comes once in a while too then she disappears for a while, then she comes back... Oh, well, doesn't bother me... I can understand your frustration though
Sometime ago I read somewhere that 30% contributor to stress (2nd or 3rd highest) in males is unusual noise from the car... Go figure...
Old Nov 17, 2005 | 01:18 PM
Matt's00MAX's Avatar
yea i can see that because my car makes the clunking noise and a squeling noise from the belts and it really pis*es me off.
Old Nov 18, 2005 | 06:18 AM
igzy's Avatar
I Know Kwaliti
Belts you can change or adjust the tension to eliminate that noise...
Old Nov 18, 2005 | 10:00 AM
boondoxmax's Avatar
I don't think its any plastic hitting anything cause when alignment done= no noise. Drive car for a week and now noise is slowly returning. Time for swaybar ends to be replaced i guess to see if it solves problem.
Old Nov 18, 2005 | 10:17 AM
igzy's Avatar
I Know Kwaliti
Sway bar ends were one of the suggestions when I inquired about it... It does not bother me so will leave it for now... Besides I am trying for fix some other probs with my car that I will need to spend time and money on before I will try to get rid of the noise... Nevertheless, let us know how it went with the replacement and if it had solved the problem...
Old Nov 18, 2005 | 05:40 PM
tsk808's Avatar
try having your shocks inspected. maybe they're worn out?
Old Nov 19, 2005 | 03:02 PM
boondoxmax's Avatar
shocks are only 2-3 months old. Just had HP installed
Lakersallday24
Jun 16, 2019 01:35 AM
patel_anu
Dec 7, 2001 04:57 PM
MaDMaX024
Nov 3, 2001 11:02 AM
BriGuyMax
Oct 30, 2001 07:19 PM
mykizism
Sep 13, 2001 05:29 AM
