Window Problems??
Old Nov 17, 2005 | 02:53 PM
misiek's Avatar
Window Problems??
For some reason when you press the AUTO-UP button for the passenger window, the window goes all the way up and than slides down 2 inches... this is when you press either drive or pass button...
Any ideas what this can be?
Old Nov 17, 2005 | 06:45 PM
BewstAdd1ct's Avatar
hello,
please utilize the ******* SEARCH FUNCTION
j/k
no, but seriously. search.
usually the window needs to be reset, in some instances the regulator needs to be replaced.
theres a button on the window motor, raise the window all the way, press and hold the button and lower the window. release the button and raise the window again. dont use the auto function during the procedure, use the normal momentary switch.
you might be able to see the button after removing the window switch plate...
pears
Sep 18, 2015 05:25 AM
thenewguyy
Sep 12, 2015 11:12 AM
markevans999
Sep 10, 2015 04:29 PM
ef9
Sep 5, 2015 11:18 PM
