HELP!!! With fog light re-wire
Old Nov 18, 2005 | 02:33 PM
n3985's Avatar
大陆弟弟
I tried to re-wire my fogs today according to housecor's instructions. But I can't get the corner tabs out by the wheel side. His instructions say to use something small and pointed to push out the tabs, and I did. When I pushed it in, I can feel and sorta see a tab being pushed to the side. But it won't give!!! How did you guys do it? Thanks!
Old Nov 18, 2005 | 03:14 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
push it in and pull it up.... that's it...
Old Nov 18, 2005 | 03:21 PM
Lethal's Avatar
When I rewired my fogs I ended up just breaking that tab. I tried for about 5min to be nice to it....then I just had enough and broke it off.
Old Nov 18, 2005 | 03:45 PM
n3985's Avatar
大陆弟弟
I did push in and try to pull it up, to no avail. It seems that even if I was to get one corner out, the middle 2 tabs and the other corner is still holding it down.
Old Nov 18, 2005 | 04:03 PM
SoonerFan's Avatar
Cletus
you are talking about the fuse box tabs right?
Old Nov 18, 2005 | 04:16 PM
Lontar1's Avatar
do it agai... push it in and pull just a bit... try using sanothe screwdriver to keep it up while you do the other corner.. and patience my friend...
Old Nov 18, 2005 | 04:42 PM
n3985's Avatar
大陆弟弟
Haha patience, I tried that sh*t for like 30min. OK, will try again tomorrow. So just to clarify:
For corner tabs, use small tool to just push in while pulling on the fuse box right?
Old Nov 18, 2005 | 05:41 PM
misiek's Avatar
Take out your fuse box cover and stick your hand up there and push out...
Old Nov 18, 2005 | 06:26 PM
BewstAdd1ct's Avatar
i just wired mine to IGN power, theyll come on whenever i want wiht the switch, as long as i have the key on.
no breaking of tabs, or anything, either.
hmm, maybe i should do a write up on it.
Old Nov 19, 2005 | 12:29 PM
n3985's Avatar
大陆弟弟
OK I got it done! I guess the difficulty I was having was because yesterday the weather was low 30s and the plastic might've been really hard. But today after doing some errands, I tried again and the corner tabs pushed out easily.
So note to future fog light re-wire peeps, do it in hot weather or when engine bay is warm.
Old Nov 19, 2005 | 10:43 PM
makdaddy386's Avatar
Check signature for my new write-up. Pretty simple to understand and lots of pics.
Old Nov 20, 2005 | 12:19 AM
steven88's Avatar
Need A Light?
Hey kevin...in your procedure, I see that your foglights are coming on without the corners in one of the pictures....I know that housecor's website and a few other write-ups require your corner lights to be on with the fogs....is yours the only procedure that allows you to turn on your fogs without any corners?
Old Nov 20, 2005 | 12:52 AM
i know that it can be done other ways but mine can def run without markers
Old Nov 20, 2005 | 09:00 AM
steven88's Avatar
Need A Light?
sweet...I think i'mma run it your way since I don't have to turn on the corner lamps...My old maxima had the foglight rewire mod, but they were wired up to my corner lamps...
Old Nov 20, 2005 | 11:09 AM
glad to help
The Frye
Sep 2, 2021 11:03 AM
fastcarny
Oct 6, 2015 10:42 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
