O2 Sensor problems....
Old Nov 20, 2005 | 10:12 PM
Maximized Jiggs's Avatar
Hey guys, I posted a while back that my gf's 2000 GLE with 100k miles had the P0420 code. So after reading posts, I decided to buy an O2 simulator so it would pass the inspection. I was told by my mechanic that I need an additonal O2 simulator as there was another secondary O2 sensor. I thought my gf's max was Fed spec but apparantely its not, when I checked there were 4 connetions for the O2 sockets in front of the engine (can any one confirm thats the right way?) After checking the FAQ's I believe if #3 and #4 are the only ones in place then its FED spec, other wise its Cali spec (all 4 have connections).
So now after the ECU reset, the light came back on for P0138 and P0139. I thought the O2 simulators would get rid of the O2 sensor codes all together but it hasnt. Now I want to know whether the O2 simulators are working as they should or they are not installed right some how. I dont have a problem replacing both of the O2 sensors as her car is over due for inspection. Any one have ideas of what to do and what to look for? Should I replace both of the secondary 02 sensors and hope the ECU falls asleep finally?
I am happy that the P0420 code went away but now we are facing 2 new codes.
Old Nov 21, 2005 | 04:16 AM
nicks79's Avatar
What if you reset ECu, and go get inspection done? Is there a way for them to know you had the code before, but once you reset it , it clears out??? I have the same issue with P0430. I need inspection next month, so if I just unplug battery and then drive for about 100 miles and go for inspection, cause usualy light comes on in about 200-250 miles.
Old Nov 21, 2005 | 08:23 AM
shabo99's Avatar
Unplugging/resetting the ECU just before going for inspection, the vehicle will not pass. The status will be "NOT READY" The ECU takes a while to reset driving around with a mix of highway and city driving.
Os Sensor problem: Please see link below...it helped me
http://forums.maxima.org/showthread....ight=simulator
Old Nov 21, 2005 | 09:49 AM
Well guys, autozone reset the light last night and this afternoon she took it in to get inspected and it passed!
So now lets see if the light comes on again, if it does then I will have to do with the same issue next year.
Old Nov 21, 2005 | 10:25 AM
nicks79's Avatar
So this is opposite of what the dude from PHilly said above. I'll try that too, the problem here is local morons at autozone wont reset it for you - they say its illegal.
Old Nov 21, 2005 | 10:35 AM
Well dont reset it and go right away for the inspection, I would drive 50 to 70 miles atleast.
Old Dec 20, 2005 | 08:17 PM
RLLOGY805's Avatar
yeah i had a problems with that to just had the computer reprogramed or something, not to sure
Old Dec 21, 2005 | 12:45 PM
Gears & Crosses's Avatar
Ya I have O2 sensor problems also and I was thinking of doing the O2 simulators also. I have been really focused on my Mustangs lately. Has anyone else used O2 sims on a 5th gen? If so what brand?
Gears
Old Dec 21, 2005 | 02:18 PM
Puppetmaster's Avatar
Gears
Only one brand as far as I know... www.o2sim.com
And yeah, a bunch of people are using em.
TallTom
57
Oct 14, 2025 05:16 PM
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
