Vibration and thumping noise, please help.
Old Nov 21, 2005 | 07:57 AM
Whtmax'01's Avatar
Started driving this morning and thought i had a flat tire, checked the tires, they are all fine. The vibration feels exactly like a flat tire or a loose wheel and at higher speeds less evident. I checked if the wheels are bolted tight and they are. As soon as I stop the noise is gone, so it seems it is coming from wheels.
Could it be the wheel bearings or the transmission? There is no noise just a dull thumping feeling. Car brakes fine , no jerking when braking. I am lost as to what it can be?
Old Nov 21, 2005 | 09:05 AM
ColdSHO's Avatar
tires off balance, some times the weights they use to balance fall off. happens to me all the time. usually when its slippery out and i get tire spin.
Old Nov 21, 2005 | 01:39 PM
Whtmax'01's Avatar
Oh today i spoke to a friend and he told me it might be the worn out tires I have, i was meaning to replace them in a month anyways. So is it possible that worn out tires may make the flat tire sound ?
The sound is most apparent crusing around 25-35 mph.
Old Nov 21, 2005 | 01:55 PM
GBAUER's Avatar
Yep. If you have a flat spot or a broken belt, it'll thud like that.
Old Nov 21, 2005 | 02:02 PM
† ErV †
tires 90%
bearings 10%
Old Nov 21, 2005 | 02:04 PM
GBAUER's Avatar
Originally Posted by EvilRoadsVictim
tires 90%
bearings 10%
You giving an "over-under"? If so, I'll take $50 on the over! j/k
Old Dec 5, 2005 | 11:55 AM
lcf's Avatar
lcf
hey whtmax'01, i'm wondering if new tires fixed your vibration issues or not.
my 2000 se also has vibration issues. figuring it was the worn out cheapie tires i replaced them and the vibrations have not gone away. i thought the problem had something to do with the wheels because the frequency of the vibrations have a direct relationship to the speed of the car. my stock rims have some nasty roadrash from faring chicago winters but i never had issues like this before and i don't believe a bent rim could be the culprit. i'm clueless. the problem really came out of nowhere.
i really do not want to have to take it into the stealership to pay $80 to simply have them tell me what is wrong with the car... can someone tell me how to diagnose bad wheel bearings? i also have a set of jics to install but i want to make sure this problem is fixed first...
insights anyone?
Old Dec 5, 2005 | 12:28 PM
Whtmax'01's Avatar
Tires came in, but I'll mount them in 2 weeks. I' ll tell you if new tires helped as soon as they are on the car. So far, it is strange but that thumping noise went away as soon as i put more pressure into the tires, about 34psi all around. However on the highway some vibration does exist. I usually run 32psi all round, but maybe with worn out tires pressure has a greater effect.
Old Dec 5, 2005 | 01:01 PM
† ErV †
darn what you used to have in them? i am at 40 in mine i think... 33 feels like a sponge.
Old Dec 5, 2005 | 01:20 PM
Whtmax'01's Avatar
The max psi on my tires is 36 psi , so i dont want to go above that, and actually 3psi feels just right.
user 11122324
42
Jul 18, 2022 03:35 PM
D Mason
Jun 21, 2016 04:43 AM
Need help
23
Oct 2, 2015 08:56 AM
uttadms31
Sep 30, 2015 05:24 AM
