ecu flash?
Old Nov 23, 2005 | 06:14 AM
inspiredbykev's Avatar
You should thank my D***
ecu flash?
I have a 3.5l 6speed and I was thinking about sending out my ecu to get flashed by technosquare. I don't know whats better the MAXFLASH for $495 or the Limited Spec (L-SPEC) Flash for $345. Or is it not worth doing. Haven't seen any dynos on 6speeds and I know an auto did the max flash and didn't see an improvement when he dynoed. If I did decide to do this would I have to reprogram all of my keys at the dealer after the ecu is unplugged?
Should I just go with the apexi safc-II? If I went with this how easy is it to install? and do I need a harness? I seen them pretty cheap on ebay. This is much cheaper than going through the hassle of sending out my ecu.
The reason for all of this is because I plan on doing headers and I dont want my car to run to rich or lean.
Limited Spec (L-SPEC) Flash $345+shipping
Features
- 7100 Rev Limiter (500rpm Increase)
- Speed Limiter Removal
- Drive By Wire Re-mapping
- Stock Fuel, Timing and CVTCS map (no changes) <---- This is done by the MAXFLASH for an extra $150
Old Nov 23, 2005 | 08:35 AM
Larrio's Avatar
The Definitive AE Master
I'd try the headers and s-afc first and see how that goes for you.
The L-spec should be your last option (IMO) if you wanted to hit the track to take advantage of those extra rpms.
Old Nov 23, 2005 | 11:03 AM
2001SE's Avatar
The drive by wire remapping should def be felt at higher RPMS since it leaves the throttle plate open 100% throughout all the powerband instead of it closing up to 20% sometimes when you rev it up to redline
Get the L-spec but then get the s-afc done to make the maximum out of that reflash
Old Nov 23, 2005 | 12:37 PM
jerome johnson's Avatar
go with the s-afc. I got the reflash on my auto SE. I got no improvement in h.p. I actually lost some h.p. , biggest wast of $500
gigabyte
Jan 6, 2017 06:05 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
dshinn
Sep 26, 2015 08:07 PM
intimidator
Sep 5, 2015 07:23 PM
