I'm so tired of my aftermarket rotors warping
Old Nov 23, 2005 | 06:38 PM
steelymatt's Avatar
Hi,
1st try: Nissan Pads + Nissan Rotors -> Rotors warped
2nd try: Axxis Metal Masters + Brembo Rotors -> Rotors warped but amazing stopping power
3rd try: PBR metal pads + Brembo Rotors -> Rotors warped after 8000 miles
Has anyone found a pad/rotor combo that doesn't result in warping (uneven wear) but has excellent stopping power. I thought Brembo rotors weren't supposed to warp. I don't brake hard or often, a lot highway driving.
Old Nov 23, 2005 | 06:41 PM
Stardust's Avatar
F---ing Kangaroos
Hawk HPS pads > *
Old Nov 23, 2005 | 09:11 PM
filtor1's Avatar
I have had the same issue. I have replaced the stock rotors with Brembo slotted rotors and EBC Greens. This combo lasted the longest, about 18K. I am now on my second set of Brembo's, also slotted with the pbr ULT Ceramic pads. Been on now for 3K. I expect similar results. I believe the rotors are just terribly undersized. BBK is one solution if you have the money. I figured out after replacing the rotors approximately every 20K miles for around $200/swap, I will spend less than with(pick a BBK company) any kits that are out. Especially considering the cost of replacement parts for said BBK. JMO though...
Old Nov 23, 2005 | 09:38 PM
irish44j's Avatar
retired moderator
6th gen rotors and calipers with Hawk HPS pads
Old Nov 23, 2005 | 10:40 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
Stardust- I told ya HPS won't warp your rotors, do you belive me now ? Hawk HPS all the way, my rotors have turned blue from some VERY high speed stopping and they are still not warped at all- and I have 23 dollar a pop cheap made in China rotors from Napa.
Old Nov 23, 2005 | 11:04 PM
steven88's Avatar
Need A Light?
Mike, is it true that majority of rotors perform the same? This is assuming they are blanks....I might just go your route since brembo or nissan rotors cost alot more...is it also true that the pads are what warp the rotors?
Old Nov 23, 2005 | 11:24 PM
Kruppa's Avatar
Powerslot rotors and Hawk HPS = great combo...i love mine
Old Nov 24, 2005 | 01:53 AM
meccanoble's Avatar
Sports Button FTW
although really good braking, this is not the simplest method. It involves spacers as well.
Instead, i found some high quality rotors. Life of rotors are not in the pads but mainly in quality of the rotors. I have AP Racing rotors with hawk pads. Best quality i have ever held in my hand, and not only more affordable than 2k4 setup but simpler. Brakes are firm, and on point. Only complaint is squeeling from the pads and has nothing to do wit the rotors. Do yourself a favor and hit up AP Racing. If you need more info, PM me and i'll get u their info.
Just a little background info, they have been making braking parts/systems for other manufacturers for years....not they doing it themselves. I've had mine for a good month and a half if not longer and i'm absolutely happy wit them. Just got suspension done this week and checked them out...looking great.
Old Nov 24, 2005 | 02:53 AM
Bluesbrekr's Avatar
Doctorate in Detailing
Make sure you're not over torquing the lug nuts, too. 80-85 lbs. is the spec.
Too tight will cause them to warp. I've got my OEM rotors/pads and no warping after 45K miles.
Old Nov 24, 2005 | 09:17 AM
Saucisse's Avatar
Same here!!! Love them !
Old Nov 24, 2005 | 09:59 AM
Maximum Performance's Avatar
Carbotech Bobcats+Power Slot rotors, 15K miles and they work very well
Old Nov 24, 2005 | 10:57 AM
StrongIsleMax's Avatar
warped rotors
my 2k4 caliper + zinc coated 2k4 rotor and pbr pads warped in about 12k miles. I think rotor warpage is a suspension/hub design issue.
Old Nov 24, 2005 | 11:23 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
same here..... 3 years and still going......... excellent buy
Old Nov 24, 2005 | 11:49 AM
Majority of the rotors are cast from the same iron so it really makes no diff if you get some cheap CarQuest or Autozone rotors, or Nissan ones. They all get them from some manufacturer like Bendix, Raybestos etc.
Yes its the PAD which warps the rotors, as it leaves material on the rotor. Cheap pads like OEM will do this. I have no problems with my Hawks. Give me OEM rotors and OEM pads and I will warp them within 2 weeks of my driving to work. I love runing up to my stupid speed limiter on weekly basis, and then I need something to stop the car with. OEM stuff would be vibrating like crazy, yet my made in China rotors and Hawk Pads hold up really good. My Rotors are Blue from all the heat, but they have no cracks in them as of yet.
Meccanoble
AP Racing rotors ? What size ? OEM repleacement or what ? I'm interested. I'm going to get the Brembo GT package in the spring most likely to cope with my big bore VQ I'm gonna build.
Old Nov 24, 2005 | 12:52 PM
ColdSHO's Avatar
Axxis pads on 04 frozen rotors, had them for almost a year, lots of really hard braking no warpage yet. just awesoem braking. the brackets are like 150bucks if ur gonna ned new rotors why not spend a lil more and get bettere performance.
Old Nov 24, 2005 | 03:48 PM
Prodigy's Avatar
Still running stock and no problems with 39,000 miles.
Old Nov 24, 2005 | 03:56 PM
LA02MAX's Avatar
but i have 45k
Old Nov 24, 2005 | 04:27 PM
RR5's Avatar
RR5
I put on powerslot slotted front rotors with the hawk aps. Nothing but brake dust and squeaking. My rear pads are like non-existant, but I picked up some Axxis Deluxe plus (front and rear) and some oe blank rotors for the rear. I will check back in jan with an update on noise/dust.
Old Nov 24, 2005 | 05:55 PM
boondoxmax's Avatar
Originally Posted by LA02MAX
but i have 45k
48,000 miles on stock rotors not a shake,rattle, or roll. Braking is just beautiful........................
Old Nov 24, 2005 | 06:37 PM
Prodigy's Avatar
Were there any changes with the 5.5 gen??? Looks like 00-01 seem to have the problems, but it could just be a coincidence.
Old Nov 24, 2005 | 06:47 PM
RR5's Avatar
RR5
My oe rotors + pads I think were the best combo, but my rotors got warped and pulsated the steering wheel during light/moderate breaking.
Old Nov 24, 2005 | 07:33 PM
irish44j's Avatar
retired moderator
how many times do we have to go over this?
in MOST CASES, the ROTORS are not "warping," they just feel that way because of uneven pad material transfer buildup, a result of using OEM or OEM-replacement brake pads.
I'm not going to rehash my "scientific unscientific" study I did on this aspect, but suffice to say that when my original rotors "warped" I did some experimenting and found they hadn't warped at all.
Believe me if you like, or don't.....it's your money you're wasting buying all these fancy rotors. Just buy Hawk HPS pads and you'll be good to go.
Old Nov 24, 2005 | 10:35 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Where did you guys get your HAWK HPS pads from?
Old Nov 24, 2005 | 11:54 PM
Stardust's Avatar
F---ing Kangaroos
Tirerack....
Old Nov 25, 2005 | 09:00 AM
steven88's Avatar
Need A Light?
Anywhere else cheaper? Or is tirerack the cheapest you're gonna get for Hawks?
grateful1's Avatar
I got my HPSs from Jeff at ImportRP because it was a few bucks cheaper than Tirerack. Go on the group deal as he has a posting for other rotors and other pads. I called him to place my order.
Old Nov 25, 2005 | 09:01 AM
Originally Posted by Stardust
Tirerack....
Thanks, man...now my X-Mas list is complete.
Old Nov 25, 2005 | 09:23 AM
MaxPol74's Avatar
Right now i have bedix pads and raybestos rotors if iam correct.So if i resurface the rotors and put on hawk pads i should be ok?
Old Nov 25, 2005 | 09:45 AM
upstatemax's Avatar
redlinemax.com
great price, I got my front and rears for $110 shipped.
Old Nov 25, 2005 | 10:21 AM
hawnboy's Avatar
Thanks for the info! I got PowerSlots that "warped" with a local aftermarket ceramic pad setup. I am going to order new HAWKS, ASAP!
Old Nov 25, 2005 | 10:57 AM
import_rcr's Avatar
Definately check your torque specs. There are TSB's on a few other models I've owned regarding warped rotors and wrong torque on lugs.
Also during a recent brake job on my '01' the drivers front caliper wasn't stuck but the piston was wearing inside caliper as if it were binding. A dragging caliper can cause your unnecessary heat build up and warp the prematurely.
One last thing check wheel balance for bent rim. Two of my AE rims were bent BAD when I put tires on and that can translate like a warped rotor too.
There I'm done...
Old Nov 25, 2005 | 04:59 PM
Eenis's Avatar
What should I look for in Rotors then? If they're all the same, then why buy iRotors or Brembo in the GD instead of the $23 NAPA replacements? What makes a good blank, period? I believe there's been discussion about how XDrilled and slotted rotors are created, and how the point in production at which the holes/slots are put into the rotor impact the chance of them cracking, but what about blanks? Basically, why pay a premium if they're the same? And this is outside of zinc coating or cryogenic processing.
Old Nov 25, 2005 | 07:23 PM
irish44j's Avatar
retired moderator
there is no reason to spend more on rotors, unless you are doing a TRUE upgrade like 2-piece rotors (very $$). The zinc coating comes off quickly, the cryogenic treatment/frozen rotors have not proven to be any more reliable than normal ones. XD and slotted are for looks, not performance.
my advice: don't pay a premium unless it's a true performance upgrade (i.e. real BBK or 2-piece rotors). Invest in good pads (HPS)
I got mine at RedlineMax also (obviously)
Old Nov 25, 2005 | 08:59 PM
RR5's Avatar
RR5
So that whole theory of superheated gases trapped between the surface of the pad and rotor surface which creates brake fade; and is reduced by using slotted or Xdrilled rotors is just bunk?
Old Nov 25, 2005 | 09:12 PM
irish44j's Avatar
retired moderator
IIRC, that is only an issue if you're using organic brake pads.....doubtful that it is an issue with semi-metallic or ceramic pads.
Even if all pads did that, it wouldn't apply to typical street driving, as not nearly enough heat is generated unless you're repeatedly stopping from 70mph over and over and over and over. This *could* apply to racing (i.e. road courses), but even then, I doubt it. I've never had any problems with brake fade, even in long autocross courses where the brakes get quite hot.
Another example: I go into the mountains to ski alot, and enjoy driving rather aggressively up and down the mountains. The only time I ever had any brake overheating problems was when my brakes were completely stock (OEM pads/rotors/etc). Since then, I've come down many long mountain roads (going downhill for20-30 minutes at a time with hard braking), with 4 people in the car and a week's worth of ski gear...Car at its heaviest, and moving pretty fast down the moutains....and never had ANY fade issues. It's all about the pads.
Old Nov 25, 2005 | 09:13 PM
Chanimal117's Avatar
I still have stock rotors on my 2000 SE. My fronts are slightly warped and scored. I've already had to replace the rears. Does anybody know any reputable shops in Long Island New York I could go to?
Old Nov 25, 2005 | 09:54 PM
irish44j's Avatar
retired moderator
try your local forum...
Old Nov 26, 2005 | 07:55 PM
ghostrider17's Avatar
I hate to be the naysayer here....but I installed Frozen rotors AND Hawk HPS pads @ 30k, and they "warped" within 3k miles.
I've since turned the rotors and they are holding-up better, but still shimmying some on hi-speed stops.
I agree with the majority here.....BBK is cost prohibitive, and stock is no answer. Best you can do is get better pads, and plan on buying cheap replacement rotors every few thousand miles.
The diameter of these brakes is simply too small for the weight and performance of this car, and the design of the calipers/carrier has GOT to be defective in some way or another. Just have to deal with it.....at least the engines aren't exploding -- YET!
gr
Old Nov 26, 2005 | 09:13 PM
scopium
800k and warped? damn.. thats short
i have brembo and pbr pads..BUT i think ever since i got SS lines.. my rotors dont warp as much.. this time my rotors lasted a 1.5 years..
i think ss lines makes the pressure more linear.. and less expansion of the fluid
BkGreen97
Apr 2, 2016 05:47 AM
Serotta33
Sep 17, 2015 12:14 PM
catalinvint
Sep 16, 2015 07:48 PM
A32goldylocks
Sep 2, 2015 06:39 AM
