2k2-2k3 HID headlight down the road visibility...how is it?
Old Nov 30, 2005 | 08:06 AM
  #41
ypl102's Avatar
horizonal direction?
My 03 HIDs have only vertical adjustments on back of housing, horizontal direction is set by the mounting angle on the clips mounted on the radiator support and the top bolts, there are some play possible with the screw inside the fender but i don't it's meant for that.
Old Dec 15, 2005 | 11:16 AM
  #42
MaxBlu5's Avatar
If installing the 2k3 HIDs in a 2k, do I have to remove the headlight clips attached to my car that keeps the 2k headlights in place? If so, do the 2k3 headlights require their own clip holders or no?
Old Dec 15, 2005 | 04:54 PM
  #43
Peabo5000's Avatar
I had to adjust my beams up a little higher. I see so well now I think I'm brighter on the cars in front. Before I could see where the light beam ended 3 feet on the ground in front of me
Old Dec 15, 2005 | 05:16 PM
  #44
boondoxmax's Avatar
Nissan made them standard on all 02-03 maximas so iam sure they didn't use the best HID kit avail. but they are a lot better than standard halogen headlights. The only problem with them is they are not projector type. And yes the hid in the acura cl sucked big time. Nissans are not that bad....
Old Dec 16, 2005 | 07:37 PM
  #45
darrick04's Avatar
If you want them to fit perfectly YES you need to get the 02-03 clips... Otherwise they will aimed up higher or lower because they aren't properly secured!
Old Dec 17, 2005 | 01:19 PM
  #46
kenny's Avatar
My 03 HIDs suck!! I am saying that only because I don't want people to jack them. THe lights may not seem very bright in the city because of the ambient light. When you are on a dark country road at night, you'll really appreciate the difference.
Old Dec 17, 2005 | 01:40 PM
  #47
NUmaxima's Avatar
If you are driving on well lit streets you are not going to see a huge difference with HID's. But on horribly lit street Maxima HID's will make the difference. Lexus still utilized reflector HID's until last year with good results. I am still contemplating whether to do a projector retrofit for my 02. But I will probably save my money for something more useful.
Old Dec 18, 2005 | 06:23 AM
  #48
Nomad's Avatar
Originally Posted by lowincash
i agree the maxima reflector hid aren't the best but it does its job pretty well. it doesn't go as far as i had hoped so but i did aimed it up a tiny tiny bit and helped a bit. reflector hids don't shoot light out as far as projectors do that's why projectors are so much better than reflectors. i was originally going to have a retrofit done on my 2002 headlights because i didn't like how blurry the cutoff was and light didn't go as far. well after cleaning the headlight lens a with plastic cleaner and scratch remover stuff the output seem a lot better and the cutoff is more defined. now i can actually see a cutoff instead of a blob of blur haha. well i would say i like the maxima hids for they do their job lighting up the road in front of you and looks great too
Hmm I followed your suggestion and my friends thought that I bought bulbs with higher K rate
Old Dec 18, 2005 | 06:39 AM
  #49
F23A4's Avatar
I think the 5.5G Maxima HIDs are noticeably more effective than typical halogens. But, my Murano's bixenons put the Maxima's HIDs to shame; quite simply, if I hit the high beams in the Murano, night is effectively turned into daytime anywhere near my frontend.
Old Dec 18, 2005 | 09:17 AM
  #50
kramarz99
2k2 H.i.d. Angel Eyes
HEY,
ANYBODY KNOWS WHERE TO FIND ANGEL EYES FOR 2K2 HEADLIGHTS?
RECENTLY I WAS PUTING ANGEL EYES ON MY MAXIMA AND I BROKE ONE OF THEM, ANY IDEA WHAT CAN I DO OR WHERE CAN I GET THEM BESIDE CUSTOMMAXIMA.COM?
THANKS, KRAMARZ99
Old Dec 18, 2005 | 09:21 AM
  #51
chr0nos's Avatar
umnitza makes halos for custommaxima.com.
Old Dec 18, 2005 | 09:52 AM
  #52
lowincash's Avatar
No More Maxipad
here's a pic of the output...i tried to take it the best i could to show how it looks in real life and this is closest i came to...
Old Dec 18, 2005 | 08:13 PM
  #53
MaxBlu5's Avatar
Thanks! I should be getting my 5.5 gen HIDs this Tuesday.
doctorpullit
Oct 28, 2019 10:58 PM
doctorpullit
Dec 12, 2015 09:39 AM
uttadms31
Sep 30, 2015 05:24 AM
Noela
Sep 26, 2015 08:22 AM
