Some Car Trouble
Old Nov 30, 2005 | 12:31 PM
wojowojo16's Avatar
Some Car Trouble
3 things have happened so far..usually when it has been cold out
1 (this has happened 2 times, about 1 week apart) - sitting at a light, been driving between 5 - 10 minutes. Hit the gas, car doesn't go anywhere then around 2000 RPM's the transmission finally engages and the car moves (tires spinning a little)
2 (this happened 1 time) driving down the highway, let go of the gas pedal and RPM's drop down to IDLE, hit the gas they come back to driving RPM's then car finally accelerates
3 (this happened 1 time) driving home on Friday the car felt sluggish, like it was struggling to accelerate. I would have to floor it to get it to do anything. When I finally got home, it had no power. I could floor it at a dead stop and it felt like a go KART.
So I take it to the dealership on sunday (2 days later to drop it off), while driving there the car acts perfectly fine. They have it for 2 days, it acts fine for them and throws no codes. I pick it up, did a test drive with a tech and of course the car was fine.
Car is an 02 Auto with ~73,000 miles.
Any Ideas????
Thanks for the help
-JOE
Old Nov 30, 2005 | 02:00 PM
wojowojo16's Avatar
bump -- anybody????
Old Nov 30, 2005 | 02:25 PM
Jasovanni's Avatar
MAF?
Maybe check your tranny fluid too...
Old Nov 30, 2005 | 02:41 PM
wojowojo16's Avatar
Originally Posted by Jasovanni
MAF?
MAF was my thought but no codes.
Tranny fluid was changed at 60K
Old Nov 30, 2005 | 02:50 PM
meccanoble's Avatar
Sports Button FTW
dag i was going to say tranny fluid but hmmm....sounds definitely like a tranny/converter issue to me....
i hate it when that happens, u see a problem and when u need it to show itself the most, it doesnt show at all....your luck is great
Old Nov 30, 2005 | 05:51 PM
paralyse's Avatar
I Miss My Maxima
Transmission is bad. Same symptoms as mine before total failure.
Either valve body must be replaced or entire unit.
Old Nov 30, 2005 | 06:07 PM
OHH NOES's Avatar
6spd Swapped
I think its your MAF. A bad MAF doesnt always throw codes...
Old Nov 30, 2005 | 07:29 PM
Darius's Avatar
this happens to me too... except EVERY time i start the car. Its worse the colder it is... goes away when the car warms up
Old Dec 1, 2005 | 06:52 AM
wojowojo16's Avatar
I think thats common when cold but mine happens when it's already warmed up.
Old Dec 1, 2005 | 07:16 AM
makdaddy386's Avatar
i very highly doubt that your MAF is causing this. Sounds way more like a tranny issue to me
Old Dec 1, 2005 | 08:58 AM
NYPD-Arnold's Avatar
Z
Torque converter.
Old Dec 1, 2005 | 09:19 AM
jimmycapp's Avatar
Either you are looking at total failure of the tranny, or you may be really low on tranny fluid. Sounds like torque converter doesnt have enough fluid to work properly.
James
Old Dec 1, 2005 | 07:08 PM
Darius's Avatar
James
but then wouldnt that happen all the time... not just when cold?
Old Dec 2, 2005 | 11:26 AM
wojowojo16's Avatar
I checked and the tranny fluid is clean and full...
any other thoughts?
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
Slamrod
Apr 10, 2016 05:24 PM
Balkins
Aug 12, 2015 06:39 AM
laparka66
Aug 6, 2015 09:36 AM
