eBay FSTB owners, washers?
Old Nov 30, 2005 | 11:02 PM
steven88's Avatar
Need A Light?
For those of you who have the ebay FSTB...how many washers did you place under the FSTB bracket to raise up the whole bar from hitting the IM? I have an issue with mine...so I'm thinking of adding washers...just don't know how many...
pictures would be nice too...thanks!
Old Dec 1, 2005 | 05:46 AM
bladerunr's Avatar
Mine fit without washers. I guess you have to use the same thickness of washers as you need clearance. Trial and error.
Old Dec 1, 2005 | 05:54 AM
Deckdout2's Avatar
Play with my balls
I have zero washers...
Old Dec 1, 2005 | 06:56 AM
steven88's Avatar
Need A Light?
damn...anybody else? I know there are alot of u with washers!
Old Dec 1, 2005 | 07:30 AM
spiromax's Avatar
Seoul Man
I put two washers on each bolt under my FSTB.
Old Dec 1, 2005 | 07:36 AM
steven88's Avatar
Need A Light?
Old Dec 1, 2005 | 07:46 AM
Puppetmaster's Avatar
None.... bar doesn't touch, even when in gear... same applies to both eBay and Otto FSTBs for me...
Old Dec 1, 2005 | 08:06 AM
steven88's Avatar
Need A Light?
I know there are two different kinds of bars from ebay...my first one was a bar that bent upwards (like stillen, otto) to avoid any clearance issues with the IM...my 2nd bar is the one that barely bends upwards...this is the one having issues becuz the lack of upward angle the bar has...
Old Dec 1, 2005 | 08:12 AM
My eBay one looked like this:
Doesn't bend as much as the Otto but it didn't touch the IM either.
EDIT: Brain fart
Old Dec 1, 2005 | 08:17 AM
steven88's Avatar
Need A Light?
Doesn't bend as much as the Otto but it didn't touch the IM either. Have you tried playing with the screws on the bar it self to see if it changes the height?
hmm...screws on the bar changes only the length I believe...and mine is already maxed out...in other words, if I change the length to any other position than what it is right now, then the bar will not fit the brackets what so ever...
I'm heading to Lowes this afternoon to pick up some washers...thanks for the help!
Old Dec 1, 2005 | 08:25 AM
You're right, I edited my post. It shouldn't change the height once you have the length set.
Old Dec 1, 2005 | 09:16 AM
ColdSHO's Avatar
no washers on mine either!
Old Dec 1, 2005 | 09:34 AM
GBAUER's Avatar
I had to put washers under my Custommaxima FSTB. one under each nut. Not a problem since then.
Old Dec 1, 2005 | 09:44 AM
SEmy2K2go's Avatar
Go BUCKS!!!
3 per side
Old Dec 1, 2005 | 01:48 PM
boondoxmax's Avatar
I had 2 washer per side on my ebay bar. Couldn't get it not to rub without washer, no matter how much i adjusted it
Old Dec 1, 2005 | 02:07 PM
misiek's Avatar
anyone have a problem with brackets from custommaxima? they told me ill need new brackets to clear so im still waiting on those... other then that i would need alot of washers on boths sides
Old Dec 6, 2005 | 06:42 PM
claudiusmaximas's Avatar
no washers for me...just adjust the bolts and angle correctly and clearance was just right. ebay fstb
Old Dec 6, 2005 | 06:53 PM
MaxBoost925's Avatar
Drug Money
No washers, here's mine:
HOWEVER, my FTSB does get in the way of a sensor, it's the blue one in the top right. It mounts real close to the strut tower next to the airbox on that one metal piece.
Old Dec 6, 2005 | 07:05 PM
ShIft_uR FacE's Avatar
they all do the same thing dont they...only diff. is the name...sorry to threadjack just wondering which to buy....
Old Dec 6, 2005 | 07:21 PM
They are all the same... just find one that is in your price range and that is pleasing to the eye.
Old Dec 6, 2005 | 08:02 PM
OOmaxSE's Avatar
Are the 00-01 FSTB different from the 02-03??? Because of the clearance issues?
I have an 00 and my bar fits with no washers and looks fine, no need for washers unless IM for 5.5g is significantly taller.
Old Dec 6, 2005 | 08:16 PM
lex4style's Avatar
do you have the ebay FSTB?
litch
123
Jan 4, 2024 07:01 PM
D Mason
Jun 21, 2016 04:43 AM
220k+ A32
25
Oct 3, 2015 09:09 PM
bernyp
Oct 2, 2015 10:10 AM
soybeanz
Sep 25, 2015 10:46 AM
