replacing factory fog halogen bulbs
Old Oct 12, 2000 | 03:56 PM
steveyang
anyone have good directions on how to take out the stock fog bulbs?? I just tried doin it with no results. Hey im just an amateur at this. Anyone willing to help out a fellow max??
peace out
Old Oct 12, 2000 | 04:04 PM
UMD_MaxSE's Avatar
Got Bent?
There were posts on how to do it a while ago. Search the forum and you will find them. From what I hear, it's a pain to remove them.
Old Oct 12, 2000 | 05:30 PM
Max2K's Avatar
Give it A Try
Changin fog lights r a realll pain. Took me and a friend a couple trys before we got it to work. K lemme try to explain. Before u do so turn ur steerin wheel to one side (so u can later reach from the splash guards to push ur fog light unit out) first u hav to unsrecw the black plastic screws from under ur car, next unscrew the splash guards on the front tire, note u dont hav to take off either. From the splash guard reach and u should be able to see and feel the fog light unit. Reach in and unscrew a screw tats holds the fog unit in place. After tat u should be able to push the unit out. Try from both the bottom of the car and from the side, the unit is tightly secured with a plastic thingie. It should pop out from front, after tat jsut change the bulb as u would with the headlights. Then just do the reverse and it should be done.
-Good luck
Old Oct 12, 2000 | 06:51 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
Go to my site... click on CAI 2... can you see the little black nub under the fog light assembly? You'll have to undo that and push the whole assembly out (but that's after getting all the black rivet thingies out from under the fog area). Good luck!
Old Oct 13, 2000 | 10:42 PM
steveyang
is it that one black screw underneath the fog light assembly that holds it in placE? i tried getting it out but couldn't dammit.the screw just doesnt want to come out. i thought this would be a piece of cake, o well. anybody have any tips on how to get the plastic screws in and out? i just pulled the damn thing before and they came out with a loud scary noise. I couldnt get them back in. thanks for the info!
Old Oct 13, 2000 | 10:57 PM
Y2KevSE's Avatar
That's right... you'll have to unscrew that black thing. Once that's done, just push outwards, HARD, and make sure you catch it.
KristyKarina
Aug 23, 2015 09:53 AM
YourLocalAsian
Aug 17, 2015 02:33 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
MikesChevelle
Aug 6, 2015 11:36 AM
