Starting issue
Old Dec 6, 2005 | 01:30 PM
00MAXI's Avatar
Starting issue
Fifty percent of the time my car turns over slow.
When it finally "ignites" the engine dies, if I don't give it a smidget of gas pedal.
Is it the starter?
The Battery?
The Alternator?
Spark plugs (plats) and coils were changed at 88k, the car now has 149k.
At around 95k I got the Nissan Fuel/induction service done.
On a side note where is a cheap place to get front rotors and pads.
Old Dec 6, 2005 | 01:48 PM
NmexMAX's Avatar
dot dot dot ...
Are there any codes?
Take each of the items in question to have them checked out at AutoZone.
Old Dec 6, 2005 | 01:50 PM
paralyse's Avatar
I Miss My Maxima
Check battery first.
Old Dec 6, 2005 | 07:25 PM
00MAXI's Avatar
Yes there is a code. It's the PO430 Bank 2 Low efficiency catalyst. Which means Front Pre-cat has gone to ****. But evidently this does not affect performance just emissions i.e. if I were to get a smog check they'd be all, "fix dat **** boy!"
Old Dec 7, 2005 | 03:23 PM
getbigtony's Avatar
by the way.. on a cold start, o2 sensors are ignored until operating temp. if ur starter turns over slow all the time, it might be a current problem to ur starter, or ur starter might be starting to die. check IACV/motor. idle air control valve/motor. i dont knwo where that is, and i've asked, but have gotten no response. perhaps i should start a thread. might be stuck closed, thus causing inefficient air flow. yes, i will do that.
Old Dec 7, 2005 | 06:54 PM
00MAXI's Avatar
Wonderful piece of advice. All of you have been great. I'm gonna do the autozone electrical check and then go from there. I had a feeling it could be the IACV valve.
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
Maxima30
Sep 7, 2015 06:13 PM
trungg86
Sep 4, 2015 04:58 AM
