Eibach Spring owners
Old Jun 4, 2001 | 10:03 PM
PhatGuy
I'm looking at the Eibach Pro springs for my 2K1. I hear I can do a 0.8" drop? Is this drop adjustable with everything else stock? I have a FSTB and RSB now.....how will my ride differ in comfort (bumps) and handling? What is the going market price for the springs? What should the intall time be including alignment? Do the back seats have to come out at all during install (I hope this isn't a stupid question?) Any other feedback at all would be awesome!
Old Jun 4, 2001 | 10:13 PM
AznWontonboy's Avatar
i belive the drop is 1.3 or sumthin.. not .8
no its not adjustable
in comfort, with the fstb and rsb not much, but would the handling noticeably wayy better.
going price depends on where u get it.. try www.shox.com
install time i dunno.. sorry.
i dont think the back seats need to comeout.. why would that effect the install? (im not postitive on this tho)
Old Jun 4, 2001 | 10:39 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
The comfort level is going to drop. You're going to feel the bumps and cracks that you've never felt with the stock springs.
No need to remove the back seats for the install.
Old Jun 4, 2001 | 11:18 PM
PhatGuy
Anyone know a relatively standard install time for the Eibach with or without alignment?
Old Jun 5, 2001 | 06:33 AM
Y2KevSE's Avatar
Depends on how skillful the installer is. I'd say somewhere between 2 to 5 hours (without alignment).
Oh yeah... make sure they cut the bumpstop (cut off one ring).
Old Jun 5, 2001 | 07:12 AM
Y2KevSE's Avatar
Originally posted by yo_its_ok
My own car took 2.2 hours, wht2kmax's car took under 2.0 hours. 4th Gen from a non-maxima.org member took 1.8 hrs.
Alignment on all 3 took 0.5 hrs.
5 hours good lord~!~!~~!
I think I'd commit suicide at that point.
-Peace
I said between 2 to 5 hours, Hogan. Also depends on the installer's experience. You, my friend, are experienced.
Old Jun 5, 2001 | 08:01 AM
Y2KevSE's Avatar
Fine fine fine... 4 hours plus play around time.
Old Jun 5, 2001 | 03:30 PM
greggmax's Avatar
It'd take me 5 weeks and then it would be f'd up. I can't even change my oil in 5 hours.
Old Jun 5, 2001 | 05:02 PM
[maxi-overdose]'s Avatar
you meant "turn-the-wheel-to-the-right-and-remove-the-filter speedy oil change"
I think I learned this from u or someone who posted about this before
Next Maxima Meet....I teach everyone the art of 10 minute oil changes, and in the parking lot brake jobs.
LoL
-Peace
Old Jun 6, 2001 | 11:23 AM
Slim Shady's Avatar
How much did the springs run and where can you order them from
Old Jun 6, 2001 | 12:20 PM
hmmm....I need to learn about the brake job then. =)
I can also teach how to use pliers to compress the rear brake piston, and do it in a parking lot.
Maybe build a supercharger out of Home Depot components ?
-Peace
Old Jun 6, 2001 | 12:28 PM
Y2KevSE's Avatar
Just make sure you don't mess up the caliper because it'll be bling bling to replace them.
Old Jun 6, 2001 | 12:36 PM
UMD_MaxSE's Avatar
Got Bent?
hmmmm... ooglie SC?
Old Jun 6, 2001 | 01:14 PM
Y2KevSE's Avatar
Originally posted by UMD_MaxSE
hmmmm... ooglie SC?
Not enought fuel = *BOOM*
Old Jun 6, 2001 | 02:13 PM
punkdork's Avatar
Springs should cost ~230 (shox.com) unless you can get them used. My install took like 8 hours cause we didn't know what we were doing and we took breaks including lunches and we had to get a new ratchet (mine broke) and then a breaker bar. Air tools and a lift would significantly reduce the install time.
Old Jun 6, 2001 | 02:16 PM
UMD_MaxSE's Avatar
Got Bent?
ooglie hi performance fuel pump and regulator?
Old Jun 6, 2001 | 02:23 PM
Y2KevSE's Avatar
Ooglie fuel management unit would work (similar to Vortech's in the Stillen SC kit).
Old Jun 6, 2001 | 04:06 PM
PhatGuy
shox.com at $230 sounds great! Checkin' it out now. Talked to a tuner today (does everything but Maximas) and he is saying I should go with H&R. They are a little lower than Eibachs but he said they are better performance wise. I assume I lose more comfort with the H&R over Eibachs?
Old Jun 6, 2001 | 04:23 PM
UMD_MaxSE's Avatar
Got Bent?
hmmm... take off the one on Jane's car and see how it works. We'll prototype one
Old Jun 6, 2001 | 05:09 PM
Y2KevSE's Avatar
Eibachs perform better while H&R's ride quality isn't as harsh. I think he got them mixed up.
OK!
can I have ur old one if I messed up? =)
Old Jun 6, 2001 | 05:17 PM
Y2KevSE's Avatar
I'm still using the Maxima rear calipers. Z rear calipers will not fit on our Max.
Old Jun 6, 2001 | 05:26 PM
I'll take the front one first then =D
Old Jun 6, 2001 | 05:41 PM
Y2KevSE's Avatar
The fronts are easy... just push down REALLY hard to compress the piston. I doubt you'll mess them up.
Get a new pair from the junkyard if you do mess up.
doctorpullit
Oct 28, 2019 10:58 PM
D Mason
Jun 21, 2016 04:43 AM
MaxLvr21
Oct 17, 2015 12:11 PM
bernyp
Oct 2, 2015 10:10 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
