Wheel Vibrating
Old Dec 19, 2005 | 11:40 AM
wadamax's Avatar
Wheel Vibrating
I had a tire replaced about a week ago on my rear driver side wheel. This past Thursday I decided to rotate this wheel to the front driver side wheel. After doing so, I noticed that as I pick up speed or slowed down (0-25 mph) the wheel sort of vibrates and makes a knocking sound. I am going in to see if the wheel needs to be balanced, but before doing so, I wanted to check to see if there were any other suggestions as to what this might be. BTW, I have the OE 2002 SE 17's. Any input will be appreciated. Just want to be prepared for what they may tell me the problem is.
Old Dec 19, 2005 | 11:54 AM
Whtmax'01's Avatar
It just might be that your rim is bent slightly which is hard to balance. Both my rims are slightly bent , the guy doing wheel balancing showed me how uneven the wheel was even with a slight deformity that you can only tell when it spins.
If your rim is bent, then just swap the tires onto a good rim and put it in front and bad rim in back.
Old Dec 19, 2005 | 12:03 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
you need to balance all four tires wven though you only changed one.. my .02
Old Dec 19, 2005 | 12:09 PM
doublea's Avatar
Maybe the wheel need to be re-balanced. This happend to me quite often specially in winter when snow get jammed in the wheel, that de-balance the wheel and make the wheel shake as speed increase, once you clear the snow in the wheel then everything come back to normal.
Old Dec 19, 2005 | 12:10 PM
wadamax's Avatar
After reading your reply about the bent rim, that may be the case. I never noticed this when the rim was on the back. I may have to switch it back.
user 11122324
42
Jul 18, 2022 03:35 PM
Fbana41
Aug 29, 2016 12:18 PM
Andy29
Sep 29, 2015 05:32 AM
06maxima55
Sep 28, 2015 04:29 PM
Bonka
Sep 14, 2015 11:18 PM
