tools to remove wheel bearing nut, what do u use?
Old Dec 27, 2005 | 10:25 PM
reMaxxxK's Avatar
(maybe in the wrong forum but don't know where to go)
ok, want to buy a power tool to remove "high" torqe nut like wheel bearing, what do u guys use?
what do u guys think about this?
http://www.harborfreight.com/cpi/cta...emnumber=45252
http://www.harborfreight.com/cpi/cta...emnumber=92798
http://www.harborfreight.com/cpi/cta...emnumber=46701
second and third one not sure what the different? go with wired or cordless? which is more reliable?
appreciate for the input.
Old Dec 27, 2005 | 10:44 PM
scopium
you can remove it by hand really.. you can put in well over 200 ft/lb torque
Old Dec 28, 2005 | 05:18 PM
irish44j's Avatar
retired moderator
just get a craftsman breaker bar, stick a 4-foot section of steel piping over it, and it WILL come free
Old Dec 28, 2005 | 06:19 PM
spirilis's Avatar
I'd be surprised if any of those 3 would do it for a well-tightened locknut. I used to have a cheap 1/2"-drive electric impact wrench like that and it could barely remove the lugnuts (yet it claimed up to 230 ft/lbs torque)
On the other hand, my Central Pneumatic (air-powered) 625ft/lb impact wrench ripped off the axle locknuts in about... 3-4 seconds each
Old Dec 28, 2005 | 06:43 PM
reMaxxxK's Avatar
thanks Spirilis, that is what I want to know, guess cheap impact wrench won't do the job at all, might go to Sears get a decent one or Dewalt, if those not working at all then just return it. and like Irish said, man power do the job!!!
Old Dec 28, 2005 | 08:41 PM
Deckdout2's Avatar
Play with my balls
It's fairly easy. Stick a tie rod puller or long crow bar through the lug nuts and use the ground for the leverage. Find a long pipe to put leverage on the breaker bar, (I think mine was a junk 10 feet metal tube), get a good grip, and easily undue your axle nut.
Old Dec 28, 2005 | 08:57 PM
reMaxxxK's Avatar
what about put it back, fac. spec 180-240 lb/ft, my torque wrench only reach 150? kind of worry not tight enough or over kill it.
Old Dec 28, 2005 | 09:19 PM
Deckdout2's Avatar
Play with my balls
Well not a scientific method but I judged by my own weight. I had to go to an alignment shop anyways, and they checked the torque on it, and I was good.
Old Dec 29, 2005 | 07:03 AM
chr0nos's Avatar
i used a 5' steel pipe as a breaker bar to take it off. i think when you are tightening it if you are off 10 ft/pd or so, it wont affect anything.
lowpost99
Oct 26, 2025 06:53 PM
bbsitum
Sep 6, 2019 07:31 PM
jfl330
Sep 4, 2015 01:44 PM
boomerbrian
Sep 4, 2015 08:25 AM
maximusrising
Sep 2, 2015 09:55 AM
