Steering wheel controls for mpg, temp, etc rewire with aftermarket HU?
Old Dec 28, 2005 | 07:51 PM
R3D666SK!N
Does anyone know how I can rewire the steering wheel controls so I can scroll thru the mpg, temp, and other stats now that I've installed an after market head unit? Also, would it be possible to hook it up to the after market head unit to control the volume and track selection? Thanks for the help, in advance, guys!!!
Old Dec 28, 2005 | 08:30 PM
Deckdout2's Avatar
Play with my balls
This will probably help you.
Pac swi-x
http://www.crutchfield.com/S-CiRw6K5...8900&I=127SWIX
Old Dec 28, 2005 | 09:01 PM
R3D666SK!N
That's good for the stereo controls, but what about the trip controls? Right now the display only shows the outside temp., but it won't let me scroll thru to see the mpg or remaining gas mileage.
Old Dec 28, 2005 | 09:11 PM
DaBoxSE's Avatar
There is a connector that was connected to the back of the stock radio. If you look at the wires that are on it, you should find a brown wire. You need to ground this wire. What you should do is strip back the wire casing (don't cut the wire in case you want to reconnect the stock radio). Wrap the exposed wire to one of the screws that holds the bottom of the radio bracket in the dash. Make sure its tight and your info computer should work as normal.
Old Dec 28, 2005 | 09:16 PM
Deckdout2's Avatar
Play with my balls
Opps, I read straight through that when you said aftermarket HU.....my bad.
Old Dec 28, 2005 | 09:48 PM
R3D666SK!N
Thanks guys for the info. I really appreciate it. Np deckdout, your info was good also. I'll probably pick up that adapter from crutchfield!
MikesChevelle
Nov 23, 2024 11:17 AM
trasmadean
Feb 1, 2017 08:20 PM
Maxima_Joe
Nov 25, 2015 08:19 AM
tnewbs
Aug 28, 2015 10:15 AM
MikesChevelle
Aug 6, 2015 11:36 AM
