Where can I get the pac-oem?
Old Jan 1, 2006 | 01:38 PM
sciff5's Avatar
There are no links on the board to a place where you can order the pac-oem unit thats supposed to allow us to run aftermarket subs on the bose system. Do you guys know where I can buy that unit for a 2002 I35?
Old Jan 1, 2006 | 02:05 PM
kingofsorrow's Avatar
forget about PAC, they're products is crap and so is their service.
Old Jan 1, 2006 | 02:19 PM
sciff5's Avatar
okay so how do you suggest hooking up a sub to the Bose HU?
High-low converter is usually considered crap
Old Jan 1, 2006 | 07:21 PM
MetaOrbit's Avatar
Got Projectors?
I've bought all mine from http://www.affsave.com
Old Jan 1, 2006 | 07:41 PM
MxdOut97's Avatar
i have the PAC adapter and it sounds just as good as an aftermarket HU with a sub. got mine off ebay
Old Jan 1, 2006 | 09:16 PM
spiromax's Avatar
Seoul Man
I'm using the PAC SWI-X adapter to make my steering wheel audio controls, but I am not using the PAC OEM amp adapter. I'm using the Scosche OEM amp adapter, and it seems to work well. I ordered both my PAC SWI-X and my Scosche OEM amp adapter from www.crutchfield.com.
Old Jan 1, 2006 | 10:40 PM
sciff5's Avatar
how do you install it? How hard is it to install? After taking my girfriends car door appart and not being able to get it back perfectly I am not too confident in my skills.
Old Jan 2, 2006 | 09:06 PM
spiromax's Avatar
Seoul Man
It's not hard at all. You pull out the dash vents and then unscrew a few screws to remove the ash/coin tray and the radio and climate controls. The only hard part is taking out the trim piece around the shifter. It's not heard to figure out. You just need to be careful as you're prying it up. Apply even pressure and don't use a sharp tool like a screwdriver. If you don't have a tool for removing trim pieces, you can use a flat wide screwdriver as long as you cover it in cloth. Then you take the wires that used to go into the stock radio and you plug them into the amp adapter. The amp adapter has a bunch of colored wires coming out of it that you splice on to the color coded wires coming out of the new head unit. The colors all match up, so it should be easy.
You use a small screwdriver to adjust the output levels on each channel of the amp adapter until you hear distortion, then you back off a quarter turn. Easy.
Old Jan 2, 2006 | 09:28 PM
KabirUTA13's Avatar
IN IRAQ MAXIMA.ORG-ING :)
hard wire it... pearl96max is the man to talk to about that... i just visited him today and he told me... so there you go... lol
Old Jan 2, 2006 | 09:37 PM
MxdOut97's Avatar
its as easy as taking the HU out, from there the plugs can only fit in certain ports so you cant mess it up
Progress
Aug 7, 2008 07:18 PM
