Best way to remove rotors?
Old Jan 2, 2006 | 10:38 AM
myMAXse's Avatar
Want to get them resurfaced, but they wont budge.
Old Jan 2, 2006 | 10:54 AM
spirilis's Avatar
Penetrating oil around the hat (lugnut holes, spray behind it) and give it a couple hours, then pound it hard with a rubber mallet. Don't strike it with metal. A wood block with a big hammer might work.
Be sure to rotate the spindle after every few strikes so you strike it all around, not just in one place.
upstatemax's Avatar
I never resurface rotors, just get new ones. Blackbird loves the cheap **** NAPA ones. They will prob cost you less than re-surfacing them.
To get them off you will have to use some force, take a hammer and pound them off, who cares becuase you will be getting ones anyway.
Old Jan 2, 2006 | 10:55 AM
super6's Avatar
just bang on the edges with a rubber hammer, they will get loose, even easyer is find the threaded screw hole on the rotor by where the studs are, and screw a matching screw into it,i think thats why they are there for.
but i would just get new brembo blanks
Old Jan 2, 2006 | 11:00 AM
myMAXse's Avatar
My 91 Maxima had the hole for the screw, but this one doesn't. I'll try the hammer.
Old Jan 2, 2006 | 12:17 PM
NmexMAX's Avatar
dot dot dot ...
http://www.forums.maxima.org/showthread.php?t=295692
Old Jan 2, 2006 | 04:44 PM
crispykid717's Avatar
Bigger than Jesus
http://www.forums.maxima.org/showpos...5&postcount=15
Old Jan 3, 2006 | 09:27 AM
myMAXse's Avatar
Thanks for all the info. Sprayed some WD40 around the central hub and a couple of wacks with the hammer and they came right off. Got them resurfaced and now no more vibrations.
Old Jan 14, 2006 | 06:01 PM
01maxima4u's Avatar
great. wd40 and rubber mallet worked 4 me.
Old Jan 14, 2006 | 06:03 PM
01maxima4u's Avatar
o, and a 6 pack :-)
Old Jan 14, 2006 | 07:51 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
you can do this...: or or : don't waste your money with the resurfacing the rotors.. they won't last.....
Old Jan 15, 2006 | 09:45 AM
Architect's Avatar
I bought Brembo blanks a while back and installed them w/ new pads and had judder problems again after a few months. Took the car in to a shop and the tech told me that even new, off-the-shelf rotors should be turned while on the car...no more problems with brake judder after a year+ (surfaced Brembo blanks and stock pads)
any truth to this, or have I just been lucky so far...?
my03maxima
Jul 28, 2024 07:40 AM
Apr 16, 2020 05:15 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
Socalstillen
Sep 26, 2015 12:01 PM
