2000 max SE - running very rough and ALL warning lights on??
Old Jan 3, 2006 | 06:59 PM
Supreme Allah's Avatar
2000 Maxima SE w. 83k miles..
Today I drove it to work without any problems, then when I get in it to go to lunch it starts very rough, and idles like a bucking horse, and I notice that all three yellow light are on the dash and they don't go away..
The lights are 'Check Engine' 'SLP On' and 'TCS Off' if I remember right.. and they DONT go away. First off the TCS feels like its on (rainy day and did a tire slip test which it seemed to pass) but occasionally the Check Engine light flashed and then went back to being solid...
It runs fairly smooth but with a weird noise when applying gas, and of course at any red light or stop it starts bucking like crazy. The idle stays up around 1k or more though so it's probably not about to clonk out, it just feels like it
Only problems or issues are that it just hit 3k for the oil change which I don't imagine could be the problem since it's always changed within 3500 miles and this would not be any acception, and since winter started I noticed a sound like a belt slipping when it's warming up.. its that loud SCREECHSCREECH that goes away after a few seconds. Somewhat worryingly I havent heard that sound in the past week, I figured it was a loose belt that I could replace on the weekend since it ran fine. Might be related??
Any advise appreciated. I have a service appt. for Thursday but would like some ideas about what it could be in the mean time.. thanks!
Old Jan 3, 2006 | 07:21 PM
NmexMAX's Avatar
dot dot dot ...
Your car's neglected.
Old Jan 3, 2006 | 07:24 PM
MaxBoost925's Avatar
Drug Money
Crap! seems like it.
Is your CEL flashing?
Old Jan 3, 2006 | 07:30 PM
jballa2KSE's Avatar
i had the same problem just a week ago wit my 2000 SE. It didnt run too rough though, but all three lights came on. At next start up, slip+TCS went away but CEL stayed on. I used a friends OBD II and got 1320(indicating coils). I cleared the code, and havent had a prob since. My mechanic told me its either the coils which is highly likely considering the complaints that are out there, or the crankshaft position sensor, so I'm, waiting till i get another code to pinpoint the problem, so I would also like a little light shed on this subject if poss. Thanks
Old Jan 3, 2006 | 07:32 PM
NmexMAX's Avatar
dot dot dot ...
Old Jan 3, 2006 | 07:33 PM
NmexMAX's Avatar
dot dot dot ...
Hooray for a useful 1st post
Old Jan 3, 2006 | 07:38 PM
Drug Money
Oops , my point is flashing CEL is major dookey, means potential engine damage can occur.
Old Jan 3, 2006 | 07:46 PM
NmexMAX's Avatar
dot dot dot ...
Or a misfire
Old Jan 3, 2006 | 07:49 PM
Drug Money
Or a misfire
...that'd be potentially harming the engine right?
Old Jan 3, 2006 | 07:58 PM
SEmy2K2go's Avatar
Go BUCKS!!!
Nice to see.
Old Jan 3, 2006 | 08:01 PM
NmexMAX's Avatar
dot dot dot ...
Anything can harm it if it gets in there.
Typically around here flashing SES light = Misfire.
But I'm sure you already knew that.
Old Jan 4, 2006 | 07:15 AM
igzy's Avatar
I Know Kwaliti
If the SLIP light is flashing briefly and there is engine hesitation during acceleration, is that a misfire too?
Old Jan 4, 2006 | 07:20 AM
woosh's Avatar
As far as I can remember a flashing CEL usually indicated that there are multiple codes stored/triggered.
As far as damage goes, get the code(s) checked ASAP.
Old Jan 4, 2006 | 07:52 AM
igzy's Avatar
I Know Kwaliti
Forgot to mention, I replaced the coils recently, if it is misfire, should I be looking at replacing the plugs? No other lights come on... Anyone ever experienced problems with just plugs?
Old Jan 4, 2006 | 07:56 AM
Drug Money
You know, IMO if you took the intake manifold off to replace the coils, you might as well change the plugs too.
Old Jan 4, 2006 | 08:03 AM
igzy's Avatar
I Know Kwaliti
I know, I tipicaly do that at the same time too, but the plugs only had 40K on them and are Iridium, so thought would be OK if I wait to replace them later on...
BTW, I have 2K so no manifold removal required
Old Jan 4, 2006 | 08:52 AM
NmexMAX's Avatar
dot dot dot ...
Who takes off the IM on DEK to change coils?
Old Jan 4, 2006 | 09:18 AM
igzy's Avatar
I Know Kwaliti
NmexMAX, I think he was referring to 5.5 gen and whatever needs to be removed from the top of the engine to access the rear ones...
Old Jan 4, 2006 | 09:20 AM
Drug Money
...yeah, exactly.
Old Jan 4, 2006 | 09:26 AM
NmexMAX's Avatar
dot dot dot ...
Pay attnetion to details, me and the mdoerator the only ones who have posted in this thread that have a 5.5g and the first line as well as title of the original post clearly states 2000 ...
Old Jan 4, 2006 | 09:33 AM
igzy's Avatar
I Know Kwaliti
Excellent point NmexMAX...
Would you know if a bad plug would set SES light on? I know that coils would as P132X, or through SLIP and TCS on...
Old Jan 4, 2006 | 09:37 AM
NmexMAX's Avatar
dot dot dot ...
Bad plug --->unburned fuel getting into cats/exhaust system-------> running rich/o2 sensor code
Old Jan 4, 2006 | 09:41 AM
igzy's Avatar
I Know Kwaliti
A-ha, I think you helped me get on top of it! I had P0140 on for some time now that I tried to get rid of, even after putting in 2 new O2's so far and what not else replaced... Cool, so it is likely a plug in the rear as the sensor in the back is reporting it. I'll just replace them all now. Nice... THANK YOU!!! You da man
Old Jan 4, 2006 | 10:03 AM
NmexMAX's Avatar
dot dot dot ...
Could be a coil...What are the plugs history?
Old Jan 4, 2006 | 10:12 AM
igzy's Avatar
I Know Kwaliti
Hm, coils I had just replaced, though they were used but are supposed to be the latest, updated ones. Plugs are about 40K+ old, NGK Iridiums...
Old Jan 4, 2006 | 10:33 AM
NmexMAX's Avatar
dot dot dot ...
Judging from your stats, your problem seems to be more complicated... but always start with teh cheapest fix first.
In this case, in order to rule out the plugs, get some cheap Cu's for less than 2$ a pop, replace them, and see if the problem persists...If you want to be extra cheap, only replace the ones in the engine bank in question.
Old Jan 4, 2006 | 10:39 AM
igzy's Avatar
I Know Kwaliti
Hey! Don't say that I was hoping to solve the problem and keep the Max as I really like the car. If I don't, I will need to say bye-bye to it as this has been driving me nuts for some time now...
I have a set of new in box Iridiums in the garage already. Will put those in and see how it goes...
Old Jan 5, 2006 | 05:02 PM
Thanks for the help fellas but I think I found a TSB that fits this prob..
http://www.nissan-techinfo.com/nissa..._III/15802.asp
Sounds exactly like what's going on except doesn't mention performance issues..
I just printed out a copy of the TSB page and will leave it w. the car when I drop it off tonight at the dealer.. then call them in the morning to see if they worked it out
Old Jan 6, 2006 | 09:52 AM
AHHH ok so the TSB thingy was already reset on a previous visit.. this thing is a misfire code so me and the tech both go at the same time "ignition coil."
Now I'm ordering ignition coils from Dave B and since the dealer would charge me 90 for the diagnostic anyway, I figure I'll have them replace them for me and just pay the extra 60 or so on top of that for labor and make sure it's done right. Then I can try to recoup some loss by keeping the old coils and doing Ebay (with full disclosures obviously!)
So uh. WHy am I posting all this. I dunno. another 500 bux down the drain. Mother Effing Ess.
dank4us
34
Jun 10, 2024 03:45 AM
kjlouis
Nov 24, 2018 06:09 AM
jholley
Aug 11, 2015 09:38 AM
Gsantos79
Aug 8, 2015 07:41 AM
Tanvirkamal
Aug 5, 2015 01:32 AM
