300zx BBK questions
300zx BBK questions
so ive been looking at the 300zx brake upgrade writeups and i still have a few questions.
1) why does the kit matt93se offers look so much different than the kit the jeff92se offers?
2) are cobra rotors really just rotors from a cobra mustang?
3) are cobra rotors the exact same besides the diameter(ie: is the spacing over the hub, between the actual rotor and where the wheel sits the same?)
4) i checked on my friends 300zx and i only need a 10mm spacer to fit. will it be the same if i use the cobra rotors or 6th gen rotors?
5) if i use the same wheels all year should i go for it? i found the calipers for 100 for all four.
Matts kit uses 2004 rotors
Jeffs kit uses Cobra rotors. The Cobra rotors are a bit larger.
Yes, they are.
No, you need the ring inserts to fill the gap around the hub.
That depends on your wheel design. When using the BBK's the relocation bracket moves the caliper out m ore. If you wheels spokes go out the same distance from the center to the outer then yes. If the spoke design flares inwoard then no. It all depends on the wheels.
Sure, even if you had to step down, its not to hard to go back to stock if you had to.
Yes, they are.
Cobra rotors can be found anywhere OEM or aftermarket rotors can be purchased. I recommend Automax in the Group Deal forum.
Not only will you need the rings to center the rotor, you will also need the brackets that relocate the 300z caliper outward to accomodate the larger 13" rotor.
I sell both for $90 shipped. You will also need a few extra bolts/nuts in the same strength grade as the rest of the brake hardware. Along with new brake lines. Matt93se sells what you need for a good price
I highly recommend a local fastener shop so you can get metrics and hardware that has the proper grade. (strength)
Originally Posted by joeyd
can you get the nuts and bolts that you will need at a local autozone or something???
adding more
6) where do i find cobra rotors (what year cobras?) with the ring inserts or just the ring inserts?
http://cgi.ebay.com/ebaymotors/Ford-...spagenameZWDVW
Don't be fooled by the price these things are awesome and a bargain! Had them on for over 6months no problems and quiet.
I'm wondering if it's worth it to change the BBK kit over to my 02 5th Gen?
Rotors? Yes. Rotors with 300z calipers? Not a chance in living hell. Both those wheels don't feature the correct offset or design to clear this bbk
Originally Posted by maxspeedse02
Will the cobra rotors fit on the stock 02 17" wheels? If not how about 6th gen 18's?
I really would like to do this mod, our stock brakes suck
That's what I figured. What other options do I have to upgrade my brakes with 5.5 gen 17's or 6th gen 18's (What I plan on getting in the near future). 6th gen brakes? ? Better rotors and pads? My rotors are warped and I've heard how had the stock brakes suck, So when I get around to fixing them I would like to upgrade. Could I upgrade to Z32 calipers with a smaller rotor without having clearance issues with the wheels I listed above?
The Z and G wheels are staggered though aren't they? I like being able to rotate my tires. I think staggered wheels on a FWD gay is kinda worhtless. I dunno what other options I would have though
it isn't 100% necessary to buy brackets for the brakes to fit. They bolt up to the stock position, but you will need to machine the rotors to a smaller diameter. I know someone who has done this and it works fine. Personally I would only do this with some wheels as the rotor diameter is smaller than stock and looks odd if the wheels are too big or too much space between the spokes. But the added braking power seems to be worth it.
1 gen and 2nd Gen Q calipers are totally different. I have a 2nd gen Q and they are totally different bolt size then the 1st gen.....
Gonna try this with 04 Maxima Rotors on the wifes I35...
If you buy reman calipers from the parts store make sure they are rebuilt correctly. I had one that was missing the o-ring inside, and it was too long before I used it so I couldnt return it. That o-ring is not available for sale by Nissan. Also there are different calipers through the years 30mm aluminum, 26mm aluminum, and 30mm iron,
Thanks guys !
I saw that, good pricing too.
I ordered your brackets so discs and pads are next !
I saw that, good pricing too. I ordered your brackets so discs and pads are next !
Apr 16, 2020 05:15 AM
Unclejunebug
Apr 2, 2016 05:42 AM
Will i need a bracket or no?
