Max runs rough when parked on hill?
Old Jan 4, 2006 | 02:33 PM
paralyse's Avatar
I Miss My Maxima
Happens at all levels of fuel (empty to full) -- when parked on a hill if I start my car up, when cold, my car sputters and misses, and has a very rough idle.
Does not happen when the engine is warm or when I am parked on a fairly level surface.
Anyone seen this issue yet?
Old Jan 4, 2006 | 04:10 PM
5thgenmaxima's Avatar
This is a guess, but I'll bet it's when the front of the car is pointed up hill??..
Again major guess, but maybe weak fuel pump? (Not pumping enough to overcome gravity until fully warmed???)
subscribing
Old Jan 4, 2006 | 07:39 PM
misiek's Avatar
just a guess but maybe because of the oil is running to one side of the pan... i would try to turn the key to on, wait a few second and then turn the car on all the way
Old Jan 4, 2006 | 07:43 PM
Captain Obvious's Avatar
Having the key at "ON" wouldn't help with oil flow because unlike the fuel pump, the oil pump is accessory belt-driven. As in oil doesn't move until the engine is turning.
Old Jan 4, 2006 | 08:13 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
maybe the car doesn't like to be parked on a hill.....
Old Jan 4, 2006 | 08:32 PM
I would think oil is about unlikely as the fuel pump idea....But to test this just pull your fuel pump relay, crank the engine 5 or 6 revolutions, replace fuel pump relay and start it.---I find this unlikely for alot of reasons.
1.) Because it runs rough longer than the second or so that it takes for oil pressure to build. (I assume)
2.) Just doesn't make since
Neither does the fuel pump idea, but it's worth checking....Find your schraeder valve on your fuel rail and hook a pressure gauge to it... See what it reads after you start it.
Old Jan 4, 2006 | 09:12 PM
Derrick2k2SE's Avatar
Could be a short or ground issue. Some connection being made when the car is on a slope? Some part of the electrical system that only comes into play during warm up could be making contact with something it shouldn't when the car is tilted.
Also check the vacuum lines. Same theory as electrical. Something loose bumps a loose vacuum line that's part of the warm up cycle.
Old Jan 5, 2006 | 12:24 PM
paralyse's Avatar
I Miss My Maxima
Thanks for the suggestions -- I'm checking vacuum and fuel pump first!
Old Jan 5, 2006 | 07:28 PM
Hoooper
to check the fuel pump just open the door and turn the key on, listen for a sound coming from the pump. then try it when not on a hill and compare. if it seems to click/pump faster on flat ground then its probly the pump. and its not oil. the engine wont start without oil pressure.
dank4us
34
Jun 10, 2024 03:45 AM
kjlouis
Nov 24, 2018 06:09 AM
MattWithTheMaxima
Jun 30, 2017 01:06 PM
WeetoddA32
Aug 16, 2015 12:45 PM
09maxshawn11
Aug 9, 2015 01:13 PM
