HELP!! y-pipe install
Old Jan 6, 2006 | 05:55 PM
Hoooper
i installed my new y-pipe today and when i drive it (only in gear, never neutral, park or idle) it makes a banging/ vibrating sound. i think it may be coming from the pipe just behind the cat hitting the crossover. is this possible? need help here fast plz.
Old Jan 6, 2006 | 06:02 PM
irish44j's Avatar
retired moderator
you need to unbolt the crossmember and insert 3 or 4 big washers on each bolt (between the crossmember and the car subframe). this will "push the crossmember down" and give you enough space for the b-pipe not to bang. Some people just take the crossmember off completely....but I prefer to have it on with the spacers.
You can also try putting hose clamps around the rubber b-pipe hanger to "jack it up" a bit higher.
Old Jan 6, 2006 | 06:06 PM
Deckdout2's Avatar
Play with my balls
Nikita and I have taken both of ours off and have felt nor had any adverse effects from doing so.
.....and yes it is your crossmember that is in the way.
Old Jan 6, 2006 | 06:37 PM
Hoooper
arright, well i messed with the hangar, guess ill put in some washers tomorrow. thanks guys
Old Jan 6, 2006 | 07:04 PM
irish44j's Avatar
retired moderator
That's because you two drive like little girls (and only one of you actually IS a little girl)
MaxLife17
Jun 27, 2019 01:37 PM
2kmaximel
Sep 16, 2015 03:19 PM
Violator
Sep 9, 2015 10:14 AM
