5th Gen Suspension Thread
Old Mar 14, 2006 | 09:40 AM
  #81
DrKlop's Avatar
Driving is the next best thing
Originally Posted by jafo2com
Sorry if this question is off-topic DrKlop (pls edit if in the wrong thread), but I have not seen any info in any suspension thread explaining why the Maxspeeds on Innerbean's website show different drop info than what is advertised. What I mean is, why does the drop list 1.4F (~1 3/8") and 1.3R (~1 1/4"), but the pic with the maxspeeds installed show a difference from the stock 28 1/16"F being 1 5/16" drop (which is close enough to spec) but the difference from the stock 27 1/4"R was only a 1/4" difference, which is a full ~1" off of spec?
I'm looking to replace the suspension this summer, and I've been pretty much sold on the Maxspeed/Illumina combo as it seems to best fit my personal preferences, but I do not want to be surprised (much heh) by any differences. If the Maxspeeds do indeed follow the actual drop numbers shown in the pic as opposed to the listed drop specs, then that would actually be great as the ride height appears to be more level than stock, the rear maintains close to stock height (for passenger comfort), while the front loses the 4x4 look, and all around I get a better handling ride.
Thank you in advance for any input.
Well, that's an interesting question. Maybe manufacturers looked at the ground clearance of a brand new car where springs have not sagged yet.
To get a more accurate estimate on how your car will look check out these cardomain websites (all these guy got Maxspeeds)
http://www.cardomain.com/ride/417747/1 - SEmy2K2go's car
http://www.cardomain.com/memberpage/734886 -GBAUER's car
http://maxima.cardomain.com/ride/335521 - Lontar1's car
http://www.cardomain.com/ride/442543 - irish44j's car
Old Mar 14, 2006 | 11:50 PM
  #82
jafo2com's Avatar
Thank you for the response DrKlop. It's no big deal really, I was just curious. For all I know it could be something as simple as a typo.
Old Mar 16, 2006 | 06:39 PM
  #83
soundmike's Avatar
Very sound, Mike
There could be another explanation for that - worn struts.
When i initially had my Maxspeeds on oem struts, the drop was actually lower and for a while it seemed like it wouldn't stop going down.
Then after about 10k miles it ocurred to me that my struts may already be worn. After i swapped them out for GR2's the drop was actually noticeably higher than when i had the oem struts. I've had the GR2's for about 15k now and the drop has stayed even since i first had them on.
Old Mar 17, 2006 | 03:21 PM
  #84
Maxz Max's Avatar
Guys,
I'm looking to drop my car and not to sure of what to do, every person I speak to tells me something different.
I was going to get the Eiback Pro Kits & Tokico HP Series (Shocks and Stuts). Til someone told me to get a DAMPENING Kits ( K Sport Kontrol Coilover Dampening kit)
Would anybody have any insight on this lil issue that I have???????
Old Mar 17, 2006 | 04:06 PM
  #85
DrKlop's Avatar
Originally Posted by Maxz Max
Guys,
I have listed all advantages and disadvantages of coilovers in post # 74.
If you plan to use spring/shock combo instead of coilovers it's better to get adjustable shocks so you can match damping force with your spring rate.
Also check out this thread: http://forums.maxima.org/showthread.php?t=461186 Boss Chen coilovers seem to have all the advantages other coilover systems have and at the same time the are relatively soft and reliable.
Old Mar 22, 2006 | 07:27 AM
  #86
sciff5's Avatar
Yeah I have started lookin at the chens too. If company could make a coilover thats as reliable as a spring/strut combo with a decent ride I would probably go for it. But Klop your always thinkin the same as me. Did you decide on what setup your gonna go with yet?
Old Mar 22, 2006 | 07:27 PM
  #87
DrKlop's Avatar
Nah man, I have to find out how much it is to professionally corner balance the car with coilovers. If I can afford that I will probably go with boss chans, if not it'll be either h-tech will illumins or Eibachs with Konis. h-tech/illumin combo got many positive reviews in my other thread.(link's in my sig)
I will be asking local guys to drive me around as I'll get closer to the point of lowering. If everything goes the way I planned I should get done with suspension before June.
Old Apr 18, 2006 | 08:00 AM
  #88
rtruchardson's Avatar
Springs/Shocks
My 2000 has a 100,000+ Miles and I know it is time to replace the Shocks. What is a good brand to go with? The ride is still rather good;no bouncing or bottoming out when I go over bumps. Thanks
Old May 1, 2006 | 04:18 PM
  #89
friedbacon's Avatar
is there a thread on eibach vs h&r? i can't seem to find the link to it. Can someone please post the link?
thanks.
Old May 4, 2006 | 03:23 PM
  #90
ghostrider17's Avatar
[QUOTE=Puppetmaster]Progress springs are soft and can be bouncy. I used to think that it was my HP struts that were the issue, but I realize now after playing around with the Illumina settings that the springs are indeed soft. I was under the impression that I need higher Illumina settings for them because of the drop, and used various combinations of settings 3-4. Loved the handling, but the ride was a tad harsh, obviously. I tried 2F 3R and it rides awesome now. Despite what I've said in the past, setting 2-3 dampers these springs sufficiently and provides a really nice ride. And yes, you will bottom out if you hit any large bumps because these springs are soft and low.
{QUOTE]
I'm still scratching my head on my own progress/illumina setup. I've tried multiple settings, and although i agree different settings on the struts make DRAMATIC changes in susp. perf -- mine is still bottoming-out on every damn thing in the road.
I REALLY don't think my struts are blown, as there is no obvious leaking fluid or anything like that. However - the two things that people neglect to mention when comparing susp. setups are 1) TIRES 2) Bumpstops.
I SUSPECT that my worn-out Kumho 712's are to blame for some of my issues. I'm going to get some new ToyoProxes4's soon, and hopefully that might help. However, I DID trim my bumpstops substantially, and I'm wondering if that has effected my overall "happiness" as well.
I DO know that my setup bottomed WORSE before the bumpstops were trimmed, so I think I can isolate it to the tires or springs.
Guys: when reporting susp. setup impressions, please mention tires and bumstop trim status -- I think it will help to get a more unified subjective opinion of overall susp. performance.
TWO years later, and I STILL don't know what to put on my car to make it PERFECT for my driving style.
gr
Old May 16, 2006 | 05:45 PM
  #91
irish44j's Avatar
retired moderator
Klop....add:
Canuck Motorsports Springs (00-03 Maxima)
Drop 1.8" front, 1.6" rear
Progressive rate
front initial rate 125 (high rate not supplied), rear (probably linear) rate 320
Old May 17, 2006 | 10:51 AM
  #92
DrKlop's Avatar
Originally Posted by irish44j
Klop....add:
Progressive rate
done, thanks
Old May 29, 2006 | 07:50 AM
  #93
Stereodude's Avatar
This thread seems very devoid of information on the differences between the different struts for Maximas. Like which ones are the closest to stock, and that kinda stuff.
I'm getting near the point where I need to replace my struts, and I'd like some guidance on which struts to buy.
Old Jun 2, 2006 | 09:46 AM
  #94
DrKlop's Avatar
Spring rates:
Eibach Pro: Front: 139-188 lbs/in Rear: 194-295-346 lbs/in
Vogtland: Front: 134 - 194 lb/in (working range 170 - 194 lb/in) Rear: 205 – 377 lb/in (working range 220 - 270 lb/in) [source: http://forums.maxima.org/showpost.ph...&postcount=13]
Tein H-tech: Front: 180 lbs/in Rear: 290 lbs/in
Tein S-tech: Front: 200 lbs/in Rear: 270 lbs/in
Progress Technology: Front : 165 lbs/in Rear : 250 lbs/in
(according to a different, unconfirmed source the rates could be 165-250 lbs/in in the front and 179-285 lbs/in in the rear.)
Canuck Motorsports: Drop 1.8" front, 1.6" rear
Progressive rate
[source: http://forums.maxima.org/showpost.ph...5&postcount=9]
H&R and Sprint refused to provide their spring rates.
Maxspeed Performance does not respond to my e-mails.
Note: Tein and Progress provided only one spring rate for their progressive springs.
Some useful shock info:
Tokico Illumina are designed for springs softer than 230 lbs/in in the frond and 315 lbs/in in the rear. (The technician also mentioned that these rates are approximate)
4th gen Tokico HP are designed for springs with 205 lbs/in front and 293 lbs/in rear spring rate. Information for 5th gen HPs in not available.
This is the graph of compression and rebound for VW Golf's OEM shocks and HPs designed for the same vehicle:
(IMO: since HPs give similar improvements for different vehicles, the difference between Maxima OEM and HP shocks should be similar as well.)
KYB compression/rebound settings: http://maxmods.dyndns.org/index.php?...KybAgxSettings
Note: All information was provided directly by manufactures and I did not change it in any way.
Weight data: http://forums.maxima.org/showpost.ph...6&postcount=64
Old Jun 2, 2006 | 02:39 PM
  #95
Stereodude's Avatar
I found another thread on here that said the Tokico Blue's are the closest to the stock struts and that the KYB's are stiffer and give a harsher ride.
Old Jun 2, 2006 | 03:00 PM
  #96
DrKlop's Avatar
Stereodude, I personally would recommend getting Illuminas because they are designed to match our stock springs at their softest setting. Non adjustable shocks are stiffer and IMO should not be used with stock springs.
I do not believe that Blues can be used as OEM replacement shocks even though that was the first thing I was told when I called Tokico.
Old Jun 2, 2006 | 03:15 PM
  #97
Stereodude's Avatar
Is it possible to buy the OEM struts? If so, how much are they?
Old Jun 2, 2006 | 04:07 PM
  #98
DrKlop's Avatar
Ya you can buy them. The best place is probably Dave B (888-254-6060) Not sure about the price though.
Old Jun 2, 2006 | 05:20 PM
  #99
Stereodude's Avatar
Hmm... If I have to buy 'em from a stealership, I'm sure they're not cheap. I'll have to call and check though.
I don't really want to put Monroe Sensa-Trac's on my Maxima, but from what you're saying it seems that none of the aftermarket struts are a good match except the Tokico Illuminas, and they're pretty pricey.
Old Jun 3, 2006 | 07:51 AM
  #100
Puppetmaster's Avatar
Klop, you could add Sprint springs to the list as well. They're website has no info on spring rates, but I know they make em for 4th and 5th Gens, as well as I30/35s.
Old Jun 3, 2006 | 07:52 AM
  #101
How about buying some used, low miles, OEM struts from the 5th Gen Classifieds? I feel like I see OEM suspension for sale all the time there.
Old Jun 3, 2006 | 08:37 AM
  #102
DrKlop's Avatar
good idea... they aren't as popular as say H&R, but they still exist. I'm ganna try to find out spring rates as well.
BTW, I think I'll also add the drop provided by spring manufacturers to make it more complete.
Old Jun 13, 2006 | 07:00 PM
  #103
jasoner's Avatar
Help with suspension
I finally paid my 00 Maxima and decided to get rid of a persistant clunking noise from front end when going over bumps. This occurs at all speeds and mainly over abrupt smaller bumos. We of course changed the struts and mounts woth oem parts. This did not fix the problem. We then changed the inner and outer tie rod ends and the problem still persisted. Next we changed the passenger ball joint. What else could it be?!! This problem really sucks. I can't spend much more cash on this thing.
The sound os a light to heavy pinging or knocking noise from the passenger side. Seems to be from front end for sure..
Thanks for any suggestions. I am about to sell it if I can't fix it. I really love the car if not for this seemingly unsovable problem.
Old Jun 13, 2006 | 07:12 PM
  #104
DrKlop's Avatar
Check all your bushings for wear especially sway bar endlinks because they are known to go bad on our cars. If it's a "clicking" sound and you can hear it on smooth roads than it's probably your CV joint.
BTW, have you thought, of taking the car to a good mechanic?
Old Jun 14, 2006 | 04:10 AM
  #105
jasoner's Avatar
Thanks for your response. Sway bar end links are new to me. I have already replaced about everything else. I have had the Nissan dealer look at it. I also had the struts and tie rod ends replaced by someone who is a mechanic at a Nissan Dealer. Sway bar endlinks is a new idea to me. How do I test for those? Or can you?
Old Jun 14, 2006 | 04:48 AM
  #106
Nissan dealer/mechanics aren't always "good mechanics".
Old Jun 14, 2006 | 05:47 AM
  #107
naxray's Avatar
I went through the same ordeal trying to find the noise in the front end of my 2K. Turned out to be the strut bearing and the rubber seats.
Old Jun 14, 2006 | 01:51 PM
  #108
jasoner's Avatar
After MANY OPINIONS FROM MANY mechanics, I finally found a Master Mechanic at a Nissan Dealership that figured out the problem. It was strangely enough the motor mount on top of the motor. The mount attatched on the fender well right next to the strut housing. Weird Weird weird. Sounded just like a strut problem or a loose part. After changing everything I jut had to come across the right experienced tech. Thanks for the input guys. I may not have recieved the diagnosis on this board but the kharma worked out well!!
Old Jun 27, 2006 | 01:45 AM
  #109
cpsmaxima's Avatar
Thanks for all the input...
Thanks to all that put their input about their set ups. All the responces helped me decide what I wanted for my new suspension set up. Last week I ordered the following parts...
Tokico Illuminas Shocks
Tein H-Techs Springs
Stillen FSTB
Stillen RSB
Stillen Anti-Sway Bar
Brembo X-Drilled Rotors
Hawk Brake Pads
I should have all the parts by this Friday! I can't wait to see and feel the difference!
Thanks again to all of you
Chris
Old Jun 27, 2006 | 12:17 PM
  #110
pedxing's Avatar
I've had H&Rs and Illuminas on for a while now and they've been great. I put spacers on the rear (20mm H&R) to widen out the track and now get the occasional scraping when going over a large bump or a medium bump at 85+ mph. So this doesn't happen all the time, just 2 times a week. The culprit seems to be the bracket in the rear that attaches the bumper to the quarter panel. It sticks out into the wheel well about an inch.
Question: Has anyone experienced this rubbing, and what did you do?
I figure I can file off a good portion of the bracket without ill effects...or maybe bend it up. Would that be more dangerous than leaving it as is? Right now it just hits the tread. I'd hate for it to hit and possibly slice the sidewall causing a blowout at highway speeds. Going to a smaller spacer (say 15mm or 10mm) would have the same risk, it seems like. Stupid bracket.
Any ideas?
Old Jul 6, 2006 | 09:00 AM
  #111
maximadriver198's Avatar
Nice looking max. Did the cattman exhaust make it loud?
Old Jul 6, 2006 | 09:06 AM
  #112
I having some problems with the my 2000 max. I'm thinking that there could possibly be a problem related to the stage 1 nismo clutch that I put in 3 months ago. From time to time, I will have problems putting the car from neutral into first gear or from neutral to anygear for that matter. It just started a couple of days ago. It only happens after I first start it up. When it does happen, I have to turn the car off and move the shifter into first and then start the car. Any ideas from anyone? Or can anyone tell me if a worn clutch could be the cause of my problems?
Old Jul 6, 2006 | 09:25 AM
  #113
DrKlop's Avatar
maximadriver198, please delete both of your posts. They are not in any way related to this thread.
Old Jul 12, 2006 | 10:33 AM
  #114
reliningmaxima's Avatar
Any ideas?
Good question , I have s tech's blues 19's 8.5 on mines and I'm thinking in adding spacers to eliminate the wheel gap for that flush look but I'm not sure what size spacers do I use in this case..... Dont want the same thing to happen to me(plus what size rims are you running)
Old Jul 14, 2006 | 01:40 PM
  #115
Elfzors's Avatar
Ok, I've read these posts forwards, backwards and sideways. I can't find anyone posting anything about certain springs being worse then others in terms of bottoming out. I have a '02 SE, and I wanna do a drop. Where I'm at a loss is I wanna have a system in the trunk (2 12's) and at times i may have back seat passengers. All that extra weight I'm afraid may bottom out on bumps or dips. Question is which springs are better for this not to happen? Also I wanna keep the stock ride quality as much as possible. Anyone have any suggestions? Much appreciated.
Old Jul 15, 2006 | 08:58 AM
  #116
DrKlop's Avatar
Eibach Pro would probably be your best bet. The drop is very mild (only 1" IIRC,) and the final spring rate in the rear is very high. So if you cut your bump stops you should not bottom out any more often than with your stock suspension.
Most people who have Eibach will also tell you that they like the ride quality.
BTW, did you see these threads?
http://forums.maxima.org/showthread.php?t=459517
http://forums.maxima.org/showthread.php?t=471572
http://forums.maxima.org/showthread.php?t=477358
Old Jul 15, 2006 | 09:48 AM
  #117
emte's Avatar
Maybe you should concider EDFC as a solution instead
It sounds like what you want is image and adaptability, your more likly to get this with a set of adjustible shocks like the Illuminas in conjunction with TIEN's EDFC system ( http://www.tein.com/edfc.html ) over any set of springs you may choose.
Old Jul 15, 2006 | 09:52 AM
  #118
sciff5's Avatar
Wow...Just wow...please do a little more research before further posting.
Old Jul 15, 2006 | 09:57 AM
  #119
Elfzors's Avatar
Thanks for the info and links. I really do appreciate it.
Old Aug 20, 2006 | 06:33 AM
  #120
DFRMAX02SE's Avatar
Need some help from all the experts out there...My rear suspension is bottoming out. I bought my 02 Max in Feb. of this year, it didn't take long to realize that the stock suspension was not up to par with my driving style. IT bottomed out over bumps and the body roll was almost dangerous. So I installed a RSB abd FSTB along with some Tokico Blues. This firmed things up, however the rear suspension stilled bottomed out. I read a TSB from Nissan on the problem and it stated to replace the rear springs. So instead of replacing just the rear springs with stockers I went with a set of H & Rs. Installed them yesterday, and have noticed that the problem is worses. Don't get me wrong the cars handling has been greatly improved and ride is, in my opinion better than stock, this problem is just annoying. Also I am afraid I will blow a strut. Any help/advise would be greatly appreciated. Thanks.
