Vias problem
Old Jan 13, 2006 | 12:00 AM
k2max_driver's Avatar
Vias problem
i noticed that my VIAS (variable intake air system) isn't working. The solenoid is not functioning i would rev it slowly it normally opens at about 1800rpm and now nothing. i did notice more initial get up and go but not as much top end. although i did pull dirty on a freeway run against an 02-03 tl type-s (260hp) from 80 to 125 (about 3 cars). but anyways what can i do what will i tell the dealer they probably have no idea. has this ever happend to anyone? didn't the 5th gen max 3.0L have this problem?
Old Jan 13, 2006 | 03:28 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
do a search and you will find your answer. The 3.0 has a vias problem buut fixable...
Old Jan 13, 2006 | 04:04 AM
nicks79's Avatar
i thought it opens up at around 5k rpm?
Old Jan 13, 2006 | 07:10 AM
rule da road's Avatar
did u already do the vias jb weld fix? My nissan tech suggested not getting into it and i feel the most power as the engine reaches 6k rpm so i left it alone. I also stripped up the bolts trying to mod it myself and almost tore my fuel line. I have no luck with engine modding.
Old Jan 13, 2006 | 07:53 AM
dafertilizer's Avatar
is it common for the VIAS to brake on automatics?
Old Jan 13, 2006 | 07:56 AM
Larrio's Avatar
The Definitive AE Master
i believe on your 2k2, the VIAS opens at 3800 rpms (definitely NOT at 1800 rpm). If your solenoid isn't working, no amount of jb weld will fix it.
the vq35 has a different IM than the 3.0
Old Jan 15, 2006 | 12:09 AM
stupid me reversed vacuum lines. always mark vacuum lines when disconnecting them
Old Jan 15, 2006 | 10:06 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
it is common for the vias rod to seperate from the cup from which it spins for any 3.0 motor that sees regular 5k+ rpms.
Old Jan 15, 2006 | 04:56 PM
meccanoble's Avatar
Sports Button FTW
i dont know how to really test if i have a bad vias. I had it opened and its all in one piece but my car doesnt pull at high end like i wish it did. Or maybe i just want my dam supercharger back
trailer54
Nitrous
Nov 18, 2015 07:44 PM
Turbonut
46
Oct 21, 2015 08:28 PM
Dasmith
Sep 23, 2015 08:28 PM
Kalrakam
Sep 16, 2015 12:30 PM
0m3nc0w
Sep 11, 2015 05:21 PM
