Transmission problems. 2 codes pulled.
Old Jan 13, 2006 | 05:40 AM
whazzzzuup's Avatar
My transmission is not engaging in 4th gear. It slips from 2nd to 3rd gear. The shifts are also prolonged.
I went to Autozone and they pulled 2 codes. They are:
P0744- The PCM has determined that the voltage signal from the torque converter clutch is intermittent.
P0745- The PCM has determined that a malfunction exists in the electrical circuit for pressure control solenoid "A."
From these codes (pulled a month ago), I decided to replaced the solenoid pack. I drove it for 2 miles and the problem was still there.
Last night, I removed the pan and VB again(3rd time). There are metal shavings in the fluid. The thing is, I replaced 6 quarts during the solenoid swap. I have only put 300 miles on it since the solenoid pack swap.
I am shipping out my VB to maximumtuning today. Do you think it's a faulty VB that is causing the problem? If the rebuilt VB doesn't fix the problem, I am going to do a 6-speed conversion.
Thanks beforehand for the help, guys.
Old Jan 13, 2006 | 06:33 AM
MacAlert's Avatar
6 speed conversion?! Didn't think that was possible for the 5.5 gen.
Old Jan 13, 2006 | 07:31 AM
Mass_Media's Avatar
Mass_Media™
It is possible, only a couple people have done it. Its alot of work the motor is mounted differently 6spd v auto.
Old Jan 13, 2006 | 08:19 AM
MacAlert's Avatar
Who has done it? I want to see!!!
Old Jan 13, 2006 | 08:45 AM
Teufelhunden's Avatar
its possible, but people are saying that its gonna cost alot.
Old Jan 13, 2006 | 09:12 AM
vsamoylov
what? where did you get that info from? please stop spreading false info because that is not true.
van i am going to look at what fsm says about it. indication of shavings is not a good thing especially if there is alot of them. hit me up on aim and i can send you all the info.
Old Jan 13, 2006 | 09:21 AM
vsamoylov
ok van hope this helps you man.
first is your at light on?
code 744 is not a electrical code but a mechanical code. it could be numerous mecahnical things.
code 745 is a line pressure solinoid valve.
so hit me up on aim and i will send you the info on how to test it. most likely its your solenoids that are causing your codes and locking up your torque convertor.
Old Jan 13, 2006 | 09:47 AM
Mass_Media's Avatar
Mass_Media™
Post a link saying that it does. You can see that it isn't mounted the same by just looking at it...
Old Jan 13, 2006 | 09:52 AM
vsamoylov
go read up on the car you drive man.
Old Jan 13, 2006 | 10:11 AM
Mass_Media's Avatar
Mass_Media™
http://forums.maxima.org/showpost.ph...81&postcount=5
Go read about it
kthnxbye
Old Jan 13, 2006 | 10:58 AM
steven88's Avatar
Need A Light?
LOL....so much hostility
sorry to hear the tranny slipping Van...slap on a 6spd and just blaaaazE!
Old Jan 13, 2006 | 04:27 PM
whazzzzuup's Avatar
Thanks for everything so far, guys. That's the thing. I replaced the solenoid packs to no avail. My only option is to rebuild the VB. If that doesn't work, the only solution is to do a 6-speed conversion.
Mass Media- are the mounts two seperate pieces for an auto and manual? If so, is there a way to use the top of the automatic transmission mount with the bottom bracket of the manual mount? This is just an assumption, but I don't think Nissan will weld on different mounting points for an auto vs. a manual.
Old Jan 13, 2006 | 04:31 PM
vsamoylov
wrong person to ask van. the auto mount is welded to the frame while the 6 speed mount is bolted to the frame. so basically all you do is get rid of the old mount and drill 2 holes that secure the mount to the frame and you are all set.
Old Jan 13, 2006 | 04:33 PM
whazzzzuup's Avatar
Simple enough. Thanks.
Old Jan 15, 2006 | 08:56 AM
99 SE-L
I hate people spreading rumors about things they absolutely have no idea about. The 6 Speed swap is not difficult.....
Old Jan 15, 2006 | 10:06 AM
hybridioN's Avatar
all teh single ladiez
I've been having a problem like that, and someone told me it could be the fuel filter.
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
Mar 12, 2020 12:06 AM
The Wizard
24
Oct 1, 2015 08:47 PM
Steven Orozco
Sep 12, 2015 10:41 PM
