removing stripped NUT! HOW?
Old Jan 16, 2006 | 04:58 PM
JdoubleOe703's Avatar
teddibear703
I have a stripped nut. Its the one for the FSTB. The place that installed it used too much torque and now it wont come off.
I;ve used the nut loosener, and didnt work. I've stripped 2 14mm sockets already and cracked one.
The nut is now almost round and still wont budge. It hasnt moved at all so i dont think i cross threaded it. Its just frozen!
Any suggestions?
Old Jan 16, 2006 | 05:27 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Try an adjustable wrench
Old Jan 16, 2006 | 05:35 PM
Whtmax'01's Avatar
try vise grip and get some PB Blaster spray if it is rusted.
Old Jan 16, 2006 | 05:41 PM
upstatemax's Avatar
Vise grips FTW!!
Old Jan 16, 2006 | 05:42 PM
TPenguin's Avatar
Got Penguin?
I would use either Vise Grips as stated above OR get some Craftsman RoboGrips... they work wonders on rounded bolts... Also if you use the vise grips you can then use a rubber mallet to help "turn" the bolt once its clamped on the bolt... Hope all goes well...
Old Jan 16, 2006 | 05:50 PM
theMax's Avatar
If it is really stripped try a size smaller socket, you may have to take a file to it to square up the edges, use a breaker bar or impact gun.
Or get some vice grips and get on as tight as you can, then hit it with a hammer. impact is the key, but you must get a good grip with the vice grips (then you will have to get a new nut of course).
Old Jan 16, 2006 | 05:56 PM
teddibear703
ok... it was seriously stuck... i used PB many times on it and never worked. I even tried a 2 part epoxy, gluin the socket to it and it still didnt work.
What worked was i went to osh and bought the craftsman BOLT out/ NUT out tool. Its like a socket but its reverse threaded sort of and it catches like teeth. I turned it a few times and as you turn it more it bites deeper into the nut. Finally it moved a little and from there it came out no problem.
Thanks for the help, I highly recommend the craftsman tool. It took less than 10 seconds to get it out, when i spent over 2 hours on it with other tools.
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
knight_yyz
Nov 1, 2015 01:34 PM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
