I hate the Power Window... arrrggghhh
Always had problems with it during the winter... too slow up and down (yeah yeah... i had not found the famous silicon spray to try solving this problem) but now things are worse!!
We had a drastic temperature change here in CT few days ago (from 50f to 15f) and my freaking window was frozen.
When I finally got it up and down (after breaking the ice on the weather strips by the door) it started to make some GRINDING noise. I thought it was only ice inside the motor or wherever and that once it got warm enough, noise would go away.
NO NO NO !!! it is 58F today and the window still grinding up and down!! WTF ??!!
It is like sand is grinding against the window OR the motor has some sand in it. Or at least sounds like that. It really grinds... scractches.. or however you wanna call it.
I am trying to avoid removing the panel, so anyone with suggestions?
Thanks in advance!
BB
Thanks in advance!
BB
Hi Dude,
I have the exact same issues under my post titled "Power Window Grinding Issues". If you don't mind, could you reply to this message and point to mine so we don't duplicate threads?
Mine sounds like someone dumped sand into the window area. It happened the very day it went from 57 to 6 degrees overnight here. We need a resolution before we lose the motor!
Thanks...
Thanks...
Freakin weather turned into icy cold in less than few hours.... now my window that ALREADY was slow (5th gen issue i guess) it is freakin GRINDING pretty loudly.
Wheres your thread?? I need to know if u found the solution!
If nobody yet solved this thing, what i'll do is roll down window and try to clean the rubber strips and MAYBE throw some hot water in there... but i am not sure if that would damage the internals...
****, i dont really want to open the door panels just to clean this thing.... any top secret tip?
Later
Originally Posted by Lontar1
just clean the rubber reallly good and a silicone lubricant......
I tried looking for that in the past... no lucky. None of the stores had this "silicone lubricant spray"
Where do i find it?
Where do i find it?
Where do i find it?
I got mine at autozone, made by STP I think.
i have a 2000 maxima se and i have a similar problem On mine when i hiy the switch to let the front window go up by itself on auto, it goes up but then it comes back down half way. it only seems to do this when it is warm outside. when it is cold it does not do it. i greased the mechanism in the door and it took the sqealing away but it still goes up and down like this. Flaw with fifth generation i think
this is common to any cars with power windows, however trying to do with icy condition outside i would not try to do the windows if they are going down, you definitely can burn out the motor. as For Silicon spray as suggested in the forum is greatly encouraged to do so.
Lost here. Not only i cant find it on the stores but Autozone.com DOES NOT SEEM to have it. Below is my search results.
Search Results
Search Term: silicone lubricant spray
Searched: Entire Catalog
ACCESSORIES
Silicone Vacuum Hose 10mm 6 ft. Blue
Silicone Vacuum Hose 10mm 6 ft. Red
Silicone Vacuum Hose 10mm 6 ft. Yellow
Silicone Vacuum Hose 4mm 6 ft. Blue
Silicone Vacuum Hose 4mm 6 ft. Red
Silicone Vacuum Hose 4mm 6 ft. Yellow
Silicone Vacuum Hose 6mm 6 ft. Blue
Silicone Vacuum Hose 6mm 6 ft. Red
Silicone Vacuum Hose 6mm 6 ft. Yellow
Silicone Vacuum Hose 8mm 6 ft. Blue
Silicone Vacuum Hose 8mm 6 ft. Red
Silicone Vacuum Hose 8mm 6 ft. Yellow
Silicone Vacuum Hose Kit 10 ft. Of 4mm 5 ft. Of 6mm 2 ft. Of 10mm Blue
Silicone Vacuum Hose Kit 10 ft. Of 4mm 5 ft. Of 6mm 2 ft. Of 10mm Red
Silicone Vacuum Hose Kit 10 ft. Of 4mm 5 ft. Of 6mm 2 ft. Of 10mm Yellow
1 Gallon Sprayer/Hose
12oz Bug & Tar Remover Spray
16oz Trigger Spray Bug & Tar Remover
Brymn B-12 Carburetor Cleaner Spray
Express Shine Spray Wax
Gunmout "Xtra Carburetor Spray
Leather Spray Protectant
NXT Generation Spray Wax
Nxt Generation Spray Wax
Recharger Kit Spray
Rust Easter Spray Penetrant
STP Throttle & Air Cleaner Spray
VP Carburetor Spray Cleaner
ACCESSORIES
Recharger Kit Spray
someone please tell me exactly what the labes says on the spray can??
Thanks again
Not sure why you're having such a hard time find it. I bought a big yellow aerosol can of it in the automotive section of walmart. I don't remember the name of it but I believe its a yellow can with a black cover. Works like a charm.
TKHanson
Nov 24, 2018 01:39 AM
you can also use the Seafoam one....
