Any Fellow 5th Geners Have Sirius? How Do You Have It Mounted?
Old Jan 21, 2006 | 10:30 AM
Dust N Bones's Avatar
I have the Starmate and I was wondering how I could mount it so it looks clean. I don't like the ugly bulky suction cup thing that came with the car kit. I was wondering how other 5th geners have their satellite radio receivers mounted and how and where they ran the antenna.
Old Jan 21, 2006 | 11:34 AM
Edward Lee's Avatar
Here's mine. I ran the antenna behind the dash to the driver's side, then down the left side of the car to the trunk. From there, I ran it outside the trunk, up the window channel and to the top center of the rear roof. The antenna tucks under the rubber seal all around the rear window. Do this and it'll look just like factory.
[IMG][/IMG]
Old Jan 21, 2006 | 11:35 AM
Slow Moe's Avatar
I have mine right on the trunk lid .
Old Jan 21, 2006 | 12:47 PM
ressling's Avatar
HOOSIER Daddy?
http://forums.maxima.org/showthread.php?t=449393
Old Jan 21, 2006 | 12:52 PM
super6's Avatar
starmate unit on panavise arm...see homepage
Old Jan 21, 2006 | 01:21 PM
MetaOrbit's Avatar
Got Projectors?
I have a kenwood tuner hooked up to my Kenwood DDX7015. I have the antenna mounted on the front dash, either to the right or left of the headlight sensor (can't remember which side).
I did another A33 with a sportster where I handmade a panavise type bracket that mounted the radio to the right of HU.
Old Jan 21, 2006 | 01:37 PM
Super6 your set up is really nice looking. Where did you get that arm and how does it install there? I don't want to drill any holes in the dash.
Old Jan 21, 2006 | 03:02 PM
Igor911's Avatar
Old Jan 21, 2006 | 09:56 PM
pekingmonkey's Avatar
There are websites that make brackets for xm/sirius satellite radio units. They mount using the existing radio holes behind the dash, and it comes out like an L. They are custom fit for a maxima. Try this website: http://www.pro-fit-intl.com/xmradio/
Old Jan 22, 2006 | 12:24 AM
lexusviper84's Avatar
i have mine mounted above the HVAC vents in the center of the dash...didnt want to use the suction cup thing either so i used heavy duty velcro and cut it just smaller then the sirius tuner...looks clean and is stable
Old Jan 22, 2006 | 04:15 AM
Originally Posted by Igor911
How is the reception with the antenna in the front window? Did you run antenna wire through the vents?
Old Jan 22, 2006 | 06:11 AM
HotshotVQ35's Avatar
i ran the ant thru the glovebox, around the weather stripping on the door and put it on the rear deck
Old Jan 22, 2006 | 07:34 AM
bugbite77's Avatar
Bump, how is the reception?
Old Jan 24, 2006 | 01:36 PM
Ariakas's Avatar
I have the H2E Kenwood Sirius reciever and have it mounted via provided suction bracket. It's setup in the lower left corner. I ran the antenna underneath the plastic wire loom cover by the doorsills and into the trunk, then mounted to the decklid. For the moment I am using the cigarette lighter to power it until I can do a proper hardwire to the fuse box.
Old Jan 24, 2006 | 02:03 PM
dkp's Avatar
dkp
I have my antenna mounted simular to Igor911 up on the center of the dash. I have had it for a couple of months and have seen no problems with the reception. The reciever is mounted just like lexusviper84, above the HVAC vents with some velcro. I was able to tuck the power wire into the crease between the trim and the dash down to the cig lighter since I have not had time to hard wire the power. I also have a dash cover that works really well at hiding the wiring. I have had problems with getting a clear signal from the Sirius FM modulator, I was getting alot of static no matter which frequency I tried. I don't know if this was caused by the Sirius unit or the crappy reception that the factory HU has. I solved this by using one of those audio tapes that allows you to plug into an external audio source. It sounds so much better now!
Unclejunebug
Apr 2, 2016 05:42 AM
Pnjboyzz
Nov 16, 2015 12:27 PM
Pnjboyzz
Oct 7, 2015 10:47 PM
sliptap
Sep 30, 2015 05:57 AM
