Subframe aka Suspension Member installation?
Old Jan 21, 2006 | 06:35 PM
steven88's Avatar
Need A Light?
How hard is it to remove and install the Subframe/suspension member on a 2k2 max? I took a look under the car and I see the engine cross member, two control arms, and a few other bolts that hold this suspension member in place....is there anything else that I'm missing? I also took note that the bolts holding the suspension member to the frame, is torqued quite high...some upwards of 100ft-lbs....and so are the control arm bolts
I don't have access to a lift and don't have air tools...if I do the install, it will be done with hand tools and an 18.75 inch 1/2 drive breaker bar...can someone tell me if this is a DIY installation? Thanks
Old Jan 21, 2006 | 08:23 PM
rbrown81's Avatar
But why is teh Rum gone?
Call Jeff at maximum tuning. He took mine out to put the new Motor mounts in.
Old Jan 21, 2006 | 08:24 PM
rbrown81's Avatar
Unless of course Im thinking of the wrong thing...
Ah crap I think I am.
Old Jan 21, 2006 | 08:53 PM
steven88's Avatar
Need A Light?
yeah you are...you are thinking of the engine cross member...I'm talking about the SUSPENSION member aka subframe member
I already know how to remove the engine cross member anyway...its a breeze
Old Jan 22, 2006 | 12:33 AM
scopium
WTF did you do now? Dude seriously, you need to stop working on your car. Leave it to a qualified mechanic. I heard you bought the same supension bolt like 3 times in a row at the dealership!
Old Jan 22, 2006 | 08:51 AM
steven88's Avatar
Need A Light?
umm okay? anyone else got input on this?
Old Jan 22, 2006 | 11:23 AM
MaxBoost925's Avatar
Drug Money
I don't think its hard, you just need a partner to help you hold it while you unbolt it.
Old Jan 22, 2006 | 02:33 PM
Larrio's Avatar
The Definitive AE Master
I would recommend at least a impact wrench, those suspension bolts are very tight.
Take a look at the FSM to see exactly what you need to remove in the process. There are only four bolts holding the subframe up.
MaxLife17
Jun 27, 2019 01:37 PM
boomerbrian
Sep 4, 2015 08:25 AM
Johnny9595
Sep 3, 2015 05:18 AM
iflexsteel
Sep 2, 2015 08:04 AM
A32goldylocks
Sep 2, 2015 06:39 AM
