Awful Fuel Economy - What else can I try?
Old Feb 1, 2006 | 05:58 PM
  #41
Moreno's Avatar
Originally Posted by Jaws
You probably are getting really crappy mileage. Are you getting 17.5 miles per US or imperial gallon? BTW, if you are quoting metric consumption, its in litres/hundred km, not km/L.
FWIW Here's the consumption I usually get (L/100 km)
8 is good highway, 9 is average/winter highway, 10 is combined, 11 is city.
Yeah I know, I'm getting 12.5L/100Km = 8Km/L = 17.5mpg
Old Feb 1, 2006 | 06:00 PM
  #42
Hoooper
Originally Posted by bigEL
Had Nissan moved to direct ingition by 2000? When my old car suddenly got bad mileage, it turned out to be a bad distributor.
no dist, electronic. i thought i got terrible mileage but i get AWESOME mileage compared to you guys, about 18 almost all city. to whoever was asking why they get bad mileage when they only do short trips, short trips mean that the car is too cold and not reading the sensors, which means worse mileage because its pretty much not listening to the O2 and all that stuff that makes mileage better.
Old Feb 1, 2006 | 06:10 PM
  #43
YuAnChen's Avatar
Just a newbie question where is PCV Valve
Picture please I have an 01
thanks
Old Feb 2, 2006 | 09:42 PM
  #44
arslaan's Avatar
hmm....I was gettin bad economy but it was my MAF; but what i would do is
1) try different brand of gas...BP's gas may give you much better fuel economy
2) try putting about 2-3 oz of acetone in with the gas on a full tank of gas.
3) don't forget, sometimes after an ecu reprogram, you have to wait a couple hundred miles
4) check your exaust system like cat and precat. seems like youre fine on the intake side of things, since everything is new or you just checked it. do you pass emissions?
and since its winter, sometimes your fuel economy goes down due to temperature because cold air is denser and your ecu will try to match lower pressure with more gas
Old Feb 3, 2006 | 05:07 PM
  #45
YuAnChen's Avatar
Originally Posted by GBAUER
That and possibly a clogged cat as well. Are you also losing a lot of power?
How do you fix clogged cat ?
thanks
Old Feb 3, 2006 | 06:52 PM
  #46
bigEL's Avatar
Originally Posted by spirilis
Nissan's used Direct Ignition since at least the 3rd gen days, maybe before? I know they started using it in a number of platforms since the late 80's.
Wow! That's an amazing, considering Accord and Camry didn't move to direct ignition until the current generation, and not even across the board.
Old Feb 3, 2006 | 10:45 PM
  #47
Anarchist's Avatar
You might want to look through this thread: http://forums.maxima.org/showthread.php?t=445402 for more suggestions. Good Luck.
Old Feb 5, 2006 | 01:35 PM
  #48
Jibberish18's Avatar
If you guys come up with anything post it because my girlfriends car gets horrible mileage too.
Old Feb 5, 2006 | 01:49 PM
  #49
NmexMAX's Avatar
dot dot dot ...
There are nearly 50 posts in this thread, why don't you try reading some of them?
Old Feb 5, 2006 | 08:48 PM
  #50
cpuguy06's Avatar
are you guys all talking about mileage according to the trip computer, or actual math mileage. I have found, like most people, I think, that the trip computer is pretty consistantly off by about 2MPG.
Old Feb 5, 2006 | 08:53 PM
  #51
Warik's Avatar
I'm talking about math... # of miles the odometer divided by gallons of gas pumped.
Which still suck for me as of last fillup... so PCV valve did nothing for me.
Any other ideas?
Old Feb 5, 2006 | 09:04 PM
  #52
cpuguy06's Avatar
wow, i just got back from a trip, and the best mileage on highway is 25, with very little luggage, doin 85. about 16-17 in town also. 40k miles
Old Feb 7, 2006 | 04:37 AM
  #53
I did, thanks for pointing them out.
I meant if someone finds a common part that is causing bad fuel mileage in all of your cars rather than random suggestions such as winter fuel and PCV valve, please mention it.
Old Feb 7, 2006 | 09:48 AM
  #54
trigger005's Avatar
They're not "random" things. Winter fuel and PCV can very well effect gas mileage... however most likely not to the extent of low teens in mpg.
If you're getting that kind of gas mileage, if there is a problem (there even may NOT be a problem) it will most likely be a faulty O2 sensor, MAF, or ignition coils. But, those things should throw a code. Otherwise you can get and OBD II and diagnose a problem the manual way.
Old Feb 7, 2006 | 11:51 AM
  #55
Nomad's Avatar
Also depends on how many times you start your max/day. I noticed like 5 miles decrease/quater tank since i started to go to school. The best mileage I ever got on my max (highway) was 26 mpg. going 75 w/ full trunk and two chicks in the rear. I bet I can get more ASAget my rear calipers fixed.(pads are constantly rubbing rotors.) yeah check if your rear wheels get dirty faster than front. Could be a sign of my issue
Old Feb 7, 2006 | 06:31 PM
  #56
NmexMAX's Avatar
dot dot dot ...
Obese women will decrease gas mileage significantly.
Old Feb 7, 2006 | 06:38 PM
  #57
Anarchist's Avatar
Check out that thread that I posted. I just calculated my MPG after it being 15-17 avg for about 3 months - it is now 20 (based on one tank, no averaging) with about 25% highway and about 50% being 5 minute trips to school etc. and the rest being quick trips around town running errands etc.
If you're too lazy to look - I got that increase by going to my dealership and getting my ECU reprogrammed, getting a 17º timing advance (now using premium fuel instead of regular), and getting a dragging caliper replaced.
Old Feb 7, 2006 | 07:16 PM
  #58
Nomad's Avatar
I think it's time to visit my fella @ the stealership.
P.S. have it really increased?
Old Feb 8, 2006 | 03:46 AM
  #59
Anarchist's Avatar
yes, it really has increased.
Old Feb 8, 2006 | 04:16 AM
  #60
spirilis's Avatar
Yeah, Nissan was definitely a pioneer in that arena. And the coils used to fail back then too
A technique I read about on nissanexa.com (EXA = non-US name for the Pulsar NX, aka N12/N13 chassis) was "cleaning" the coil packs. The technique was to thoroughly clean all carbon crap off the coil packs and their rubber sheath in the possible event that ignition shorts were causing them to fail.
Old Feb 8, 2006 | 10:22 AM
  #61
qballjr13's Avatar
Are those fuel system/injector cleaners that they offer at quick lube oil places worth it or are they crap? I know Nissan doesnt recommend any type of fuel additives but....
Old Feb 8, 2006 | 03:14 PM
  #62
Nomad's Avatar
I don't trust it. But every oil change use a bottle of Chevron/Techron.
Old Feb 8, 2006 | 04:27 PM
  #63
cabernet's Avatar
Is there a way to tell if your calipers aren't releasing? I get about 40K on my rear brakes (much less than the front brakes). Also, get about 20 MPG combined city/highway.
Old Feb 9, 2006 | 12:36 PM
  #64
Nomad's Avatar
If the rear wheels get dirty faster than the front your brakes do drug. Also when you driving it feels like power loss or that smn' holds your car's a**.
Finally I'll get rid of this problem!!! My brembo torors just arrived!!!
P.S. I'll snap some shots to show how big is the diff. between rear & front.
Old Feb 10, 2006 | 03:24 AM
  #65
getbigtony's Avatar
the PCV valve is part of the emmisions system. It recirculates exhaust gas through the cylinders to help with combustion. Don't listen to the other guys above this post. Miricle fluids never work. You can also try checking your tires out as well. Are they full? Do they show any weird wear?
uhh PCV = Positive Crankcase Ventilation...
i think you are referring to EGR = Exhaust Gas Recirculation
hah! i still remember my crap! i should go take the ASEs and become certified. that way i'll be of more help to the forums
well i get bad gas mileage too.. but never that low. i had 16 before and that was from an intake leak. check for it. now i get like 19. when i drove a whole day up to JFK goin around 80-85mph the whole time i got 25mpg!
when i drove to edison on parkway i got 23 goin 80mph
just varies a lot. i guess those mile ratings are really rated at high speeds in 5th gear or 6 gear if thats wat u got.
Old Feb 13, 2006 | 07:25 PM
  #66
Judas
I saw a Maxima Owner that had replaced the Crankcase ventilation tube with two small Intake filters. What are the benefits?
Old Feb 13, 2006 | 09:25 PM
  #67
NmexMAX's Avatar
dot dot dot ...
Less blow-by in the TB/IM.
Old Feb 16, 2006 | 01:01 AM
  #68
SilverMax_04's Avatar
Lower Sulfur Gasoline has Maintenance Implications
Lower sulfur content in gasoline will be here by March 1, 2006. Read the details of this change and the implications that the change has for OCI and exhaust system life on my new posting in Fluids & Lubes.
http://forums.maxima.org/showthread.php?t=456754
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Forge277
Jun 13, 2016 09:26 PM
msellas
Sep 23, 2015 09:16 PM
