Exhaust Parts
Old Jan 31, 2006 | 10:27 AM
carsarecool's Avatar
Exhaust Parts
I read the stickies but still have a question, where do the O2 sensors in the OE y-pipe go when you install an aftermarket one, and how do you keep the CEL from coming on? O2 simulators?
Sorry if its an obvious answer but all the y-pipe questions are about "which one is better which one should i get what works better with a 5.0 or 5.5 gen " that kind of thing.
Old Jan 31, 2006 | 10:33 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Answer is right here.
Old Jan 31, 2006 | 10:55 AM
upstatemax's Avatar
I used a simulator when I installed my headers. some extend them past the main cat.
Old Jan 31, 2006 | 07:40 PM
Hoooper
he said y-pipe i think. i put mine on the O2 sensor hookup closest to the original place. (i think it ended up being on the other pipe but im not sure). i dont think your CEL should go on no matter what side you put it on, unless you didnt put it on...
Old Jan 31, 2006 | 07:52 PM
Puppetmaster's Avatar
The aftermarket y-pipe (Cattman, Stillen, Warpspeed, Budget, whatever) should have the corresponding bungs for the O2 sensors. You do not need an O2 sim for a y-pipe install.
Old Jan 31, 2006 | 09:29 PM
Oh so even though you eliminate the pre-cats, you can screw the O2's right back where they were and it doesnt mess up the readings?
Old Jan 31, 2006 | 09:32 PM
Hoooper
WHAT?????? you didnt put on a y-pipe if youre eliminating the pre-cats.
Old Jan 31, 2006 | 09:33 PM
Mass_Media's Avatar
Mass_Media™
On 00-01's it elimates the precats. 02-03 you have to get headers.
Old Jan 31, 2006 | 09:47 PM
Hoooper
i thought we were talkin 02+, my bad
Old Jan 31, 2006 | 10:07 PM
Mr. Blue Sky's Avatar
damn, now I need to find a place to get a y-pipe. Any good y-pipe should come with the bungs already there for the sensors
Old Feb 1, 2006 | 06:36 AM
Depends on if the car is FED or CALI spec actually. On the FED spec 00s you are removing both precats when you install an aftermarket y-pipe. The CALI spec 00s and 01s (which are all CALI spec) still have one precat between the front manifold and the y-pipe, but you are doing away with the rear precat. On the 02-03s (which are all CALI spec) both precats are between the manifolds and the y-pipe, so you're not eliminating either of em with an aftermarket y-pipe.
Old Feb 1, 2006 | 06:40 AM
I know someone local with a CALI spec 00 who installed a Cattman y-pipe and he doesn't have any CEL or codes.
Old Feb 1, 2006 | 06:45 AM
upstatemax's Avatar
Originally Posted by Puppetmaster
Depends on if the car is FED or CALI spec actually. On the FED spec 00s you are removing the only precat when you install an aftermarket y-pipe. The CALI spec 00s and 01s (which are all CALI spec) still have one precat between the front manifold and the y-pipe, but you are doing away with the rear precat. On the 02-03s (which are all CALI spec) both precats are between the manifolds and the y-pipe, so you're not eliminating either of em with an aftermarket y-pipe.
I still have to disagree with you on that, I swear on my 00' cali spec the front pre cat is in the y-pipe.
I am pissed I forgot my camera for the header install.
Old Feb 1, 2006 | 07:00 AM
Well, and once again, my info is from the following links:
http://www.desertpearlmax2.homestead.com/Fed_YPipe.html
http://maxima.theowensfamily.com/tsb/NTB02-051a.pdf
I will also try to contact someone local with a CALI spec 00 to see if I can get pictures for ya.
Old Feb 1, 2006 | 07:58 AM
upstatemax's Avatar
Damn, your right...
I forgot all about the huge five bolt flange on the B2 manifold. It was never a deal for me because everything came off. I also never really knew that there were different y-pipes for CA and Fed, I think I have only seen a pic of the Fed one that runs up to the manifold so I forgot all about that damn flange.
We also never seperated the B2 precat from the y-pipe when we pulled it so it was one big piece when we tossed it.
Old Feb 1, 2006 | 08:06 AM
Damn, your right...
Glad we finally agree...
MAXSE5SPD
Sep 17, 2022 04:00 AM
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
Justin Kroll
Sep 2, 2015 11:06 AM
A32goldylocks
Sep 2, 2015 06:39 AM
