Random Technology High Flow Cats..Yay or Nay?
Old Feb 3, 2006 | 02:53 PM
Maxi113's Avatar
I was thinking about replacing my stock cat with a random technology high flow one, but will it still be emission legal? I haven't heard anything about these for our cars..Are they worth getting?
Old Feb 3, 2006 | 02:55 PM
upstatemax's Avatar
Why? not being a smart azz. If you are looking for power, it will not help. I only replaced mine with a highflow because mine was bad and the highflow was much cheaper than a factory cat.
bighunt's Avatar
I've had mine in for a few years now. no problems w/inspections or anything else.
worth getting? there's probably very little power difference. but, i bought mine when i got my cat-back system.
Old Feb 3, 2006 | 03:01 PM
steven88's Avatar
Need A Light?
if you run a search on the org...you'll see many owners of this cat have bad luck...like the honey combs fail and fly right out...
Old Feb 3, 2006 | 03:04 PM
irish44j's Avatar
retired moderator
no power gain over stock cat = why bother. Save your money for something worthwhile.
Old Feb 3, 2006 | 03:05 PM
merovi's Avatar
I have heard that they do not really free anything up because our cat isn't like most other cars, most of us have pre-cats so the main cat is a little free'er flowing.
If your looking for a pipe to replace your cat, I currently have a SS test pipe f/s. I do not know brand but its looks to me likes its in good conditions. You can me if you want.
Old Feb 3, 2006 | 03:08 PM
Maxi113's Avatar
Nah I used to have a test pipe on my max it was too noisey..Thanks anyway. Yeah I was just curious to ask since I haven't heard anything on these locally. Thanks for the input.
Old Feb 3, 2006 | 04:06 PM
GBAUER's Avatar
Get a cattman if you're going aftermarket. Redline sells them. Corey told me that someone else actually makes it for catman, but i can't remember who at this point. Regardless, the thing is really, really well built. Far better than stock. However, don't expect any extra power. I only got mine because I killed my last one.
Old Feb 14, 2006 | 06:34 PM
Cleck02's Avatar
What is the difference between a test pipe and high flow cat? what are the ups and downs to both. Right now I have injen CAI and greddy evo2 Catback. Also have hotshot headers which have not been installed yet.
Old Feb 14, 2006 | 09:19 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
I've had a Random Tech cat on one of my previous cars and the honeycomb substrate collapsed and basically clogged the cat. I bought a brand new Catco cat from wrenchead.com (I think, its been AGES since then) for around 70 bux and has it installed for 40 bux to get my car to pass emissions.
Personally I do not have any cats on my car, and my car isn't very loud even with headers- BUT that is a personal opinion. Downside to it is, the smell from the exhaust can give you some headaches with the windows down. My OEM cat failed around 70K miles or so... I have been runing a test pipe for over 70K miles now, and got a bit over 140K on my car now.
Old Feb 15, 2006 | 12:34 AM
Jibberish18's Avatar
You're fine in Illinois. I have a Random Tech replacement cat for my Focus. The cat is right under my header and it's been doing fine for over a year (although it's not a universal but a whole replacement piece.) It's also doing fine in terms of rust. No rust at all. Not bad for being non-stainless steel. Besides when your car is 2000 or higher I don't think they even put you on the dyno. I don't know if it'll make much of a difference in performance. Maybe in sound. If you want a replacement that is like OEM try CarSound cat (by Magnaflow). Found dirt cheap on ebay.
Old Feb 15, 2006 | 06:17 AM
markmaxima's Avatar
i have a question for you, i bought a race pipe from custommaxima.com, it replaces the cat, besides not passing inspection, is there anything else i should be worrying about ex smell, noise etc thanks
Old Feb 15, 2006 | 07:13 AM
2K3MAX2NV's Avatar
"tse-tse fly"
make sure you get the correct gaskets cuz mine didnt fit correctly and it made alot of noise (bees in a can)
Old Feb 15, 2006 | 07:20 AM
n3985's Avatar
大陆弟弟
Which is? The Cattman one?
Old Feb 15, 2006 | 09:16 AM
spastic's Avatar
Not to hijack your post but since it was mentioned frequently here I thought I'd ask. What are the symptoms of a failing or failed cat?
Old Feb 16, 2006 | 04:33 PM
03maxima1's Avatar
Stick with stock until it fails, then replace it.
TallTom
57
Oct 14, 2025 05:16 PM
Apr 16, 2020 05:15 AM
maxinout93
Oct 31, 2015 02:04 AM
