How do you get the VIAS box off?
Old Feb 6, 2006 | 09:02 PM
carsarecool's Avatar
I read the stickies and was going to try the JB fix but i cant seem to get the box off, im trying tomorrow with a screwdriver bit and breaker bar but those things are on there TIGHT- also what about the bottom two screws, i remember someone saying they didnt need to move the TB to get it out but i cant see a way of doing that without taking off the throttle body, and some hoses that are in the way of the other bottom screw. If anybody has pics or anything thatd be appreciated- thanks
Old Feb 7, 2006 | 06:05 AM
igzy's Avatar
I Know Kwaliti
I did not take the TB off when I did it, though I did read of some members doing it that way, I found it unnecessary... Some have used wise-grips to take the screws out. I used a large Phillips screwdriver (I think it is #2, it was the largest in the set )...
Old Feb 7, 2006 | 07:57 AM
upstatemax's Avatar
Do you even know if it IS broken?? IF you search around there are ways to find out if the rod is broken or if it is fine without removing the VIAS.
Old Feb 7, 2006 | 09:15 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
no need to take the TB off to remove the screws.. the screws are tight as hell and are a pain. Get the longet baddest screw driver available to do it the screws are like cheese so be careful....... you can also use some vicegrips to finish it. I did....
Old Feb 7, 2006 | 08:51 PM
Yeah from reading the FAQ's and other peoples questions i just wanted to see what was goin on in there and try the JB fix- i'm almost 100% sure its broke, theres a power drop off after 5-5500 rpm's and it doesnt feel worth shifting higher than 5k, like a waste to wind it out all the way.
Old Feb 7, 2006 | 10:24 PM
rule da road's Avatar
man i had some trouble. stripped some screws. i went to nissan for my intake, saw the work i did with disconnecting a few wires - they almost didn't let me leave. Theres FUEL around there!! Could ignite and BOOM!! luckily it was on tight enough fixed a few things but I AINT MESSIN WIT MY VIAS!! After about 5500 im lowered power but higher gears DO me fine. Nissan senior tech suggested DONT mess with the VIAS!
Old Feb 7, 2006 | 11:07 PM
YuAnChen's Avatar
How to find is it broken or not ?
Old Feb 8, 2006 | 07:58 AM
nicks79's Avatar
Fuel in VIAS, what the hell did you do?
Old Feb 9, 2006 | 08:17 PM
YuAnChen's Avatar
Anybody can answer my question ?
How to find is VIAS borken or not
Old Feb 9, 2006 | 08:49 PM
yeah, fuel? whats up with that?
Old Feb 11, 2006 | 12:07 AM
YuAnChen's Avatar
Still waiting for my question getting answered
Old Feb 25, 2006 | 08:45 PM
jenk01SE's Avatar
dyno run.........
Old Feb 25, 2006 | 08:48 PM
jenk01SE's Avatar
I only loosened the TB and you are correct with the #2 Phillips screwdriver. I used the Visegrips on the HANDLE of the screwdriver while applying lots of pressure into the end of the screwdriver without harming any of the screws.
Old Feb 25, 2006 | 09:54 PM
Well in the process of stripping one of my screws, i decided to actually look at the friggin thing. car was already warm so i started it up and pulled the throttle cable and i saw the solenoid and metal bar thing move back and forth twice when the engine revved real high, is that a definite that its working or is it true the cup and rotator assembly inside is what fails?
I'm wondering cause i'm not really impressed with the top end most of the time, from what i hear the 3.0 with manual should have a pretty impressive top end
Old Feb 25, 2006 | 11:11 PM
spdfreak's Avatar
Don't mind my dumb question, but whats a VIAS box ?
Old Feb 26, 2006 | 11:58 AM
alpinestars™'s Avatar
THIS IS...
Variable Intake Air System. It lets more air into your engine at around 5K for a nice power boost. Its the Hallmark of the VQ engine.
Old Feb 26, 2006 | 12:04 PM
6SpeedTA95's Avatar
Do these VIAS things break a lot? Seems similar to a vtec controller on a honda and its pretty rare that one of those goes south on you.
Old Feb 26, 2006 | 01:15 PM
jenk01SE's Avatar
They do break, proportional with time spent above 5000 rpm.
The VIAS is nothing like a VTEC which varies the cam timing.
Old Feb 26, 2006 | 01:21 PM
6SpeedTA95's Avatar
So if you rev it alot it breaks???? That kinda sucks...anyone have an article or something they can link me to so I can read about this thing?
Old Feb 28, 2006 | 04:46 AM
Cdoc's Avatar
I have a 2K Maxima and I remember it having an impressive top end. I remember liking the Max being better than my old Sentra because when I was doing 60 in the Max I could still accelerate well. Unfortunately those are memories now.
I've been looking at VIAS and MAF threads to see if one of those could bring my memories back to life. It looks like both are supposed to fix the same problem of low top end power. Has anyone done both? Which one gave more impressive results?
Installing a new MAF would be more $ but I think I have a better chance of breaking things that could cost more $$ if I attempt the VIAS mod.
Old Feb 28, 2006 | 05:02 AM
I know what you mean, it can still accelerate pretty good at 60-70 in 5th just cause its in the powerband but the way a VIAS problem is described around here is a "not strong enough acceleration feel past 5k rpm's" like the car doesnt wanna go anywhere, itll still wind out to 6500 but just feels kind of blah doing so.
Have you read all the threads on MAF's? Mine was done last yr, although i think its going bad again. Was gonna change the plugs cause im at 79k miles and a lot of people here do them at 60, but the service advisor told me they dont need to be done til 100000 mi., which suprised me since they usually take any chance to make some $$. Otherwise i cant think of anything that would affect top end performance
Old Feb 28, 2006 | 08:31 AM
Cdoc's Avatar
My tach doesn't go above 5K when I accelerate and once it gets there it stays there until I let off the throttle. It isn't that I have sluggish top end, I have NO top end. I'm guessing this is the MAF and not the VIAS.
I've got 85K on my Max and I still have factory plugs. I think that will be a summer project. It is just too cold out now!
Old Feb 28, 2006 | 08:36 AM
6SpeedTA95's Avatar
Plugs alone shouldn't keep the car from revving but plugs + maf might
Is a plug change difficult on these cars?
trailer54
Nitrous
Nov 18, 2015 07:44 PM
MaxiNoob98
Oct 2, 2015 10:13 PM
King_Ten_Ahead
Sep 27, 2015 02:24 PM
Sep 27, 2015 08:37 AM
