moon roof
Old Feb 7, 2006 | 10:48 AM
JaKillz2's Avatar
moon roof
K simply put, it's not working. I can press either button (the back and forward or crack uncrack) and all it does it move about 2 inches, press EITHER again and it moves about 2 inches. I can do this till its closed. Either button does it and does it the same. If I get it close and press it again, both buttons cause it to crack open. Then crack close. It sounds pretty much electrical but what to do?
Old Feb 7, 2006 | 10:56 AM
kcowden's Avatar
There is a reset function for our sunroofs. Push and hold the button that will open/close the rear section of the roof for about 5-10 seconds and that should reset it.
Old Feb 7, 2006 | 11:03 AM
gold007eye's Avatar
New to the Maxi world...
I just ran into the same problem a couple of weeks ago..
1st - Have you changed the battery or disconnected the battery lately?
In my case.. I was installing new HU so I had disconnected the battery.. when I went to open sunroof.. SAME issue..
You have to "re-learn" the sunroof controls.. If you look at your owners manual (I forget the page)
I did mine without needing the manual.. I think what I did was..
Turn Car on... slide the switch to each click and then back to the "Close" position... then on the crack button I held it for the Up position for 5 seconds and then the down position for 5 seeconds.. then keep pressing that button till it closes.. turn the car off then back on and see if that fixes it.
*I would read the owners manual though (there is probably an easier way)
Old Feb 7, 2006 | 11:34 AM
JaKillz2's Avatar
AWESOME thank you, weird thing is it just randomly started. Oh well, as long as its fixed thank you guys
EDIT: DAMN! Neither worked. tried both and it didnt do anything. do you have to have the car ON or just electrically on. ?
Old Feb 7, 2006 | 12:49 PM
kcowden's Avatar
Not running, just to the "on" postion.
Old Feb 7, 2006 | 01:00 PM
Lethal's Avatar
If you want to perform the sunroof reset here it is:
• If the sunroof is open, press the tilting switch repeatedly toward tilt "Down" to fully close the sunroof.
• After the sunroof has closed all the way, keep pressing the tilting switch towards tilt "Down" for more then three seconds.
Thats exactly as it reads from a sunroof TSB. See if that fixes your problem.
Old Feb 7, 2006 | 02:32 PM
GBAUER's Avatar
Hold the tilt/close button for 5 seconds. It'll clear the problem up. I have to do it once every three or four months.
Old Feb 7, 2006 | 03:28 PM
DrKlop's Avatar
Driving is the next best thing
wait a sec, I disconnected my battery many times but I never had problems with the moon roof?
Old Feb 7, 2006 | 06:07 PM
Hoooper
well your moonroof is a cheater. ive done the same process that lethal said and thats exactly how to do it. i have the TSB right here and thats what it says.
Old Feb 7, 2006 | 07:11 PM
JaKillz2's Avatar
ARGG i cant get it to work god damnit. I cracked it so i could do exactlly what Lethal said. I pressed the "vent close" once to close it to full seal. Then I pressed it and held it for like 10 seconds, it opened though an inch as well though cause after all i just pressed it again... anyways i held it and nothing happened. I tried having it open one click, then closing and holding it instead of letting go and it still didnt do anything. this is all the vent switch too.
Old Feb 7, 2006 | 10:27 PM
ratha77's Avatar
i opened mine 2" by 2" then closed it the same way, left it for like 15 mins, and it worked, just keep playing with it man, what a pain
Old Feb 8, 2006 | 05:08 AM
gold007eye's Avatar
I dunno if it has to be disconnected for a certain ammount of time, but mine was disconnected for 30min - 1hr.. and it did that to me.. I was freaking out thinking I had done something till I read the owners manual and it mentioned that could happen when the battery is disconnected.
Old Feb 8, 2006 | 04:15 PM
Hoooper
o never thought about that. it probly has to be off long enough for the computer to reset or w/e after a couple hours.
Old Feb 8, 2006 | 04:32 PM
JaKillz2's Avatar
disconnecting it worked for me. Had it off bout 30 min
Old Feb 8, 2006 | 04:40 PM
DrKlop's Avatar
gland that you fixed it
It's probably different for 5.0 and 5.5 gens. Notice, everyone who suggested the relearning procedure has 5.5 gen.
Old Feb 9, 2006 | 03:47 AM
gold007eye's Avatar
Not to ***** the thread, but what is the difference between 5th Gen and 5.5 Gen?
Old Feb 9, 2006 | 03:48 AM
gold007eye's Avatar
Glad that worked for ya
Old Feb 9, 2006 | 06:01 AM
maxima57O's Avatar
The 5th gen is 2000-2001, and the 5.5 gen is 2002-2003. In 2002, they upgraded the interior (adding heated steering wheel and navigation as options, I'm not sure if the nav came out only in 03 though). They also ugraded the outside changing the tail lights and the front and also adding HIDs. I think that covers it, the engine got an upgrade too I think. Add stuff if I missed it...
Old Feb 9, 2006 | 06:27 AM
FunLovinMaxima's Avatar
From: a charming town in Connecticut first settled in the 1600s
engine went from 3L to 3.5L!
carguy96
20
Feb 6, 2021 06:21 AM
zzznightmarezz
Sep 21, 2015 06:32 PM
Vequity
Sep 10, 2015 05:26 AM
Jeffesernia11
Aug 23, 2015 06:09 PM
13Maximasv
Aug 7, 2015 10:56 AM
