View Poll Results: Which rims you like better for 2000 SE Maxima?
Stock 17" rims
34
34.34%
04 SE 18" rims
65
65.66%
Voters: 99. You may not vote on this poll
18" 04 SE rims on a 00-03
Old Feb 14, 2006 | 07:30 PM
  #41
irish44j's Avatar
retired moderator
Originally Posted by vsamoylov
its actually a torsion bar not a sway bar.
no, you are referring to the beam axle as a whole (correctly known as the "torsion beam", which includes the pieces that run perpendicular - commonly mistakenly referred to as the "trailing arms") The rear sway bar runs inside of the torsion beam and provides additional stiffness to the entire assembly. Check out your FSM.
so while by name it isn't a "sway bar," technically it really is....
Old Feb 14, 2006 | 07:33 PM
  #42
ayotrick85's Avatar
I promise I'll quit hijacking threads.
Old Feb 14, 2006 | 07:44 PM
  #43
irish44j's Avatar
retired moderator
Originally Posted by AllGo
I respect your knowledge regarding maxima's as you have obviously raced and upgraded your vehicle for mild competition purposes however the bar under the rear beam you speak of is NOT a sway bar. There is absolutely no way that it can create any force against any moving part of the rear suspension or reduce body roll. It serves only as additional mass/strength to the upside down U shaped rear beam.
if that were true, than there would be no such thing whatsoever as an aftermarket RSB for our cars either. Recall that the Stillen/Cattman/Addco/Progress RSBs simply attach to the torsion beam itself (and NOTHING ELSE)....providing additional "mass/strength to the upside down U shaped rear beam"...
As far as my comment of Larger wheels/tires, I wasn't referring to those blinging 19's and 20's, but many manufacturers ARE choosing these as stock sizes on there high performance vehicles. However our modestly powered Maxima's with our sloppy chassis's surely won't benefit from these sizes. I guess I should have mentioned "wider" wheels and "lower" profile tires will enhance grip, turn-in and braking characteristics. I guess the assumption would be that an aftermarket wheel/tire setup would generally offer both.
It's looks, man. If car manufacturers were doing it for performance, all these cars would come with lightweight 16's or 17's, not 25-lb 18's......for example, the 18" G35 wheels on my car are far worse for performance than my 17" 5Zigens. The choice of tire is much more important than the rim size. period. Besides, the G35 Coupe comes with 245/45/18 tires in the back, which is actually a HIGHER sidewall than the stock maxima 225/50/17....
Hell, the VW R32 is generally considered to be "high-performance," right??
Did you know that the factory 18's that come on it weigh a whopping 28lbs each!!!!???? Please tell me how that helps handling or braking?
Grip is directly proporsional to sidewall stiffness and tread tackiness, as is braking.
Old Feb 15, 2006 | 12:32 AM
  #44
spiromax's Avatar
Seoul Man
Last time I checked, this thread was about putting 18'' 6th gen wheels on a 5th gen Maxima. You guys remember how to read, right?
I don't pay attention to who the moderators are around here. I just read and post, and I hope that my own common sense will keep me out of trouble. So far, it has worked out well for me. It's a real shame that threads like this one are being turned into circuses by noob hijackers, whiners, and flamers. If you have a gripe with a person or a group of people in this community, then there are better ways to handle it than to screw up someone else's thread. I'm surprised that at how far this thread has deviated from its topic and how far it has fallen from any sort of constructive discussion, especially considering the fact that a couple of moderators have obviously visited the thread.
I love the Org because it is the Org. If I wanted to read TheVBoard or ClubSi, I wouldn't be here.
BACK ON TOPIC:
The pics of the 6th gen wheels on a 5th gen look nice. Murano wheels don't look bad either. I agree that they look better on a lowered car than on a stock height car, but you'll have to find a tire size that doesn't rub too much after the drop. Personally, I didn't mind the look of my stock 17'' wheels, but mine were a bit more shiny silver than regular 5th gen 17s (Titanium Edition). I eventually wanted a fresh look for my Max, so I switched out my stockers for 17'' 350Z wheels. They don't fill the wheel wells as well as the 6th gen 18s, but they give the car a more aggressive look with a minimal threat of rubbing, and my upcoming spring/strut combo will help fill the gap. The 350Z wheels also have a different offset from the stock 5.5th gen wheels, so they don't seem to be recessed into the rear wheel wells like the stock wheels. I was going to buy spacers for my stock wheels, but I decided not to buy them after seeing how the 350Z wheels stuck out a little farther than the stock wheels. The look is nice.
Old Feb 15, 2006 | 06:47 AM
  #45
vsamoylov
its aactually called a solid beam axle which has a torsion bar in it. and yes its connected with trailing arms.
Old Feb 15, 2006 | 01:52 PM
  #46
Darius's Avatar
back to the topic... where can you get these besides the dealer?
Old Feb 15, 2006 | 02:47 PM
  #47
irish44j's Avatar
retired moderator
not according to Nissan.....but in any case, it's not worth arguing about any more.
Darius, you can get the wheels in the classified section here on the org, junkyards, etc....
Old Feb 15, 2006 | 03:57 PM
  #48
fia_f1's Avatar
... wow ...
omw to 15 ....
Old Feb 15, 2006 | 04:02 PM
  #49
irish44j's Avatar
retired moderator
Originally Posted by fia_f1
... wow ...
omw to 15 ....
you're going to be on your way to if you're not careful
Old Feb 15, 2006 | 04:09 PM
  #50
vsamoylov
dude who knows what nissan call parts these days. everything in their designers heads are screwed up.
Old Feb 18, 2006 | 04:54 AM
  #51
Ammi's Avatar
350 Detroit Muscle
try ebay..
Old Feb 18, 2006 | 06:02 AM
  #52
rbrown81's Avatar
But why is teh Rum gone?
Old Feb 18, 2006 | 08:41 PM
  #53
bugbite77's Avatar
ummm 03 350Z rims
Old Feb 19, 2006 | 04:30 AM
  #54
LeX's Avatar
LeX
Nissan by Nature
I like the G35coupe 18s or Track edition 350z 18s... not too heavy and look good
Old Feb 19, 2006 | 04:33 PM
  #55
Darius's Avatar
how do the 04 SE 18s compare in weight to other stock maxima rims?
Old Mar 7, 2006 | 10:53 AM
  #56
papasuede's Avatar
http://cgi.ebay.com/ebaymotors/Nissa...QQcmdZViewItem
Old Mar 7, 2006 | 04:49 PM
  #57
Teufelhunden's Avatar
yes they will look good only after lowering, and do not get 245/50/18 tires, thats too much side wall. i recommend 235/40/18. it will look much better than the dumb as$ who has the 245/50.....
Old Mar 7, 2006 | 05:10 PM
  #58
MAXRB8's Avatar
Originally Posted by SEmy2K2go
They may not make as big of a difference on the 4th gens, but do A LOT for us 5th gen guys.
I transferred mine from my 4th gen to my 5.5 and noticed a much bigger diffrence when installed on my 5.5 than when installed on my 4th gen, but I did also add 15mm H&R spacers to the rear at the same time, nice!!
Back to the wheels, might want to consider the 350Z forged or Altima Se-r 18 forged at least they are light, most factory wheels tend to be heavy but look good, I have 245/40/18 on 8.5" width 42mm offset with no rubbing issues. 2 cents
Old Mar 8, 2006 | 08:31 AM
  #59
acMAX's Avatar
hell yeah...major difference after the addition of a rear sway..
Old Mar 8, 2006 | 03:32 PM
  #60
Killercam2's Avatar
Bigger the rim.. the better
Old Mar 9, 2006 | 10:10 AM
  #61
BUSi87's Avatar
Anybody got prices on those 04 se rims.... i intrested in getting them wit a 35/30 sidewall cause i already got my JIC suspension...
-ENJOY THE VQ EXPERIENCE-
Old Mar 9, 2006 | 12:27 PM
  #62
Ammi's Avatar
350 Detroit Muscle
I paid ~$500 last year. By the way, wrong size tires. You want 235 or 245/40/18s
Old Jun 26, 2007 | 02:46 PM
  #63
Lupin's Avatar
Originally Posted by 01Black20th
mine were rubbing in the rear on that lil bolt that is attachted to the bumper, just bent it up with a pair of plyers and hasnt rubbed since, even with 3 people in the back goin over some big bumps
what size were you tires which rubbed?
From what i getting on this thread is that the stock 04 SE 245/45/18 will rub so they need to be changed to 245/40/18 or 235/40/18 to eliminate the problem of rubbing on a non lowered car.
Is that the case, anyone agree or disagree?
Old Jun 26, 2007 | 02:55 PM
  #64
Lupin's Avatar
I'm getting a pretty good deal i think on a set of 04 SE rims and tires, 245/45/18 but if they rub on my 03 SE then it's not such a good deal if i have to purchase new rubbers, 245/40/18.
Just want to ensure if this is the case with those stock 245/45/18. if it is then I'm not going to spend the extra cash to buy the 245/40/18. if not, then i'm going to scoop them up.
anyone ?
Old Jul 14, 2007 | 03:53 PM
  #65
pbn85's Avatar
Im on H&Rs right now all around and I'll be getting OEM 6th gen 18s rather soon. I shouldn't have a problem with rubbing in the front b/c h&r drops the car mildly in the front but the rear is another problem...h&rs drop the rear quite a bit. Will I have rubbing issues in the rear?
I dont know too much about tire sizes so what size is recomended? thanks in advance
Old Jul 14, 2007 | 04:00 PM
  #66
Forevermax13's Avatar
What size tire would you need if you wanted to drop a eibach spring on maxima or 350z rim? I was thinking probly 215/45/18 or 235/40/18
Old Jul 22, 2007 | 08:03 PM
  #67
pbn85's Avatar
I used the rim calculator in the stickies and it looks like 245/40-18 is the tire size that will give the MOST accurate speedometer reading. Im picking up 04 SE rims tomorrow for $300 and will get tires later on tomorrow. I will post pics
Old Jul 23, 2007 | 09:51 PM
  #68
MIXXMAX's Avatar
I beg the differ. I believe the 235/40/18 is the closest tire size which will keep the speedometer accurate. I have this type of setup on my 2kSE.
Old Jul 24, 2007 | 03:20 PM
  #69
pbn85's Avatar
just put em on today with new toyo proxes 4 240/45
Old Jul 24, 2007 | 03:32 PM
  #70
Jess's Avatar
SHIFT_In2D
Matches your car nicely!
Old Jul 24, 2007 | 03:44 PM
  #71
pbn85's Avatar
thanks Jess
Old Jul 24, 2007 | 05:57 PM
  #72
nk2k2's Avatar
yeah i have to agree w/ jess that it does look clean. i also think that the g35 wheels work nicely with the silver maxes.
Old Jul 24, 2007 | 06:14 PM
  #73
russianguy's Avatar
What wheels are heavier murano, 04 se or g35 18"
Old Jul 31, 2007 | 04:15 PM
  #74
rmaxima02's Avatar
Just lower the car, and it would look awesome.
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Fbana41
Aug 29, 2016 12:18 PM
Luigi623
Sep 21, 2015 01:42 PM
mikeymouse1995
Sep 18, 2015 06:42 AM
0m3nc0w
Sep 11, 2015 05:21 PM
