3rd gear grind
Old 02-10-2006, 11:27 AM
JaKillz2's Avatar
3rd gear grind
i know it's a known problem, when shifting up into third and the sticks more to the left of the slot it grinds, noise and feel. What is it, is it bad, anything to do about it?
JaKillz2 is offline
Old 02-10-2006, 11:37 AM
Need A Light?
steven88's Avatar
i heard its common on the 2k2-2k3 6spd maxima...
dunno about the 2k1-below 5spd maxima
steven88 is offline
Old 02-10-2006, 12:09 PM
It's business time.
Progress's Avatar
I've missed shifts going into 3rd more than any other gear and more than any other car. I've never grinded though. Is the clutch worn and/or fully engaged?
Progress is offline
Old 02-10-2006, 12:24 PM
JaKillz2's Avatar
yes, well it would be fully dissangaged, its only when you have the rod to the left too much, as if you tried to go too straight up instead of the uprightup motion.
JaKillz2 is offline
Old 02-10-2006, 12:43 PM
Derrick2k2SE's Avatar
A lot of the 6 speed trannys have the 3rd gear grind. Mine is one of them. If I shift into 3rd fast at a high RPM it grinds. It goes in OK but it sounds bad. A lot of them were replaced under warranty. At 97k that's not an option for me though. I'm keeping my eyes open for a used 03 6 speed w HLSD.
I haven't heard anything about the 5 speeds having problems though. The 5 speeds are much smoother shifting. My 95 had almost 200k and shifted great.
BTW JaKillz2, did you figure out why the car wasn't running right the other day?
Derrick2k2SE is offline
Old 02-10-2006, 12:51 PM
OOmaxSE's Avatar
Could be that your synchros are going bad. Considering the part is under a couple bucks, sounds like they could easily get booted. I've heard that it will only get worse if not fixed...
OOmaxSE is offline
Old 02-10-2006, 12:54 PM
Need A Light?
steven88's Avatar
so when you go into 3rd, its smooth? just only a loud grind?
or can you actually "feel" the grind on your shift **** when u go into 3rd?
steven88 is offline
Old 02-10-2006, 01:10 PM
boondoxmax's Avatar
No grind for me. All gears engage smoothly...........
boondoxmax is offline
Old 02-10-2006, 01:12 PM
MAXjersey01's Avatar
my 3rd grinds sometimes when the clutch is fully engaged, doesnt happen near as often enough to worry me though.
MAXjersey01 is offline
Old 02-10-2006, 03:39 PM
HotshotVQ35's Avatar
37K on my 02 no probs at all...
HotshotVQ35 is offline
Old 02-10-2006, 06:06 PM
vsamoylov
i have a 02 trann and i dont have the grind but i can fell that the synchros are weak when i engage 3rd gear
Old 02-10-2006, 06:32 PM
Yeah, it's the 3rd gear syncro. The actual ring is pretty cheap. It's just that the install involves a tranny rebuild. Since I want HLSD any way the easiest thing to do will be to get a newer tranny with HLSD and install it my self.
or can you actually "feel" the grind on your shift **** when u go into 3rd?...
On a fast high RPM shift you can hear the crunch going into third pretty well. Not much feeling through the shifter but the 02 and up have cables instead of a solid linkage like the 5 speeds. Not much vibration gets passed through to the stick. I'm sure I would feel it on a linkage setup or especially a rear drive where the stick is mounted right to the gear box.
Old 02-10-2006, 06:35 PM
vsamoylov
just get a 6 speed from a 6th gen
Old 02-10-2006, 07:09 PM
If it's a direct bolt in and has HLSD I would be game. I found a 9000 mile 03 6 speed with HLSD for $1800 to my door. The insall is no big deal for me.
I just put on headers, S-AFC, Fidanza lightweight flywheel and a stage 3 clutch within the last few months. It may be a while till I can justify spending that kind of money on the car again. If I were single, or looking to be single again, I would have done it.
Old 02-10-2006, 07:36 PM
JaKillz2's Avatar
ya but mines a 2k. It does it like every and its not really random it happens cause i have the stick forced to straight up in the 3rd gear slot instead of the upleftup from second and its just like a split second like you push against the gears and then its gone. And you can definately feel it through the ****
JaKillz2 is offline
Old 02-10-2006, 07:46 PM
How many miles are on your car?
Old 02-10-2006, 11:23 PM
Need A Light?
steven88's Avatar
6th gen 6spd tranny is better i believe...
don't quote me...but i think it has triple cone syncros for 1-2-3...versus double cone syncros on the 5.5 gens (smoother shifts)...and the most important...the 4.1 final drive
steven88 is offline
Old 02-11-2006, 06:47 AM
JaKillz2's Avatar
its got 78k
JaKillz2 is offline
hcarter1112
42
07-18-2022 03:35 PM
aw11power
10-10-2021 04:57 AM
04-16-2020 05:15 AM
knight_yyz
11-01-2015 01:34 PM
Quick Reply: 3rd gear grind
