deciding on front spacers
Old Feb 13, 2006 | 04:04 PM
inspiredbykev's Avatar
You should thank my D***
I plan on buying 19x8 rims. Offset comes in 40. I ordered 20mm spacers for the rear. Should the fronts be flush or do I need to get some spacers?
Old Feb 13, 2006 | 04:29 PM
Ammi's Avatar
350 Detroit Muscle
all depends on what drop you got
Old Feb 13, 2006 | 04:53 PM
cattman/progress coilovers
probably a 2-3inch drop
Old Feb 13, 2006 | 05:06 PM
steven88's Avatar
Need A Light?
I think 8 wide in the rear + 20mm spacers with a 3 inch drop would make your tires rub...
I'm running 8.5 wide rims with 245/40/18 tires...and my rear rims aren't running any spacers...I am about 2.5 inches from stock and the tire comes real close to the outter fender...I'm sure with a 20mm spacer it would easily stick out and rub against it...
So to answer your question...no the fronts will not be flush...if you really wanna use those 20mm spacers...I suggest going for a mild drop and running maybe a 10mm in the front
Old Feb 13, 2006 | 05:34 PM
what mm rear spacers would you recommend with an 8 inch width and a 40 offset?
Old Feb 13, 2006 | 05:37 PM
steven88's Avatar
Need A Light?
prob something mild...i'd say 5mm or 10mm....anything above that and slamming the car will cause u to rub....
if you look at my car...the clearance for the rear tire and the fender is not too much....
you can always try out those 20mm spacers...and since you have coilovers...adjust the ride height to a point where the 20mm would work with your setup...
Old Feb 13, 2006 | 05:50 PM
yea i don't have my car slammed of the roads where I live. Just a clean drop.
I want my rims flush with the fenders.
What would be the best rim offset for the rear on a 19x8 rim for the rear on our cars?
My tire will be a 235/35/19
Old Feb 13, 2006 | 05:55 PM
what offset in your front and rear?
Old Feb 13, 2006 | 06:07 PM
steven88's Avatar
Need A Light?
I have 18x8.5 and 42mm offset with 245/40/18 all around...
your 8 wide with 40mm offset should sink in a "tad" more than my 8.5 wide @ 42mm...just letting u know...thats if you get 245/40/18 tires
Old Feb 14, 2006 | 02:13 PM
I'm going with 19x8 with a 40 offset. I just ordered eibach 15mm spacers for the rear. Tire size will be 235-35-19.
The Frye
Sep 2, 2021 11:03 AM
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
Maxima30
Sep 7, 2015 06:13 PM
