Remote Starter Kit
Old Feb 16, 2006 | 02:53 PM
trigger005's Avatar
Remote Starter Kit
Looking to get a remote starter kit to go along with the stock remote. Anyone have any recommendations?
Is this hard to do? I think a bypass kit will also be needed for the alarm system? Even if I could do this will it come out looking bulky as hell?
Old Feb 16, 2006 | 03:10 PM
Kruppa's Avatar
You will need a spare key for it to work
I have the Compustar 2W900FM model with a lifetime warantee and I love it.
It's an alarm/remote start specifically made for manuals
If you have a manual like me...
The car must be in neutral and the e-brake up for the remote start system to work...when ur in the car u put up the ebrake and put it in neutral and then the system engages and you take out the key (car remains running)...once the last door is closed the car automatically turns off and locks...if at any time between then and the next time you go to remote start it, any door was opened, the car will not remote start as a safety precaution in case somebody else went in your car and left it in gear...If you have a standard this is a great option and to my knowledge it's the only remote start system that can be legally installed in a car with manual transmission.
Igor911's Avatar
check the ICE section.
You can get a DEI Valet that will activate remote start on double-pulse lock of the stock remote. Yes you will need a by-pass for the chip in the key.
Old Feb 16, 2006 | 03:12 PM
Igor911's Avatar
I have the Compustar 2W900FM model and I love it.
If you have a standard like me...
The car must be in neutral and the e-brake up for the remote start system to work...when ur in the car u put up the ebrake and put it in neutral and then the system engages and you take out the key (car remains running)...once the last door is closed the car automatically turns off and locks...if at any time between then and the next time you go to remote start it, any door was opened, the car will not remote start as a safety precaution in case somebody else went in your car and left it in gear...If you have a standard this is a great option and to my knowledge it's the only remote start system that can be legally installed in a standard.
OR
You could tap pin 44 (grn/wht) at the ECU and it wont start at all if it's in gear. Just tap that to the Nuetral Tranny Switch wire from the alarm
Old Feb 16, 2006 | 03:23 PM
cpuguy06's Avatar
im sry for typin in all caps...but...YOU CAN GET A REMOTE START THAT WORKS WITH TWO TAPS OF THE LOCK ON THE FACTORY REMOTE???? For 2k2 were talkin here right?? Also on topic, I have a Viper(DEI) 771XV that i put in myself using the maxima.theowensfamily guide and it works great.
Old Feb 16, 2006 | 03:25 PM
00MaxATC's Avatar
I have CompuStar also I highly recommend it because of the range and the ability to interface with a manual.
Old Feb 16, 2006 | 03:27 PM
Igor911's Avatar
yes, I had it that way on my 2000
Old Feb 16, 2006 | 03:29 PM
cpuguy06's Avatar
do u know if it works for the 2k2 as well?
Kruppa's Avatar
Originally Posted by Igor911
OR
Yah good point but I like mine because it's also a full alarm system and it has incredible range...the factory remote sucks for range...I get a full half mile range with my Compustar setup...good if you're in a building or something because the stock remote never works from inside a bigger building or from any reasonable distance which is something you want for a remote start usually so it's warm by the time you get there...unless of course the only time you'd use it is if you're right at your house in the driveway but that's not the case for me.
Old Feb 16, 2006 | 06:26 PM
03maxima1's Avatar
Best buy has one for 160 installed. But you will pay extra for the immobilizer. Strictly remote start and keyless entry.
Old Feb 16, 2006 | 06:43 PM
maximillien's Avatar
Keep it DEI only you'll thank urself later on
Old Feb 16, 2006 | 06:49 PM
MaxVice4's Avatar
Kruppa... I really like you car... How much was your kit all together? the lip,skirt and rear
Old Feb 16, 2006 | 11:30 PM
Swiyzee's Avatar
Maxipimp
Im also shopping around for this remote start and manual trans solution and basically i want to make my factory keyless a full blown alarm and make it ALL operable from the factory fob. this means i want to retain my keyless entry, add remote window rolldown like the 4th gens (holding unlock button), shock sensors, sirens w/factory horn honk and remote start (holding lock button). i was confused by previous post i read because they were not thorough enough and left me in the dark. any lite would be appreciated. -P.S. sorry for thread jacking, it kinda does still fit the subject.
Old Feb 17, 2006 | 12:19 AM
lalaMAX's Avatar
any good one or group buy here? i m lookin for one either... but mine is 2000 auto...
Old Feb 17, 2006 | 05:17 AM
Ammi's Avatar
350 Detroit Muscle
I installed Viper 791xv on my 5sp and works perfectly.
Old Feb 17, 2006 | 08:17 PM
03maxima1's Avatar
Old Feb 18, 2006 | 07:40 PM
lowincash's Avatar
No More Maxipad
you might as well get an alarm system while you're at it...i was about to just get the auto start kit and use the stock remote but decided to get an alarm with it...besides, i like the soft chirp the alarm makes when i arm/disarm and the designated button for the remote start makes it easy to use.
Old Feb 18, 2006 | 07:43 PM
Kruppa's Avatar
Plus you can add two aux's like rear defroster etc.
Old Feb 18, 2006 | 07:46 PM
I agree I say you go with the alarm combo, DEI's newest combo is nice. If u know how to install one its on ebay for about 179 shipped!
Old Feb 19, 2006 | 10:34 AM
trigger005's Avatar
Thanks guys.
BUT... my car already comes with alarm and rear defrosters. Shoulda probly mentioned that earlier...
Apr 16, 2020 05:15 AM
maxima297
Sep 30, 2015 03:32 PM
Pied
Sep 26, 2015 03:29 PM
